Old 08-19-2015, 07:15 PM
SwizzyMan's Avatar
Restoring an admiral c322
There is a lot of magenta/purplish color and certain things but you can make out skin tones and some objects. And a bit of noise in the picture but reasonably clear.
RCA CTC-7 Pensbury (Restored)
RCA CTC-5 Westcott (Restored)
Old 08-19-2015, 09:35 PM
miniman82's Avatar
First Light: 1952-2011
If you disturbed T704, you threw off the chroma circuit alignment which is responsible for making the correct colors appear on the screen. Hook up the color bar gen and look at the screen with a mirror while adjusting the top and bottom section of T704 till the bars look right.There is also a chroma alignment procedure in the service manual, if you feel like doing it the hard way. Make sure the tint control is in the middle when doing T704 adjustments, or you'll have limited tint range when you're done.
Evolution...
Old 08-19-2015, 11:32 PM
Once you've got the bars looking nominally good, get a regular pic on screen showing people's flesh tones. Set the tint control mid-range. If the flesh tones are too green or too purple, tweak the burst phase adjustment T703. It shouldn't take more than 1/8 turn or so either direction get correct flesh tone.
Back in the day, flesh tone was the standard reference for centering the tint range.
Old 08-20-2015, 06:19 AM
SwizzyMan's Avatar
OK adjusted T704 and it looks great. I still need to do some convergence adjustments. Here is a picture of what I have now. Is there any problems with any of the bars to any of you?
Old 08-20-2015, 06:30 AM
SwizzyMan's Avatar
One more thing. Would it be a bad idea to use this as my daily watcher? All guns test great and the life test is good.
Old 08-20-2015, 07:25 AM
You should be able to use the set. Keep a eye on the line voltage. This set was designed to run on 117v ac. and you DO NOT want to run the set any higher than 117v ac. It can cause problems with the horz circuit and burn out tubes.
Old 08-20-2015, 07:29 AM
MRX37 MRX37 is offline
image looks really tilted. Perhaps adjust the yoke?
Old 08-20-2015, 12:39 PM
Those are good color bars.
Before messing with convergence, I'd look at a crosshatch test pattern (or dot pattern) to judge whether it really needs improvement. Read about convergence in the manuals. Convergence is a multi-step procedure, not just one little tweak. On a color "roundie," it's difficult to get perfect convergence around the edges of the screen.
You can also look at regular programming to judge convergence. Look at the edge areas of the screen -- left, right, top, bottom -- and note whether there is "color fringing" around the edges of objects. This may be more obvious where there's lettering on the screen.
Some small amount of mis-convergence is pretty common in my experience. Ask yourself if your picture would bother you in everyday watching. If the answer is "not really," you could skip convergence for the time being. If your convergence is already pretty good, and you screw it up with hasty adjustments, it could be hard to make it that good again.
Phil's Old Radios
Old 08-20-2015, 02:43 PM
SwizzyMan's Avatar
Kind of seems like I just need the dynamic convergence a lot. The line voltage coming from my cheater cord that came with the TV is reading 122v is that too high? If so how can I fix that? Will degauss the screen again and fix the tilt.
Old 08-20-2015, 03:19 PM
SwizzyMan's Avatar
I must also note that there is a lot of noise distortion in the picture. I tried messing with the fine tuning but no luck. Should I do a color purity and dynamic convergence the red line is a bit higher when the blue and green are both one line.
Old 08-20-2015, 06:28 PM
SwizzyMan's Avatar
One other thing I have tried degaussing the set atleast 5 or 6 times and I still cannot get a little bit of yellow to go away on the bottom right of the red screen. I am using a junk tv degaussing coil.
Old 08-20-2015, 07:14 PM
Yes, That is to high. You need to find a variable auto transformer.{ variac}
Running your set 0n 122v could raise the horz output tube cathode current, And melt down the fly back. I know it sounds stupid that a difference of 5 volts could damage the set but it can. To correct the tilt, Just turn the yoke when looking at a crosshatch. You will see what he means.
Old 08-20-2015, 07:17 PM
SwizzyMan's Avatar
What would be considered minimum dangerous to the set? 119v? or not any higher than 115?
Old 08-20-2015, 07:37 PM
Here is a picture of my variac. This unit is 20 yo and is rated at 10 amps.
Old 08-20-2015, 07:39 PM
SwizzyMan's Avatar
I really dont have the money for a variac. Is there any other possible alternatives?
