Old 09-10-2019, 09:48 AM
Originally Posted by static1701 View Post
Yes, it is a 5J6, I pulled all the tubes the other day and tested them. That three piece chassis is really strange.. in all the prints I have looked at I can't find it anywhere. Thank you again for trying to find this...
With the 5J6, it's probably a 21mc IF. The 41mc tuners used different tubes.
The Admirals of the day were strange in that respect. The VHF only sets were 21mc, where the UHF/VHF models were 41mc.
Old 09-10-2019, 10:03 AM
I was not sure what the orange thing was because it is tapped in the center. Tim, thank you for the info. Getting closer to figuring it out.
The tap (if there is only one) means it is a dual diode. Some selenium's had several taps and acted as several diodes.
Old 09-10-2019, 06:29 PM
Tim's Avatar
Tim Tim is offline
I don't see the power transformer. What numbers are printed on or stamped into it?
Tim
Old 09-10-2019, 07:20 PM
static1701's Avatar
static1701 static1701 is offline
No power transformer. Series wired setup. It has a small transformer on the back side of the selenium rectifier, the vertical transformer and the audio transformer.
Old 09-14-2019, 09:50 AM
static1701's Avatar
Thanks to RonL, the Television is a Canadian 1957 chassis # 1621
With the information he provided, I should be able to get it going.
Old 09-14-2019, 11:23 AM
static1701's Avatar
RonL: Does your book have any other prints? The 2 that you sent don't show the connections for every connection on the tube sockets. This resistors I need to replace are not listed. I think someone replaced the 12DQ6 with a 12BQ6, because the print matches everything else.
I looked at the sam's print for that model and it is similar, but not exact. Hopefully between the 2 prints I can figure out what parts I need
I usually fix tube amps, I have done a few tv's but mainly just swapping caps. This one is going to need a lot more to get it going but it will be great when it is done.
Thank you to everyone for helping out.
Old 09-14-2019, 06:28 PM
ronl ronl is offline
Hi static.thats all the info I have.my guess is the other connections are used for tie points.this was common in the tube point to point sets.RonL
