Old 07-10-2019, 10:20 AM
ppppenguin's Avatar
I was in touch with them too a few years ago. Ultimately no result. Like Darryl, I don't think they're interested in folk like us.
Old 07-10-2019, 10:48 AM
With a place like that, would you really want to trust them with ultra rare, virtually irreplaceable, roundie CRTs? Given that they have never done them before, and don't even seem to care to try?
Old 07-10-2019, 02:57 PM
NowhereMan 1966's Avatar
Slave to 1 Cat
Originally Posted by tubesrule View Post
I spoke with them extensively back in 2014/15. They claim they are capable of rebuilding anything including Pyrex tubes although never provided evidence of this, and that's as far as it went. They would never commit to anything for any price. They basically had no interest in our community. Perhaps someone else could pickup the torch and try contacting them.
Darryl
Yeah, hopefully by the time when our demand will be higher, the ETF people can take care of us. I guess like with anything else, I'm sure Thomas would do it for the right price, everybody has their price as my father says. The thing is, it depends if we can pay for it. I was always a big believer in "when the door is closed, God (or whomever/whatever you believe in) opens a window" but sometimes opening a window takes action on our part too.
Old 07-20-2019, 01:54 PM
trinescope trinescope is offline
Right now I am trying to deal with the failed vertical convergence transformer. I was not able to get a turns count due to damaged wires, and I gave up after unwinding over 6000 turns of wire which kept breaking due to corrosion. The primary was still good and I was able to get a resistance reading from that winding, but the secondary was open and I don't know a whole lot about it. The wire sizes on both windings measure the same (.003") which corresponds to a 41AWG wire. Knowing the wire resistance, winding resistance, and the approximate turns per foot of wire I get 2000 turns for the primary which would seem about right. Unfortunately the secondary resistance measurements given on the Westinghouse schematic are incorrect. Since the Sams folder on this model gives an RCA part number for this transformer as being the same as that used in the CT-100, I looked at that schematic and found very different resistance measurements as well as in the Sams folder on this set. I'm really not sure what to go with here. Also, the ratio on the secondary winding either side of the tap doesn't jive with what I know about the AC voltage requirements given on the 15GP22 datasheet. The datasheet gives a convergence/focus voltage ratio of 900:225, or 4:1, but the transformer looks more like 2.5:1 based on the resistance readings given.
Erich Loepke
Old 07-20-2019, 03:09 PM
Have you tried contacting Steve McVoy, who possibly could lead you to someone who has done this before and knows the turn count?
Old 07-20-2019, 03:26 PM
John Folsom and John Yurkon come to mind.
Old 07-24-2019, 08:11 AM
While waiting for information on the convergence transformer data I decided to do the IF and chroma alignment. The video/chroma was pretty close as-is with just a little adjustment needed. The IF is a different story, however. It had a narrow peak instead of the double hump broadband response shown in the service data. I was having problems with the cores sticking in the IF transformers and I ended up twisting the coil form in the second IF can. I had to remove the transformer and get the cores out and do the surgery on the broken wires. As of this morning I have the repaired transformer installed but not connected. The third and fourth transformers will have to have the cans removed so I can remove the metal clips that engage the cores and try to get them back into their places.
The marker in the center of the scope screen is 44MHz.
The second shot is the chroma response to the demodulator input and is pretty close to what is called for in the service information.
Erich Loepke
Old 07-24-2019, 03:19 PM
ohohyodafarted's Avatar
Bob Galanter
Here are the DC resistances of the vertical convergence transformer. These readingx are taken directly from a known good trans that I removed from my CT100 and replaced with one of the replacement transformers that Folsom had for sale back in the day. The original has been sitting on my shelf for about 10 years because I am saving it in case of a failure in one of my 15" color sets.
The resistance of the primary is 1060 ohms.
The secondary is 20,300 ohms center tap to one end.
and 8700 ohms center tap to the other end
with an overall end to end resistance of 29,000 ohms.
That equates to about 27,645 feet (5.23 miles) of #40 wire on the secondary at 1049 ohms per 1000 feet of wire.
