Old 03-02-2018, 08:40 PM
Here are links to sections of the schematic showing the vertical output and the HV regulator.
That 35Z5 damper with hum control is another oddity
https://flic.kr/p/224WWzJ
https://flic.kr/p/23sRc4V
Wao. Talk about engineering overkill. Sorta like Muntz in reverse.
Old 03-07-2018, 12:53 PM
Notimetolooz's Avatar
I'm very impressed!
Although I'm not a fan of duct tape in permanent construction.
Old 03-07-2018, 11:02 PM
EdKozk2 EdKozk2 is offline
Tinker
These are a couple of pictures with the rebuilt 16AP4A that came with the set. First is with the focus coil disabled. The second is with the focus coil connected to a separate power supply.
The crt wouldn't focus so I checked it out of circuit. I spent a day going over the focus circuit, everything matched the schematics, even the red and blue focus coil wires to the plug connector. This set I found had the wire connections inside the focus coil itself backwards.
I also used this chassis to test another 16AP4A crt today that came out of a Motorola TS-52 chassis I bought in the late eighties. Those are the last two pictures.
If any one else ever comes across a the TS-16/16a chassis, you can find an entire description of its' circuits starting in Riders Volume 5-8 for Motorola. I used a Teleaides for the schematics, better than the Sams for this chassis.
Ed
Old 03-10-2018, 12:29 PM
Bill Cahill's Avatar
Super Moderator
Smile
Does anyone have an extra of that set they'd like to get rid of? That is the niftiest set I've ever seen. Even a hv regulator. Wow!
Please join my forum.
Old 03-10-2018, 01:03 PM
Super Moderator
Thumbs up
Gee. I've never seen re build work like that in my life. It is utterly magnificent.I couldn't do work like that.
Old 03-11-2018, 04:20 PM
Kevin Kuehn's Avatar
Workin' Late Again
Hey Ed, nice work on the Motorola. That was a pretty incredible undertaking rewinding the vert yoke coil. I'd probably of had that thing tied in a knot before I got it back on the yoke form. CRT picture is shaping up nicely.
