It's a non polarized cord.
Alright thanks also would rubber gloves help protect me from the high voltages?
Rubber gloves actually rated for electrical insulation would likely be too clumsy to do fine electronics work in. At least the pair I have...
I would suggest using your DMM to check the outlet you will be plugging into first, to make sure that it is properly wired (wider blade is neutral) and properly grounded. I would suggest using at least a GFCI receptacle if you want to skimp on an isolation transformer. Marking the cord for polarity is a good idea. Installing a polarized interlock and cord is a better one. |
| Audiokarma |
Yes, you want the neutral side of the line to connect to the chassis.
Unfortunately, the set has the power switch in the grounded side of the line, which will make the chassis hot with respect to earth ground when the set is turned off. To make such a set as safe as possible without major redesign, I would recommend the following: Replace the interlock and cord with a polarized type. Move the power switch to the hot side of the line. Directly ground the neutral side of the line to the chassis. Delete C85. Replace C84 with a safety rated (X1Y2) ceramic cap. |
You can get safety rated caps from http://www.justradios.com/ , which also has a good article about the whys & wherefores of such caps:
http://www.justradios.com/safetytips.html Regards, Phil Nelson Phil's Old Radios http://antiqueradio.org/index.html |
New-old tv cleaning
I have been going over the Emerson I got (while waiting for the new power cord) and I have noticed that it seems like this tv was only used once in its life time, as all the tubes test like new (that I have gone through so far) and the crt looks perfect although dusty (like the rest of the inside).
This is the third thread you've started about the same TV. It helps others follow your story if you keep all chatter about a particular set in one thread. It's also far less annoying...
| Audiokarma |
Oh sorry I don't really know how to delete the post so I will figure out how to get rid of it and re post this the other thread.
I merged all the posts together.
