Old 06-04-2010, 06:42 PM
dawgs's Avatar
dawgs dawgs is offline
new project?
good evening everybody, how goe's things?. I have a new project?. your probly thinking?, he always has a new project that he's working on?. thing is, I don't have all the fancey eqwipment to test all of my new toy's that I rescue frome file 13,. anyhow, I'd like too get this one up & running. not sure about all the tubes' and there funtions in this set?.
dawgs
Old 06-04-2010, 07:02 PM
Nice old Transceiver, it probably needs some new filter caps just like an old TV.
I think you would get a better response for help if it was posted in the Antique Radio Forum though, would you like me to move it there?
We also have a Forum for "Hams" you might want to check out before trying to operate that thing, I don't know much at all about Ham Radio but you might need to check on licenses (if any) required to operate it.
Old 06-16-2010, 05:48 PM
dawgs's Avatar
the ham radio project
good evening everybody, I've done a lot of tube replacements on the ham radio, the resultsare the same., on the usb & the lsbd, things are the same,. when a station comes in, there's a sqweal,. I can tune it in until the sqweal stops, but there is nothing there. am I doing something wrong, as per instrutions, I've put the set into the mode for the up & stating mode,. is there something I'm doing wrong?.
please addvise me thank-you.
dawgs
Old 06-16-2010, 05:59 PM
dawgs's Avatar
lost the pictures as usual
dawgs
lost the pitures as usual
Old 10-27-2010, 05:56 PM
dawgs's Avatar
been away for a while, but, I have something new for yous too figure-out, got it out-of a scrap plie at file-13 again as usually,..
tans
Old 10-27-2010, 08:01 PM
Tubejunke's Avatar
Dawgs, you know, you don't really need much of any "fancey eqwipment" when it comes to troubleshooting vintage electronics equipment. The main thing that you need is a working knowledge of how to properly measure voltage, resistance, and current (amperes). After you achieve that, all you really need is a modern digital VOM, and what a lot of techs refer to as an "amp clamp." These things, like most technology, have become so cheap to produce that you can get fairly decent stuff these days for not a lot of money. Your average VOM will have the capability of measuring current (amperes), but current must be measured in SERIES with the part of the circuit to be tested, which boils down to breaking a connection somewhere and connecting the meter probes at the break. Why do this when you can get a clamp type meter and effortlessly check your current. The main thing I want to stress is that ALL meters can be VERY dangerous, if not fatal of improperly used. If you are in doubt ASK someone!
Other than a meter, a tube tester is completely necessary and can amazingly be found used for reasonable prices considering the fact that without one, a person into vintage electronics is about a crippled as he could possibly be. I mean it's the same as any job; certain tools are just necessary, and all of the knowledge in the world is useless without the right tools. That is unless you are of the eccentric variety that can just pay some lucky tech to revamp your toys with a blank check.
So we still are not looking at anything fancy or expensive. However, if you REALLY get deep into the trade or hobby you might decide to tackle alignment jobs and the need for more expensive equipment becomes necessary, ie. signal generators and oscilloscopes. The beauty is that you can have a lot of fun with vintage electronics and hardly ever find the need to touch these items. I do encourage anyone in this hobby to learn the ins and outs of scopes and the alignment of signals. I say this because the garden variety TV and Radio professional is getting older and thinning out. Soon there could be very few people in the country who have the knowledge to do more than swapping tubes, resistors, and capacitors, etc. I myself am going to try to enhance my knowledge of waveforms (more than sine and square waves) AND get the necessary tools for alignments.
Good luck with your projects!
Old 10-27-2010, 08:40 PM
RitchieMars's Avatar
RitchieMars RitchieMars is offline
VK Member
In regards to your Philco, I had a bad audio output transformer in my '53 Zenith, and I went the same route. I took a very similar transformer out of a derelict RCA tube radio and it worked for me. I took resistance readings on it and made sure it was at least similar in that respect, although I was told that the turns ratio is actually what makes the difference.
As for what ruined my old transformer, I'm pretty sure that it fried due to bad capacitors. If you have any of those old wax capacitors lingering around in your chassis, you might want to evict them to make sure the trouble doesn't return. From your picture, it looks like your set is in decent running condition. Were you having horizontal troubles?
