Old 11-03-2019, 08:45 AM
I would use the 3.9 ohm. Its there to reduce in rush current at
turn on so the electrolytics charge slower. It also protects the fuse
from random blowing. Most sets do not use a fuse, just the resistor.
In that case it is of a fusable design not just a wirewound resistor.
Old 11-03-2019, 02:48 PM
Dubis7's Avatar
Dubis7 Dubis7 is offline
Alchemizes cash to tubes
Whoops. I bought a 3.5 ohm at 10 watt last night. Oh well. If I decide I'm not happy with it, I can always switch over.
On the plus side, I also decided to add that missing fuse. I'm real sure GE left it out, so I've ordered one and plan to install it where the schematic calls for it. It's probably not necessary, but it will make me feel a little better.
It looks like once that part comes in I'll be able to get back to where I should be. I'll verify it's still passing video and audio and go from there. One more 3 section can to go.
Old 11-06-2019, 05:06 PM
Dubis7's Avatar
Okay, well mixed news.
The new resistor (Replacing R119) fixed the power issue. I now have sound, video, and high voltage back.
Only problem: I've lost part of my vertical deflection. I also was hearing a clicking from the flyback, but I'm still getting HV and that seems to have stopped after I tightened a few screws on the HV cage. Not sure why that would fix it, but there we are.
So here's what I'm going to check:
- I'll verify that I'm getting the correct voltages out of the 3 sections of the
power supply. Perhaps they're too low.
- I'll verify my HV is high enough. Could that cause partial loss of vertical?
I know the yoke is okay, because in fiddling with the height I've been able to get the picture to bounce all the way down, but it almost immediately bounces back up.
I'm including a video as well. Perhaps someone can point me towards a suspect section?
https://youtu.be/D5siDbEAvU0
Old 11-06-2019, 05:20 PM
1. good
2. No, If HV is too low the picture would be bigger. (slower moving elections are easier to deflect)
3. Seems reasonable.
4. Have you tried adjusting vertical linearity?
Old 11-06-2019, 05:40 PM
Dubis7's Avatar
I did try this. It definitely reacted, but not enough to fill the screen.
Old 11-06-2019, 09:23 PM
Dubis7's Avatar
A few more clues before I call it a night:
I'm getting a response from the brightness control. When I decrease the brightness, the flyback starts clicking like mad and fills out the screen, somewhat. It more flickers with each click. The picture does grow larger. The picture was shrinking when I increased the brightness before I started.
Also, now the flyback is ringing at me. I'm not sure what that means, or if that makes sense. I took a video of it.
I'm noticing that, when I stick a screwdriver near the flyback ring, small blue sparks jump to it. I think that's normal, but maybe not? Maybe I need to treat the flyback with some corona dope?
I decided to stop taking voltages since I wasn't sure if the ringing was dangerous. I measured two of the three sources, and noticed they were actually running about 10 VDC higher than they were supposed to. I'm not sure if that's within tolerance or not.
https://www.youtube.com/watch?v=A3hx...ature=youtu.be
Old 11-07-2019, 12:13 PM
You said in the first post that the tv was “mostly working” before you replaced the electrolytics. So are these new problems, perhaps associated with the rebuilding efforts or were they observed initially?
Old 11-07-2019, 12:22 PM
Dubis7's Avatar
They existed, but have changed, if that makes sense. When I started, the set had AC hum in the audio from bad electrolytics. The picture would shrink and change size with brightness, and the vertical hold was exceptionally touchy. I was also noticing some flashing on the screen. I'm not sure how to describe it, almost like WWII era flak, if you've ever seen video of that. With the brightness up it looked more like the flickering lines you get with tracking issues on a VCR, but with the brightness down they'd be more visible. That wouldn't start until the set had been on for awhile, though.
Since replacing C1 and C2, plus the two paper caps on the main board, the vertical and horizontal hold is much better and the audio hum is gone, but the picture shrinkage and growth is much worse, and I'm hearing sparking from around the flyback. I can't seem to find exactly where it's coming from, though, and I'm not seeing any parts actually failing. I ended up leaving it on for awhile and despite all the sparking noises nothing actually stopped working. It has developed that ringing that I posted earlier, that's new as of last night (and didn't start until quite awhile after replacing C1 and C2.)
I'm wondering if I don't have a problem with the HV rectifier. I ordered a spare to see if that changes anything. I know I have HV from the flyback, since bringing a screwdriver near it and the cap to the HV rectifier causes it to send a healthy spark, so I'm personally inclined to think that the flyback itself is fine.
Any other thoughts? Could this be a yoke problem?
Old 11-07-2019, 01:15 PM
If the rectifier isn't the problem the cup it's socket is in might be...I had a friend's 13" Zenith tube color on the bench a few years ago and that set had HV rect socket cup arc through....the point of the screw that held the socket in the cup was arcing through the cup to the chassis. My solution was clean the living daylight out of the cup to confirm condition, drill out the arc hole and carbon path near it, fill the drill hole with RTV silicone to block the arcing path, and shorten the screw and round it's point to avoid a relapse....worked like a charm, and hasn't failed yet.
