Old 10-03-2010, 03:46 PM
jeyurkon's Avatar
jeyurkon jeyurkon is offline
I may be off base here, but I believe that the very tiny leaks that we are trying to stop on CRTs are much too small for a liquid like vacseal to be "sucked into". I look at it as a dense low-vapor pressure coating that essentially provides a second containment wall, in case the first fails. I have painted it around CRT neck pins, base pins and tip seals as a preventive measure. I have no statistically significant proof that it did any good, but in those small quantities, it is pretty cheap per application.
You're not off base. But, Vacseal is intended for small leaks. If the leak is too large it gets sucked in too much and doesn't plug the hole. In smaller leaks it thickens as the solvent evaporates and gets too thick to pass further.
Vacseal is intended to be cured at temperatures above 200C. It cures below that temperature, but not as well. The very property that makes it a good sealant prevents the solvent from evaporating rapidly once a skin has formed. Heat helps.
Unopened bottles have a shelf life of 3yrs. Cans, 3 months. I've had opened bottles that refused to cure even with heat. I suspect it cures much the way shellac does, and doesn't.
The datasheet says that the surface will always seem a little sticky so don't worry about that.
Old 10-08-2010, 11:26 PM
ohohyodafarted's Avatar
Bob Galanter
OK So who was the winner? Only one bidder took it for 5K.
ME http://AntiqueTvGuy.com
Old 10-08-2010, 11:34 PM
ctc17 ctc17 is offline
Yep, first bid at 45 seconds left then he hit it with another bid in the last 5 seconds to block any other potential last minute bids.
Hes fairly local so thats nice.
Old 10-09-2010, 10:44 AM
kx250rider's Avatar
REAL TVs have TUBES!
Not me...
Charles
Old 10-09-2010, 12:06 PM
jeyurkon's Avatar
Not me either. I was tempted, but didn't feel right dragging it across country.
Old 10-10-2010, 07:39 AM
kvflyer kvflyer is offline
Well, I wish I could say that it was me. I was tempted as well but don't have that kind of money and as mentioned above, don't have the means to cart it for all of those miles. It sure is a piece of history. And I would guess considering what it is, it was worth that money.
Let's hope the new owner surfaces and that we find out the status of the CRT. Sure would be nice if it works! That chassis would be a candidate for a very slow restoration with the stuffing of original capacitors. Wadda ya think?
