Old 04-06-2024, 10:30 PM
luRaichu's Avatar
luRaichu luRaichu is offline
NIGHT STALKER
There is quite a pulse on that transistor case, you can't use layers of tape to replace the original mica insulator.
This is 3M Super 8 electrical tape. The HOT is rated for 600v max, so is the electrical tape iirc. Although it would explain the goopified tape around one of the HOT legs.
I don't have the original mica sheet. It was glued to the old, busted HOT with some weird white substance.
Old 04-07-2024, 04:27 AM
Retired Batwings Tech
That weird white substance is the silicone heat conducting grease and without it the transistor could fail from overheating. Same stuff used on processor heat sinks and should always be used. The tape itself is not very heat conducting and its breakdown of 600V is the MAX at its nominal thickness not compressed under a transistor. There can be upwards of 1000V between the transistor case and ground during the flyback period and this is why it is so important to do things the right way, HOT's are not cheap as I remember and so far I've seen about half a dozen blown in this thread.
Old 04-07-2024, 08:17 AM
luRaichu's Avatar
NIGHT STALKER
I'll have to correct you on that, I've blown a quarter dozen. They're $6 a pop, I can afford it...
But yeah this makes me feel pretty stupid. I guess I will try mounting the HOT externally just as a test to see if the previous mounting setup was bad.
Old 04-07-2024, 08:37 AM
What were the ORIGINAL HOT part numbers ?
The tape has to go ! Lets double check the ##'s then
clean it up spotless & get a mica insulator & compound.
On the U tubes I saw no reason for the fail looked
pretty normal.
Zeno
Old 04-07-2024, 08:54 AM
luRaichu's Avatar
NIGHT STALKER
pretty normal.
Zeno
The original HOT was Matsushita 2SD517. I got the EXACT same replacements from eBay https://www.ebay.com/itm/294368705463
Old 04-07-2024, 01:15 PM
luRaichu's Avatar
NIGHT STALKER
I'm going to buy these two things on Amazon.
Mica insulator -> https://www.amazon.com/gp/product/B07P428VZ1
Thermal grease -> https://www.amazon.com/gp/product/B005VULWLA
Old 04-07-2024, 03:49 PM
The breakdown of the insulator to ground is going to kill the transistor. If I remember the heatsink was a ground potential on those Color Pilot sets, worked on may of them as they popular computer monitors in the 80s on the Apple-II that had a composite out.
Old 04-08-2024, 11:58 AM
Originally Posted by luRaichu View Post
Should I drop the lightbulb in place of the line fuse, or the +B fuse?
Being the supply in the vicinity of 120-140V, a 120V bulb will survive of and you can protect the PSU using it in the place of +B fuse, if have one. You can test the PSU even if HOT shortens out (if is a < 30W bulb).
For the entire TV, is good to use a higher wattage one.
Test only after aplying the correct insulator (mica) and thermal grease (+1 for correcting this first).
Old 04-08-2024, 02:49 PM
luRaichu's Avatar
NIGHT STALKER
How much thermal grease should be used? It should be applied to both sides of the mica, right?
Old 04-08-2024, 09:19 PM
Yes, just a little dab is all that's needed on both sides then tighten the screws evenly allowing the thermal grease to squish out, this takes the air pockets with it.
Old 04-09-2024, 06:51 AM
Just to be on the safe side, is good to check or sub the pulse H cap (or resonating/efficiency cap). Is one generally having one pin to collector of HOT and another to ground (like the ceramic cap), in the board. It have values in the vicinity of 6 to 12nF, with at least 1600V of WV. A failure with that, and the HOT shortens out.
Old 04-09-2024, 08:43 AM
luRaichu's Avatar
NIGHT STALKER
I just checked the cap list I'd made, there are no capacitors in the TV that are in the realm of 1600v. I will check again since there are four 160v caps used and there might've been a read error.
Old 04-09-2024, 03:39 PM
luRaichu's Avatar
NIGHT STALKER
This TV has ceramic caps on the HOT collector (red wire). Since they're not electrolytic, unlikely to fail IMO.
Old 04-09-2024, 04:34 PM
Are you willing to take that chance?
Old 04-09-2024, 05:35 PM
luRaichu's Avatar
NIGHT STALKER
In my experience, only electrolytic caps manufactured in the 90s/Y2K go bad. I've never really seen a ceramic cap spoil, and even electrolytics from the 70s and 80s still hold up alright.
That said, I do have a single 1500pf @ 3000v ceramic cap lying around. I'm not sure whether the 700pf difference in capacity matters.
So YES, if the 1500pf cap isn't a suitable replacement I will try running the set anyways once the HOT is mounted correctly. I think I'll be very lucky if the HOT blows again; with the proper mica insulator and all - and new HOTs cost less than a bag of jerky anyhow.
Edit: don't just take my word for it, ask our mother ship https://audiokarma.org/forums/index....#post-11556769
