Old 03-22-2020, 06:13 PM
maxhifi's Avatar
maxhifi maxhifi is offline
https://antiqueradios.com/forums/vie...p?f=3&t=194179
http://www.videokarma.org/showthread...=248278&page=2
Old 03-23-2020, 01:23 AM
Kevin Kuehn's Avatar
Workin' Late Again
Max,
I did some more poking around and ran across this old thread that you started and possibly you'd forgotten about it. Andy pretty much identified the problem with this post I've quoted below. Andy confirms the sync stability remark with another post at the very end. This Marconi set you're working with definitely fits the category of having a cheap sync design where the sync is taken from after the video amp. Another way of doing this would be grid-leak DC restoration which takes place in the grid circuit of the video amp. That may give you the needed isolation. I'll see what I can dig up on that method.
http://mail.videokarma.org/showthread.php?t=250452
Most sets drive the cathode with the video, and it's coupled to the video output tube via a cap. The brightness control is coupled to the cathode with a resistor and controls the DC voltage on the cathode. All you really need to do is replace this resistor with a diode (cathode toward the brightness control). Adding a .1uF cap between the brightness control and ground will improve the DC restoration a little, but might cause sync, or blanking problems on some sets (some old/cheap sets take the sync off the video output tube, and don't have any blanking circuit). You will also need to add a resistor in series with the grounded side of the brightness control to keep the maximum brightness level reasonable.
As a quick test, you can simply clip the diode in parallel with the brightness control to cathode resistor, and turn down the brightness a little. If you connect the diode backwards, it won't do anything.
Old 03-23-2020, 01:37 AM
Workin' Late Again
Also, if you haven't already, try experimenting with making your .1uf cap value smaller or eliminating it. Possibly you can find a workable compromise.
Old 03-23-2020, 08:08 AM
maxhifi's Avatar
Kevin,
I do remember that now! I was trying to improve my little 8" RCA, it is incredible how fast time passes, I can't believe it was already 8 years ago.
Thank you for looking into this for me, I will pull the chassis today and try some smaller capacitors. It is looking like I am going to.have a lot of time over the next few months. The Marconi was sitting half finished under the desk I'm using to work at home, so when I was preparing to work at home I pulled it out. I'm using it to play the news, and concert DVDs while I'm passing the time. It has a better picture, and a substantially better speaker then my Predicta does, and this one little improvement would be nice.
I also.got a bunch of tubes for it over the weekend from VK member Gregb,
Old 03-27-2020, 12:19 AM
Penthode's Avatar
Penthode Penthode is offline
I noticed the resurrection of this thread and would like to add my own comments. The RCA 630TS employed 1/2 a 6AL5 diode as DC restorer in the circuit depicted below). The RCA sets from chassis KCS28 thru and up to I think KCS47 utilized DC coupling and no DC restorer diode. From about 1953 RCA abandoned DC restoration.
In every case, RCA did not employ 100% DC clamping and compromised with only partial clamping. You can examine the degree of how well black level clamping is achieved by watching active video cutting between dark to bright scenes while examining the vertical blanking bar on the screen (by misadjusting the vertical hold control so the bar is central on the screen). The bar should remain the same shade of grey or black when cutting between scenes.
The later sets without any DC clamping the bar changes with the scene cuts. The earlier RCA sets the bar shade remaiens "reasonably" constant in shade. This doesn't means that there is no noticeable shift in the bar's brightness.
I think the RCA engineers compromised a little and did allow some AC component. Perhaps this was because of normal temperature drift of components which would result in having to constantly adjust the brightness control. Nevertheless, look at the 630 TS and compare it with your original modification. It looks as if R148 was added to isolate the diode capacitance from the video path. Also note R149 the 1Meg ohm resistor across the clamping diode which is necessary as a DC return.
Also note that in the earlier sets, the clamping diode is across the video path to the CRT grid input. Later sets applied the signal to the cathode. The grid circuit does not draw current whereas the beam current passes through the brightness control and thru and around the clamping circuit. A fundamental error in your earlier circuit is that there is no DC path to allow beam current to flow!! So you are going to have to place a lower resistance across the diode which will compromise the clamping. In other words, not to sound to pessimistic, I do not think it will be a simple task getting the cathode driven circuit to work.
Also note that C143 0.25ufd is charged thru R150 which effectively further dilutes the clamping effect.
The bottom line is that it is not a perfect world and engineering is all about compromises. Especially when dealing with analog circuits! I would suggest you carefully think thru this as there are a few gotchas that need to be addressed.
Old 03-27-2020, 10:11 AM
maxhifi's Avatar
Thanks for posting, this helps a lot! I have been using the TV all week, and what I've noticed, is that high contrast scenes tend to lose cause the TV to lose lock horizontally, and there are also rare scenes which affect vertical lock.
This TV actually wouldn't lose horizontal lock through the entire range of the horizontal hold control previous to being modified.
