Old 06-22-2018, 11:18 AM
Man, that looks like factory condition to me. Good!
Old 06-29-2018, 07:35 PM
nasadowsk's Avatar
Damn does run fast…
Ok, so why did the 6GH8 suck so much, and how come if they sucked so much, did RCA and everyone keep using them?
Old 06-29-2018, 11:08 PM
I don't know, but comparing schematic voltages and calculated plate dissipations to the GE spec sheet, It seems like the pentode section was pushed rather hard in some of the sockets.
The burst amp in the CTC-20 shows a plate voltage of 385 v, but the GE spec sheet says the max rating is 350.
In the CTC-12, the pentode section in the chroma oscillator appears to have a plate dissipation of 2 watts (spec max = 2.5w). In the few sockets I checked in the CTC-20 6GH8 "forest", it appears the plate dissipation was about 1.5w.
Not sure why the plate voltage and dissipation was designed to be so high, because, unlike a triode, a pentode's AC gain is mainly affected by plate current, not voltage.
I guess these tubes were just used too close to their design limits, but by using multitudes of them, the cost to the factory was probably reduced.
Old 07-08-2018, 09:55 AM
mr_rye89's Avatar
mr_rye89 mr_rye89 is offline
On the 6GH8 subject, Last time I went to my local surplus store they had a bunch of em, mostly RCA. I noticed some of them were marked "Brazil" as the country of origin. I wonder if that is one of the factors in the reliability of this tube? Thankfully this set (CTC-21) only uses one 6GH8.
Old 08-23-2018, 12:01 AM
mr_rye89's Avatar
*Update*
The dreaded black bars showed up in the picture last week, symptom of 51 year old filter capacitors. So an order in to Mouser for a bunch of capacitors, pulled the chassis and did the recap, powered up, no smoke or flames
not to mention a great looking picture! (I'll touch up the convergence later)
More to come as I was recently gifted a Dual 1019 changer (original was missing!). The ultimate 1960s audiophile/videophile console!
Old 08-24-2018, 01:59 PM
Popester's Avatar
Popester Popester is offline
Your dial indicator lamp looks a lot brighter than the photo that had it on channel 9. Did you replaced the dial lamp? Set is looking nice.
My wish list:
Sony KV-7010U
Sony KV-1220U
Old 08-24-2018, 03:49 PM
mr_rye89's Avatar
No, same bulb. The AFC knob when pushed in dims/brightens the dial indicator lamp.
