Old 04-06-2017, 03:41 PM
J Ballard J Ballard is offline
80s tube cams fun
Thank Wayne, again, for the clarification.
I recall being at a meeting with the late Carl Eilers, who said the VTR modification would "amount to a xtal change." That might have been an oversimplification, so I stand corrected.
Before the Tek designed format converter arrived at the ATTC, we were likely recording at 1050i (2x 525i) at NBC/RCA with the Bosch camera and Sony VTR. I know we didn't lug a format converter around on remotes!
Some people in the HD committees wanted to perform all tests in 1125 lines-you can guess who. I'll give Charlie Rhodes credit for standing his ground on non-converted source material.
The Sony VTR/tape combination was very tricky. I recall a visit by the Sony field engineer who cleaned our machine, and the bit errors were low. Satisfied, he left for the trip back to NJ. Gradually, throughout the day, the bers began climbing on the VTR, until it was unusable.
I called the field engineer's home number, and told his wife that we needed him back in the Midwest. "Oh, he just walked in.." Needless to say, he didn't want to return.
Wayne-remember that day?
Old 04-06-2017, 04:44 PM
I started another thread on early HD test material so as not to clog up this one:
http://www.videokarma.org/showthread.php?t=268804
Regarding the format converter and Sony VTR, Zenith had no choice but to lug it around everywhere. We did demos at three political conventions, taped a Chicago Bulls basketball game, and taped a 4th of July parade in Evanston, IL.
And yes, we did run the camera gain at -6dB whenever possible, to reduce noise; but this also made the comet-tailing worse.
At the political convention in the Astrodome in Houston, they couldn't find a place for the recorder and format converter, and we had to run 3000 feet of RGB baseband coax out of the convention to our truck. We had distribution amps at 1000 foot intervals IIRC, and our tech, Steve Heinz, had to get the top level of security clearance so he could walk the cable access in case anything went wrong.
The conventions also taught us some things, like MPEG-2 codecs do not do well with confetti drops! Too much unpredictable random motion over most of the image. We also learned that the KCH camera ventilation fans loved to eat the flimsy paper confetti circles - we had to open the cameras and clean the stuff out before things overheated.
On one of the conventions, we had to shoot from the back of the hall. We had a rush delivery of a long lens from Angenieux, and when we turned on, couldn't get the 3x telextender to work. Frantic phone calls revealed that it was disabled when the lens was used on HD cameras, because Angenieux thought it was not of sufficient quality for high definition.
At another convention, we were given a spot on the camera platform. Our signal was converted to HD so it could be used in the regular production if they wanted, but we had a tough time matching the gamma and black stretch of the NTSC cameras. Our associated gear was below the raised platform, with a chest-height wall all around. We had a constant problem of convention delegates putting their half-used soft drinks on the railing, posing a threat of dousing our gear, despite signs all around the outside asking people not to do it. Once when someone pointedly set his drink right above the gear, I "accidentally" knocked it off on his shoes.
Old 05-13-2017, 07:48 PM
Adlershof Adlershof is offline
Originally Posted by kf4rca View Post
I was fortunate that my station didn't jump on the Beta format till the BVV5/BVP5 (BVW505) combo came out.
And with it the big, ugly red smear. Colours were inferior to Plumbicons as well. The BVP-7 was quite an improvement over the 5.
Originally Posted by dauberich View Post
Both the 6000 and the BVP-3 have great colour for a saticon camera.
I think this is actual BVP-3 video, with the revealing Saticon streaking in the night footage:
https://www.youtube.com/watch?v=XGDtih0Sgis
https://www.youtube.com/watch?v=w4vhlMlxTxA
https://www.youtube.com/watch?v=j5avZobt5XU
https://www.youtube.com/watch?v=wFKeH0RmJI0
The BVP-300 I think was the predecessor of the 330. No autocentering and maybe some other not yet features.
While the 330 could be used with the same CCU than the BVP-360 I think.
Can't find it back, but it had been asked here as well: With an adaptor, docked instead of the Betacam recorder, the BVP-3(0) could also be used as production camera.
Originally Posted by Telecolor 3007 View Post
If you mentioned H.D. tube cameras, I'm curios how the image provided by one is.
In Europe we had "Bosch" KCH 1000. Plumbicon and saticon. Never seen images taken with one.
If you believe http://euscreen.eu/item.html?id=EUS_...CC0B0334818E83, where these cameras can be seen at 1:40, several hours of programming had been produced with them every day during IFA 1991. I only saw Bosch KCK, Philips LDK 6 and RCA TK 47 there...
Once a talkshow appeared that had indeed been recorded with this gear, as the continuity announcement proudly mentioned. The 16:9 image, letterboxed into the PAL signal (not even PALplus at this time), could be described as looking like KCM 125 pictures. No surprise, considering that even the housing of this last hurray from Darmstadt had been used for the very early HD cameras that have hardly ever been seen in Europe itself.
B.t.w., some tube cameras had very vivid colours, which I like.
Well, the BBC did not like the Marconi Mark VII for this reason...
The skin tones shown by these cameras could indeed be questionable, although this one (which also experiments with shots that simply could not be done with IOs) got them quite right I think:
https://my.mail.ru/mail/alvem/video/43/2343.html
Or the vivid colours of the Fernseh KCU 40, a camera also disliked in the UK (ot at least at some local station there), for reasons that are beyond me:
https://my.mail.ru/mail/tina-12366/video/10/7598.html
This video is also a nice example for comet tails.
Like yet another one, from the same venue but this time dirty stuff where the KCU 40 / KCR had to cope with adverse lighting:
https://www.youtube.com/watch?v=32x5moK8P2I
Note also the horizontal bars that pop up time and again, such as at 27:30. That's another characteristic effect, in German called Mikrofonie. When it gets really loud it can cause the tubes in the camera to vibrate, and these bars appear in the picture.
And in case you also note the occasional blue and red spikes, although the digital compression widely swallowed them in these videos: This is known as "SECAM fire", in this case appearing on tape drop-outs.
