Old 01-06-2012, 03:20 AM
All the caps tested OK, but I think I found the problem. It turns out it works better if you actually solder all the connections
Now on to the cabinet.
Old 01-06-2012, 08:19 AM
holmesuser01's Avatar
Naah. Just makes for interesting problems later.
Please dont ask how I know this... Vivid memories of an RCA roundie flyback and one missed solder connection and a jumpy width that didnt happen until the entire set was put back together completely... set back and all.
Old 01-06-2012, 03:11 PM
I let the set play for a couple hours and the audio issue has resurfaced. My next thought is that it could be the cap across the audio output transformer breaking down. The original was 600 v and I replaced it with a 630 v. I recall seeing a service note about replacing this cap with a higher voltage one.
Old 01-06-2012, 03:15 PM
Kevin Kuehn's Avatar
Workin' Late Again
That's weird if it's breaking down in that location. How many volts across it?
Old 01-06-2012, 03:28 PM
miniman82's Avatar
First Light: 1952-2011
I always wondered why that particular cap was rated 1000vdc in sets, seems to me it shouldn't have more than about 400v across it at any point in time.
Evolution...
Old 01-06-2012, 04:49 PM
Workin' Late Again
I suppose the audio signal can add to the DC volts, but I'd of never thought the audio signal would be very much for a couple watts TV speaker.
Old 01-06-2012, 04:58 PM
Positive-going back-EMF spikes can get stacked 'on top' of the supply voltage, 'specially if the voice coil were open.
Old 01-06-2012, 05:12 PM
kvflyer kvflyer is offline
This question often comes up. Yes, there are spikes on that capacitor and it should be at least 1000VDC. I know that there are Orange Drops rated at 1600VDC out there. Might be a good thing to have. Also, not having a speaker connected can cause a high reflection of the signal back to the tube. I know this is just a 6V6GT single ended amplifier. But I have seen a few audio amplifiers that had the tube sockets burned. All because of the reflected signal. I don't think that you have to not use it now, but I would get some 1.6KV caps the next time you order some.
Old 01-06-2012, 05:44 PM
Workin' Late Again
How bout a couple double value caps in series?
Old 01-06-2012, 05:56 PM
I imagine that would work too. I do have a few of those orange drop 1600v on hand though. I'll install one later tonight and clean out the tube socket pins too.
I started on the cabinet this afternoon. 55 F and sunny Never expected to be working on an unheated porch in January!
No chips or deep scratches. I'm going to clean it with some mild detergent then buff with Novus #2
The CRT gasket foam is rock hard and crumbling. I'll replace it with some closed cell foam insulation.
Old 01-06-2012, 11:09 PM
I removed the faceplate and cleaned the cabinet with some warm soapy water.
The speaker cloth has faded quite a bit.
I recall someone had asked about the clarity of the faceplate. Here it is before any cleaning. I hope it clears up.
There's some flashing left from the bakelite molding process.
Time to finally lose the caster wheels. Now I can bring it inside.
Old 01-07-2012, 09:48 AM
I removed the faceplate and cleaned the cabinet with some warm soapy water....
Bob,
I see that you were able to remove the nuts that hold the speaker board to the cabinet. What method did you use? I started to take my speaker board out and the nuts didn't want to budge without breaking. Did you pry up on the two "capture" parts in the center of the nut? Did any of yours break?
Bob,
I think it was me that asked about the clarity. I was able to polish the clear faceplate with no problem. But when I look at either one that I have (I have two) in bright light, the clear plastic has sort of a very faint swirl pattern in both of them. I suspect the plastic was about as clear as they could get it but there was still some kind of white swirl in it. Mind you, very faint and it doesn't affect the picture. But I was just interested to see if anyone else noticed it.
And for what it's worth, that foam gasket on mine was as crisp as a 50-year old wedding cake! I didn't replace it yet.
Old 01-07-2012, 09:49 AM
BTW, nice to see this restoration. My chassis is copper plated and the reason I have spare parts is because I bought a 16R12 for parts. Mine was missing the HV cage. I was lucky that both were copper plated.
Nice job as usual!
Old 01-07-2012, 04:14 PM
Looks like some idiot production manager was screaming at the workers to get productivity up. Which usually means the workers have to skip steps to keep the quality decent... So they didn't take the time to remove the flash.
Old 01-07-2012, 04:46 PM
Originally Posted by kvflyer View Post
Bob,
Bob,
I used pliers on the four in the corners. I got a good grip on them and sort of unscrewed them while pulled back.
I tried to pry up the capture teeth with a small screwdriver on the rest, but couldn't manage it. I had to mangle them by bending them with needle nose pliers.
None broke though and I might be able to unbend and reuse them.
I propped it up in front of a window and, yes, it sure does have those swirls.
Here it is after cleaning with warm soapy water and Novus #2. Not much of an improvement. Those swirls are definitely in the plastic and not surface dirt.
LOL - I bet you're right.
