Old 03-30-2021, 06:17 AM
tornadoman tornadoman is offline
I had one of those HDTV tuner cards for my PC back in the early 2000's and early HD, before all of the subchannels came along, was awesome. Even 720p channels back then easily trounce the 1080i OTA channels today.
Old 03-31-2021, 11:50 AM
Tom9589 Tom9589 is offline
Old TV Nut, you are correct. I misspoke. Our ABC affiliate is broadcasting in 720p. I went back this morning and checked all of the major Atlanta TV stations:
ABC: 720p
CBS: 1080i
PBS: 1080i
NBC: 1080i
Fox: 720p
OTA shows the difference. Cable shows virtually no difference at all.
Old 04-02-2021, 03:13 PM
NewVista's Avatar
NewVista NewVista is offline
Originally Posted by Tom9589 View Post
PBS: 1080i
All this time I'm thinking PBS is 720, like my local PBS (which has sacrificed HD bandwidth by squeezing in do-gooder channels, in a certain foreign tongue, that this hoped for target audience apparently totally ignores.)
Old 04-02-2021, 06:46 PM
dtvmcdonald's Avatar
Back at the beginning of DTV, ABC and Fox chose 720p because it was thought better for
sports. And back then, it was. There were three reasons: interlace artefacts per se,
the Kell factor of blurring used to reduce them, and the fact that nobody actually
transmitted 1920 resolution, the absolute max was 1440. This was implemented by
restricting the coefficients in MPEG.
At least around here, they are equally horrible.
Old 04-02-2021, 10:32 PM
NewVista's Avatar
Anyone else notice their local OTA PBS has been kicked down to 720?
Old 04-03-2021, 04:35 AM
NewVista's Avatar
...besides, any 'advantage' of 720 is now moot because right at this moment, sports broadcasts are being originated with 1080i PsF cameras, resulting in zero interlace motional artifacts!
Old 04-24-2021, 03:33 PM
KentTeffeteller's Avatar
Gimpus Stereophilus!
Big issues. The network affiliates and their equipment (not trivial, as in Millions). Problem B: Cable and Satellite down-rezzing it even more. Sorry, reality applies.
Old 04-24-2021, 03:57 PM
nasadowsk's Avatar
Damn does run fast…
Does the FCC even enforce standards anymore?