Hope this helps in your winding effort in the event you are unable to obtain a replacement.
Good Luck!
ME http://AntiqueTvGuy.com
Old 07-24-2019, 05:40 PM
Good Luck!
Thanks much for the information. I guess the Westinghouse and RCA transformers, although functionally equivalent, are actually constructed differently. Looking at the ad on the ETF website for the reproduction transformers, it says that 41 and 43AWG wires are used in the windings. My transformer had only 41AWG wire in both primary and secondary. The scan of the Sams folder for the Westinghouse shows secondary resistance readings of 3800 and 9200 ohms (although the scan is fuzzy in that area, so that's a best guess) whereas the RCA part as you measured is 8700 and 20300 ohms, respectively. The primary resistances are just about equal, however. My educated guess is the RCA part uses 43AWG wire on the secondary. 41AWG wire is about 1320 ohms/Kft and 43AWG is about 2140 ohms/Kft, quite a bit of difference. Using best guess turns per foot based on the location of the windings the primary is 2000 turns of 41AWG, and the secondary is 8700 + 17000 turns of 43AWG. For the Westinghouse part I get 2000 turns of 41AWG and 5750 + 12500 turns of 41AWG. Using the same insulation thickness the overall winding dimensions are roughly equal and just about fit in the E laminations.
The overall primary/secondary ratio looks to be different between these two if my assumptions and calculations are correct, but the tapped secondary ratios are nearly the same.
I don't know if I want to attempt this on my own or see if maybe Edcor or some other transformer company could produce this.
Erich Loepke
Old 07-24-2019, 05:58 PM
If you order them from a professional transformer company I'd be interested in 1-2 vertical transformers.
If John Folsom was ordering the reproductions from a reputable firm he may have proven exact specs from the company that you can use.
Old 07-25-2019, 08:54 AM
Bob Galanter
Forget about the resistance numbers on the Westy schematic. They are wrong. The correct numbers are on the CT100 Sams schematic. I have no first hand knowledge of the correct wire gauges, but I would go with the numbers on the ETF ad for Folsoms trans. What do you come up with when you measure the actual wire from your trans?
Old 07-25-2019, 10:06 AM
Yeah, I know the Westinghouse schematic numbers are wrong (1350 ohms for the secondary IIRC). Since the CT-100 part looks like it works in this set as well I'll go with the numbers I get based off of your information. I did measure a 1 foot piece of wire and got 1.3 ohms which corresponds with the 1320 or so ohms per 1000 feet of 41AWG. 43AWG should have been more like 2.1 ohms per foot. That's why I believe the parts were made differently.
My secondaries were open so I didn't have the benefit of getting a resistance reading off of the original part.
Erich Loepke
Old 07-25-2019, 08:40 PM
I was finally able to do the IF alignment after dealing with stuck and chipped cores and two transformers with broken wires. I think I got a pretty passable response after a lot of iteration. Hopefully the color will look and sync better now. I will need to order more capacitors so I can replace the remaining paper wax capacitors still being used. Also I will need to check out the horizontal oscillator since it starts becoming flaky after being on for a while, shifting frequency a bit then back again. I need to build a 3.58MHz crystal oscillator for aligning the demodulator section. That way I should be able to set up the 90 degree phase shift using a dual trace scope and be sure it's correct before installing the CRT to the chassis. That is the pain in the rear about this set... the CRT has to be removed from the chassis to do much of anything with it beyond normal adjustments.
Erich Loepke
Old 08-08-2019, 01:24 PM
Looks like I'm on my own as far as the convergence transformer goes, so I ordered one of those Chinese automatic coil winders and some 41AWG wire. This should make it easier to get a nice, tight, even wind and if the transformer ends up not working for some reason I can try again fairly easily. I'll first try winding the primary and see how close to 1000 ohms I get for winding resistance. That's a few days off right now. I also need to order more .1uF capacitors, and I will also get a 3.58MHz crystal oscillator for chroma demodulator alignment. My work area is in the garage, and with this 100 degree weather I'm not really doing much now.
Erich Loepke
Old 08-08-2019, 01:31 PM
I wish you success with the attempt.
