jr_tech also has it, and he did the input impedance test on it, and it was 10m.
it a rather complicated thing to do with a voltage source and a 2nd DVM. most DVMs of this type are, but most clamp meters are 1m.
=^-^= Yasashii yoru ni hitori utau uta. Asu wa kimi to utaou. Yume no tsubasa ni notte. いとおしい人のために |
So the msr- r500 is the one to grab
I guess that would explain why when I touch the probe I see a little tiny spark.
It's almost like adding an extra resistor to ground.
Well I don’t know how much this meter was affecting the voltage outcome a guess maybe 10-12 volts lower then what it is normally.
| Audiokarma |
Lower impedance circuits (such as power supplies) would be hardly affected at all by the load of a 1 megohm meter. jr Last edited by jr_tech; 10-05-2022 at 03:21 PM. Reason: clarify p 9 measurement |
Ever since I accidentally let the hot red plate for like 40 seconds this is what I’m left with. Does this look like a bad damper. I am going to try a damper but I have both boost voltages so what’s this it looks like a bar generator but it’s not. Stumped again.
like that are from some Osc, you can see they are perfect repeating not waving or anything like that. What happens when you change the Horiz. Hold? Is it always there? Does not look like a bad damper. If you got good Boost V. Damper is most likely good. But with respect to the bars, On the outside, could possibly be Heater-Cathode leakage, or short? Just a guess..... Unfortunately, this might be a job for Mr. Oscilloscope..... Some frequency getting into video? Does it remain or change with Brightness, or Contrast change...? .
Yes you can call me "Squirrel boy" Last edited by Username1; 10-05-2022 at 09:51 PM. |
between the last pic posted and this http://videokarma.org/attachment.php...7&d=1664286524 http://videokarma.org/attachment.php...1&d=1664977314 there has been 10-15% width lost. which is strange is the horz frequency way off? or the Damper damaged?
| Audiokarma |
Already tried 2 new horizontal output tubes of course no change. One thing after another. So I need to find out what gives up when these tubes red plate to long.
A weak damper can cause low HV & insufficient horizontal width, but can also be a symptom of the horizontal osc being at the wrong freq, or a damaged HOT.
A new damper is a rather low cost first step in working out the problem.
So if the frequency is low then that’s why the bars are there and are you referring to hot as tube or flyback. I have 2 new dampers coming tomorrow.
HOT = horizontal output tube FBT = flyback transformer.
Wait till you get the new damper, then once again do the setup for direct video input at test point B, and then adjust horizontal hold to try to get lock, once you get lock, there should be no need to adjust it again.
Well there is a difference in meters I have a cheapy meter from sears looks just like the one mentioned in the previous few posts and on one pin I checked was 188 v but with the cheapy meter it showed 203 v that’s a 15 volt difference wow I have to check all voltages again.
| Audiokarma |
