#496
I once had a Majestic TV (1951 model) which had a round 16GP4 CRT (metal cone). Never had one bit of trouble with the tube losing vacuum or anything else. Also, I did not realize that round CRTs had seams anywhere in or on them; in fact, I don't recall seeing a seam anywhere on the 16GP4 in my set. (I learn something new all the time reading the posts in these forums.) Round metal-cone CRTs: I agree with you one hundred percent. Those tubes worked well enough, but the metal cone created the heck of a HV shock hazard, as I think the cone was one half of an HV filter capacitor, the bell of the tube being the other (this technique, IIRC, replaced doorknob HV caps in many if not most 1950s sets with round CRTs). IMHO, the best thing ever to happen to television CRTs was when the manufacturers gave up on metal-cone tubes and switched to glass exclusively, which all but eliminated the shock hazard.
Jeff, WB8NHV Collecting, restoring and enjoying vintage Zenith radios since 2002 Zenith. Gone, but not forgotten. |
#497
That said I have a 50+ year old 16AP4 that is still holding vacuum as was the worn out tube it replaced. I think the bigger tubes (19", 24" 30") probably had more problems because of the larger joint surface and the extra expansion contraction problems. The metal tubes don't hold a charge on their own but I guess you could still get shocked with the set off if the doorknob cap was charged up. |
#499
You're right setchell carlson is what I was thinking of.
Jordan |
#500
Dont feel bad as i get the two confused once in awhile myself. Still a cool tv though.
-Tony |
| Audiokarma |
#501
Load of TVs - US$ 50 each one
#502
Jordan |
#503
50's (?) RCA set
I didn't see this one on the first page, so here it is:
http://cgi.ebay.com/ws/eBayISAPI.dll..._promot_widget The seller says he blew a resistor by turning up the focus control. I wonder what that means? Maybe he incorrectly replaced a cap or two? Looks like a nice little set.
Sony Trinitron Fan |
#504
He doesn't do grill cloth either!
tvontheporch.com |
#505
I didn't know that model had grill cloth. Was it supposed to wrap around the entire top half of the front of the set?
| Audiokarma |
#506
tvontheporch.com |
#507
#508
A Rarity!
RCA "Victory". Guess that means it's post-war, huh?
![]() http://baltimore.craigslist.org/hsh/507856749.html veg
Admiral Combo on Goodwill MI
| Audiokarma |