Old 11-07-2019, 01:55 PM
Dubis7's Avatar
Okay, so I'm potentially on the right track that my HV rectifier might be suspect, then? I was more or less shooting in the dark, but I figured it's a cheap part and an easy swap, and worst case I have a spare I can access.
I've heard of something called "Bloom" Does that sound similar to what I'm describing?
Old 11-07-2019, 02:17 PM
What you describe is hard to understand...
If you had a blank raster or unchanging test pattern the set should not flicker of change brightness. What blooming typically manifests as is an overload of the HV supply. Less HV makes for dimmer picture and bigger deflection since less HV means slower electrons that hang out longer in the yokes deflection field. Blooming is typically either constant (beam current set far too high) or dependant on average brightness of the video image displayed.
I've never seen a set display something that looks like a tape artifact unless connected to a tape deck....there is a phenomenon known as retrace lines that occurs when screens and or brightness is too high....
You need to post some pictures.
Old 11-07-2019, 02:27 PM
I would also check the condition of the external dag on the CRT to assure that it is not flaking off and is properly grounded to the chassis. Examine the operating set in a darkened room, with dark adapted vision, to look for the arcs.
Old 11-07-2019, 02:42 PM
Dubis7's Avatar
The entire screen flickering is new. It does that when I hear a spark from the HV section. Before it was just the lines I was seeing.
No, it wouldn't be that, then. These actually get more visible when the brightness is all the way down. They looked like lines when a picture was displayed, but when I turned the brightness down they appeared as larger blotches across the screen. I don't think the artifacts themselves were changing, I think the video signal was hiding it. It's almost as if these were electrical spikes going straight to the picture tube that had nothing to do with the rest of the circuity, which again makes me think HV.
I'll plan to either Friday evening or this weekend. I won't get a chance to get to my workbench before then.
Old 11-07-2019, 02:43 PM
Dubis7's Avatar
I'll give that a try. As far as the CRT goes, I didn't notice any obvious flaking, but I can definitely check whether it's solidly grounded.
Old 11-07-2019, 03:06 PM
Dubis7's Avatar
Just to make sure we're on the same page:
When I started, here's what was wrong:
- Audio Hum from bad filter caps.
- The picture would grow larger when I turned the brightness down, and
smaller when I turned it up.
- After being on for a few minutes, lines that resembled tape artifact lines
would appear on the screen. With the brightness turned all the way down
(and the picture not visible) it appeared that these lines were actually
bright splotches flashing on random parts of the screen. These were not
impacted by changing the brightness.
- The vertical and horizontal hold was exceptionally touchy.
What happened when I replaced C1:
- So, I actually technically got this right the first time. I intended to
connect the negative end of my new C1 to ground, along with all the
ground connections that had connected to the negative lug of the can I
replaced. When I soldered it to the terminal strip, I miscounted and
ended up soldering the negative end of C1 and the connections that had
gone to the negative lug of the can to each other on a spare, ungrounded
terminal connection.
- At the time, I also replaced C67 and C105, which are paper capacitors on
the main board. I believe they're related to the vertical and horizontal
holds.
- I tested my C1 replacement and it worked (thanks to my faulty
connection.) I was able to connect a signal and tweak the horizontal and
vertical holds. They seemed much more stable than before. The flashing
on the screen and fluctuating picture size (when I fiddled with the
brightness) were still there at this point, but nothing had gotten worse.
- I recognized my "mistake" later and reworked the connection. I moved
the negative end of my C1 to a ground point, and connected the
connections that were meant to connect to the negative end of C1 to a
ground point on a different terminal strip. That was a mistake, but it also
meant that almost all of the chassis was cut out of the circuit.
Replacing C2:
- I replaced C2 at the same time that I "corrected" my "mistake" on C1. I
was very careful to label which wire went where, and have checked
repeatedly to ensure that I did not miswire anything. C2 should be
correct.
- After replacing C2, I noticed that I was getting filament lights, and
nothing else. It was then that I realized that I had miswired C1.
Fixing my "Correction" on C1:
- I then corrected C1 to match the schematic, but still saw no change.
Voltage measurements indicated that power wasn't even getting through
fuse M1, so I measured R119 and discovered that it had drifted millions of
ohms above what it should have been.
- To verify my hunch that R119 was the source of my problem, I bypassed
it with a pair of alligator clips. The set came back to life, but I began to
hear sparking from the HV section, and noticed that video was now
compressed from the bottom third of the screen. I didn't leave it on too
long like this, since I didn't want to run it for long with R119 bypassed.
- I replaced R119 (3.6 ohms at 7 watts) with a 3.5 ohm at 10 watt resistor.
Where I am now:
- C3 is still untouched. I prefer to test my set after replacing major
components so I know when a problem started.
- Since replacing R119 and C2 (and correcting C1, though that hadn't had
any impact before) the picture has been squished, and a raster doesn't
appear on the bottom third of the screen. There's sparking noises from
the HV section, but the flyback itself still produces sparks when I place a
screwdriver next to it.
- The picture flickers (and sometimes stretches to fill the entire screen, but
only for a moment) when I hear a spark.
- I need to see if the splotches are still present.
- The picture grows much larger, almost to the point of filling the whole
screen (it may actually, but at a certain point it's too dark to tell) when I
turn the brightness down.
- My audio hum is gone.
