Old 06-26-2015, 05:49 PM
SwizzyMan's Avatar
Restoring an admiral c322
you measure no HV at the CRT anode (or metal 3A3 tube socket housing)?
Yes absolutely nothing
RCA CTC-7 Pensbury (Restored)
RCA CTC-5 Westcott (Restored)
Old 06-26-2015, 05:52 PM
Originally Posted by SwizzyMan View Post
Forgot to mention yes my screwdriver slipped when It broke.
Ok for starters only use plastic or FG tools working around HV cage.
You prob blew the damper, Try a new damper tube.
Old 06-26-2015, 05:56 PM
SwizzyMan's Avatar
By blown you mean the filament is blown? Because it still lights.
Old 06-26-2015, 06:04 PM
SwizzyMan's Avatar
switched the 6au4 with a 6ax4 dont think they are compatible subs
Old 06-26-2015, 06:15 PM
Set off
Remove the horz out tube from the socket.
disconnect the plate lead from the tube.
put a DC volt meter on the plate lead (+) and the neg to chassis.
Set on should be about 400vdc
Old 06-26-2015, 06:20 PM
SwizzyMan's Avatar
Set off
First time I got only 17 volts then all my other attempts were zero
Old 06-26-2015, 06:24 PM
ok now just trace back until you find the 400v
look for burned coils if nothing at the pin 5 of the damper
also make sure you still have B+, if the damper was shorted you may have blown the B+ fuse again.
use the correct fueses.
Old 06-26-2015, 06:25 PM
SwizzyMan's Avatar
What exactly do you mean? check soldering connections and my caps?
Old 06-26-2015, 06:31 PM
check B+ at fuse
SwizzyMan's Avatar
There is a power supply fuse that I mentioned that is blown and I am guessing that MAY be the problem..
do you have the schematic?
Old 06-26-2015, 06:33 PM
if the fuse is blown then that is the problem.
Get the correct fuse put a good damper in and try again.
Old 06-26-2015, 06:35 PM
SwizzyMan's Avatar
That what I was thinking... Thanks so much Dave! Dont know what I would do without you. I will replace the fuse tomorrow and I will hope for the best.
Old 06-30-2015, 07:45 PM
SwizzyMan's Avatar
Got the HV back and was able to acquire a leader lcg-400 fully working for $60. Now I feel as my horizontal and vertical hold have gotten worse with the patterns displayed even though I have recapped both the vertical and the horizontal board... I am also getting barber polling when I turn the color knob all the way up and fine tune. What is wrong here? Do I need to recap the boards or should I recap the main chassis? Here are the pictures http://i.imgur.com/iZtVJZt.jpg http://i.imgur.com/M9VCUjn.jpg http://i.imgur.com/fOMxSXN.jpg
Old 06-30-2015, 08:12 PM
tvcollector's Avatar
Looks like there still could be issues with the vertical.. As for the swirlyness in certain areas of the pic, that could possibly be the Leader pattern generator.. Those things usually need to be recapped to function properly.. I have one also that's a bit touchy.. The convergence is off quite a bit I see..
