Old 02-28-2021, 09:50 PM
recepteur recepteur is offline
Hello old_tv_nut
The white line is not stationary with respect to the picture tube face as it does move with the vertical centering adjustment.
Old 02-28-2021, 09:56 PM
Gents,
As of todate, I've replaced all the resistors and capacitors on the vertical oscillator and balance amplifier and the thin white line remains. I've check both vertical sawtooth waveforms and they are both identical 180 degree out of phase. All the high voltage rated capacitors (6KV) used for deflection were replaced last month. Cheers
Old 03-01-2021, 06:19 AM
Too bad you didn't have another CRT to test it , perhaps it's the CRT at fault
Old 03-01-2021, 11:12 AM
But could the CRT really be causing it? Seems kind of unlikely to me, but then again, I have little experience electrostatic deflection TV sets, beyond working on oscilloscopes.
BTW, I'm NOT a gent!
Old 03-01-2021, 11:29 AM
old_tv_nut old_tv_nut is online now
Originally Posted by recepteur View Post
Hello old_tv_nut
Curiouser and curiouser - one report of movement and one report of none.
Old 03-01-2021, 11:30 AM
Good day Yamamaya42,
Noted !
Cheers
Old 03-01-2021, 11:52 AM
Is there waveforms provided with that schematic? I see something on there marked point V, right out of the video det, before the video amp, and if it is anything like most sets I have seen, and the video signal there is about 1.1v ptp, one could try coupling in an external monitor, and see if the video is clean there.
I did this on my FADA.
It will rule out any problems there and before that point.
Old 03-01-2021, 12:41 PM
Hello,
I will compare with the waveforms provided in the Admiral chassis 19A1 schematic.
Unfortunatly, I don't have an external monitor.
I disconnected the coupling capacitor c43 .05 mf and the thin white line remained.
Cheers
Old 03-01-2021, 12:48 PM
Is there waveforms provided with that schematic? I see something on there marked point V, right out of the video det, before the video amp...
He's already disconnected C43 which decouples the CRT from the vid output, and the line is still there. (Edit. OOPs he just posted this again)
And since the line moves with the vert centering adj., the blip has gotta be modulating CRT beam intensity. I still say look for the blip on pin 5 or 9 (focus anode and accelerator(?) anode respectively.
Old 03-01-2021, 12:57 PM
That pretty much rules out that it's coming from any video source, you could try hooking an oscilloscope to c32a/ the brightness pot, while c43 is unhooked, there SHOULD be nice clean power there, and that will rule out any PWS issue, I doubt that is the problem, but you never know.
Old 03-01-2021, 01:21 PM
This may be way out in left field, IE making a wild guess here, as I said, I have not worked on this type of TV before, could this possibly have something to do the HV power supply being off frequency (too high/low) and causing an odd resonance on the screen?
There only seems to be the .005 cap on the line, and if the osc is somehow de-tuned a bit, who knows what weird stuff it may do.
Old 03-01-2021, 01:38 PM
Hello,
I will look for the blip on pin 5 or 9 knowing there are some high voltages. I'm trying to figure a way how my scope will be able to read such voltages without causing any damages to the equipment. Please advise me. Cheers
Tom9589 Tom9589 is offline
Yamamaya42, don't go to New Jersey. They refer to everybody as "you guys."
Old 03-01-2021, 01:51 PM
I was born in Poughkeepsie, then I moved to hell at the age of 10. (aka, Texas )
Old 03-01-2021, 01:58 PM
I wouldn't want to advise you on using a scope considering the voltages present.
As an alternative, I would do this - take a cap of .1 uf or higher, and jump it from pin 5 to ground and see if it kills the blip. Then from pin 9 to ground and see. Try the cathode too for the heck of it (pin 2).
But as a precaution, first measure voltage on the pins to be sure it doesn't exceed the cap's voltage rating.