Maybe it is best to just put it back as it was? I suppose if it was good enough in 1958, it's probably still good enough!
I also wondered about where will the beam current flow, and realized that it flows to ground through the diode when the diode is "on", and when the diode is "off" it flows through the video output tube. There is really no other path. This must be what is going on, because the circuit does work, it just doesn't work well.
Old 03-27-2020, 10:55 AM
Workin' Late Again
Did you get a chance to try any smaller cap values? And if so was there any difference on the hold interaction? I looked at grid leak bias restoration at the video output grid, but that requires DC coupling from the video output to the CRT cathode. Could be done, but it's a lot of re-engineering.
Old 03-27-2020, 11:17 AM
maxhifi's Avatar
Not yet, I haven't had a chance to pull the TV chassis out of the case again yet.
Let me ask a dumb question. Is the DC signal we are attempting to restore present at the output of the video detector?
Old 03-27-2020, 06:08 PM
Originally Posted by maxhifi View Post
...Is the DC signal we are attempting to restore present at the output of the video detector?
Yes. The DC component is broadcast. One of the consequences is that the RF power at sync tips or blanking or black level does not change due to variations in the scene content. Therefore (assuming the TV's AGC circuit is working on sync tips) the output of the video detector is similarly stable.
However, carrying this all the way to the CRT by using DC coupling all the way is not practical in tube sets (too much drift over time/temperature, plus changes every time you replace a tube). It is also not practical in solid state sets even if the transistors do not vary, due to component tolerances. Every stage would need the bias circuits replaced with adjustable potentiometers.
The only reasonable way to stabilize the video DC level is to do it close to the CRT, (or measure it at the CRT and use feedback to adjust it at an earlier point).
The ultimate solid state CRT TVs used feedback to control the CRT bias individually for red, green, and blue, thus achieving not only DC restoration but automatic CRT tracking. The video IC restored DC in the low-level luminance, then added a low brightness pulse at the top of the raster just after retrace (where you can't see it) to measure the CRT beam current near black.
Why not measure zero current, exactly at black, to set cutoff? Because a CRT has a power law current vs. voltage characteristic, so at zero current, the incremental current gain is also zero, which means there is no feedback signal.
Old 03-27-2020, 06:22 PM
By the way, if the DC component was not broadcast, it would of course not be present at the detector, and the whole exercise would be somewhat futile (although it could have some effect by clamping the darkest thing in the scene as black).
Iconoscope camera tubes had inherent AC coupling. The DC level had to be made up by clamping the darkest parts of the scene to not go below black, plus there was a "shader" (a live person) adjusting it along with the spurious shading across the image that the iconoscope was prone to. Someone who does camera electrical alignment is still called a shader today, although they are not doing it all real-time during use.
Old 03-30-2020, 12:34 AM
Penthode's Avatar
The reason you are losing sync is because when the brightness is turned up high or the contrast advanced, you are clipping the sync with the diode! I suspect the sync take off is at the plate of the video amplifier.
Compare your circuit with the RCA 630ts and note R148 which will alleviate the sync clip.
It is a mystery how it works all unless the diode was installed opposite to how you depict it. The CRT electron current flow in the original design is from is ground through the brightness control up thru R32 the 150K resistor to the cathode of the CRT. The diode depicted in your drawing would obstruct the beam current and there is no other path unless C19 the 0.05ufd coupling capacitor is very leaky!
Old 03-30-2020, 12:56 AM
Agree with the possibility of clipping the sync. Adding a series resistor as in the tube circuit would fix this.
Disagree with the "can't work" statement. The added diode is in the right direction for restoring DC at the CRT cathode. The sync tips are positive here, and C19 is charged by diode conduction during sync, then discharges through the CRT during active video. In the case of grid drive, since there is no grid current during active video (or at any time) to discharge the coupling capacitor, a resistor is added across the diode.
Investigation of the charge/discharge time constants with a scope by looking for tilt on the cathode waveform and sawtooth on the added 0.1 cap would help optimize the capacitor values.
Old 03-30-2020, 12:59 AM
Workin' Late Again
I don't think I've ever seen a textbook or manufacture example of a diode in conjunction with the video going to the cathode. The diode orientation is confusing because early on there was a double standard depending on function of the circuit. I always assumed that came about because of conventional vs electron current flow.
Old 04-01-2020, 01:44 AM
Penthode's Avatar
I agree. Why I suggest it can't work or at least the concept is faulty is because there is no path for the CRT beam current. The diode is in fact reversed to the flow of beam current. This may explain why the clamping diode was only used for grid driven CRTs.
Old 04-01-2020, 10:38 AM
The path for the beam current is the coupling capacitor. Electrons are drawn into the coupling capacitor throught the diode during sync pulses, then flow from the capacitor into the cathode and the CRT beam during active video.
On average over time, the charge drawn through the diode equals the discharge through the beam current.
