Old 01-16-2011, 10:05 AM
if the HV looks right, the HOT and Shunt current look correct? I like to watch the HV while oberving scene changes to see how well the regulation is taking place. I also recall reading somewhere that defects in the video amp circuit can cause excessive beam current due to bias on the CRT cahodes being incorrect resulting in overloading of the HV circuit.
Old 01-16-2011, 12:12 PM
doogie812 doogie812 is offline
Replace the 3A3! Doogie
Old 01-16-2011, 10:58 PM
If the HV and regulator are OK, but the CRT draws too much beam current, you will SEE it go out of regulation (losing focus, and picture size changes)
Old 01-16-2011, 11:25 PM
freakaftr8's Avatar
Convergence freak!
Yep it's dwawing excessive beam current I believe. I guess I just got used to the way an FJP22 looks. This is the first CYP CRT I have had.
Old 01-17-2011, 12:39 AM
I think the 21CYP22 is definitely less bright overall than an 'FJ or 'FB.
Old 01-17-2011, 03:27 AM
rcaman's Avatar
rcaman rcaman is offline
your cyp will not be as bright as the fjp steve
Old 01-17-2011, 08:08 AM
miniman82's Avatar
First Light: 1952-2011
If it has weak guns, yes. The CYP that came in my '9 is very strong, it gets almost as bright as an FJP does but has better color IMO.
Evolution...
