Old 12-23-2009, 09:19 AM
Sam Cogley's Avatar
Sam Cogley Sam Cogley is offline
The Devil Inside
Excellent work!
Growing up leads to growing old and then to dying,
And dying to me dont sound like all that much fun...
-John Mellencamp
Old 12-23-2009, 10:13 AM
Sam Cogley's Avatar
The Devil Inside
Watching your videos on the WR-8, I think I've figured out what that wooden plug in the speaker is for - it might be a deflector to distribute sound around the room, compensating for the upward-firing speaker.
-John Mellencamp
Old 12-23-2009, 10:58 AM
jeyurkon's Avatar
jeyurkon jeyurkon is offline
That looks great! You have more patience than I. I would have taken one look at it and sent it in for reconing.
Old 12-23-2009, 01:13 PM
That's a very good idea.
Thanks. I was going to until I got some words of encouragement This one sure needs some reconing though!
I've seen similar vintage speakers going for around $20. I imagine reconing costs a lot more than that.
Old 12-23-2009, 01:23 PM
jeyurkon's Avatar
It cost me about $76.00 I'd have to try to find his address, but there's an older gentleman who will do it for $60 and I'm told he does an excellent job. I didn't find out about him until I had mine done.
Old 01-07-2010, 03:17 AM
Progress update
I've broken the cabinet down as much as I can and have been gluing all the separated veneer.
The veneer has separated at virtually every edge. I wonder what happened to this cabinet - high humidity, heat, crappy glue ?
Here's some of the original finish. I've ordered up some Dark Walnut Mohawk toner lacquer - should be a good match. I'll try golden oak for the center board.
I also picked up some new speaker cloth from AES that is a perfect match to the old fragments. Here's a dry run.
Here's the old filter capacitor. It's pre-electrolytic so that huge box just has a 2 MFD, 3 MFD, 3MFD and 0.05 MFD in there. The new ones are a little bit smaller
I'd like to remove that old block of tar but it's being stubborn. I figure it will shave at least 5 pounds off the weight if I can get it out I've tried a heat gun and the oven. Only got the first layer of tar out so far.
Old 01-07-2010, 03:40 AM
rollei35guy rollei35guy is offline
Maybe put that capacitor box in the oven for a while to soften up the tar?
Also I was watching some early episodes of 'Homicide: Life On the Streets' and noticed in the Lieutenant's office there was a what I think was a 'Columnaire'. Just caught a glimpse of it.
Nice work for sure.
Old 01-07-2010, 04:55 PM
Originally Posted by rollei35guy View Post
Maybe put that capacitor box in the oven for a while to soften up the tar?...
I've tried that. It did soften up the tar, but the guts just wouldn't slide out. It's tough to work with a big, heavy, hot box oozing tar! I'll give it another go soon.
Old 01-08-2010, 07:29 AM
I wonder if you can soften it up some in the oven. Then run a knife (a nice chef's knife from the kitchen perhaps ;-) ) around the edges to break the bond.
Turn it upside down pop it out. Sorta like a cake or loaf of bread.
Another thought might be to insert a couple of long lag screws or screw eyes into the tar. Would give you something pull on.
Old 01-08-2010, 02:25 PM
I finally got it out
Thanks for the suggestions. I let it cook for about 30 minutes @ 300ºF while upside-down. Gravity finally took over.
I like that idea about the screws - I'll try that next time
Old 01-08-2010, 02:51 PM
Tar filled multi-Section capacitor, it's what's for dinner!
Good job.
Old 01-08-2010, 02:53 PM
PunkTiger's Avatar
PunkTiger PunkTiger is offline
SW DXing
My, that's unpleasant! I bet the house will smell of tar for a few days, Febreeze be damned.
Do you think there will be enough room in that box for the new caps? It looks kinda tight. ;-)
Old 01-08-2010, 03:13 PM
leadlike's Avatar
leadlike leadlike is offline
I keep a corkscrew around for such purposes-really works well on the more traditional multisectional lytics we love to restuff.
Yum, yum !! Do you know what the values of the damthaing were/are ? I'd wager you can put modern ones back up in the space vacated by that nasty mess & no one will be the wiser...I sure won't tell...(grin)
Old 01-08-2010, 04:02 PM
A whopping
0.05 MFD
2 MFD
3 MFD
3 MFD
Yeah the new ones will fit with loads of room to spare
