Old 10-12-2019, 08:10 PM
static1701's Avatar
static1701 static1701 is offline
Got deflection!
I replaced the replacement caps in the vertical section and I have deflection!!!
It rolls a bit but it is working. Super happy to have gotten this far.
Old 10-15-2019, 07:41 PM
static1701's Avatar
Need some help, I have replaced all the caps and resistors in the video and horizontal sections but I can’t get a stable horizontal lock. It wants to pull to the right. Adjusting the contrast affects it as well.
Old 10-15-2019, 10:58 PM
The horizontal AFC diode pack may be bad.
Old 10-16-2019, 09:02 AM
static1701's Avatar
What values are they? I am guessing I will have to make something.
Thanks,
Scott
Old 10-16-2019, 09:30 AM
The schematic should at a minimum give you a part number you can search a data sheet for.
Usually the original was a 2 diodes Ina 3 leg package.
You want a replacement with the same or greater Piv and forward current ratings and a fairly fast switching time. Most will favor shotkey diodes for their fast switching time and the broader horizontal locking range they give, but you can often get away with 1n4007s especially if you need a quick temporary sub to confirm the original is bad.
Old 10-16-2019, 02:16 PM
static1701's Avatar
Thank you!!!!!!!!!!!!!!!
I replaced the 34-8037 (D1) with a couple of Shotkey diodes I had left over from another project and I can get a reasonable stable lock now. It wiggles a little bit but over all it is stable. I am guessing the diodes I have are not the right ones.
Video: https://youtu.be/zOQZrGYF7d0
Old 10-16-2019, 02:59 PM
You do have them connected common-cathode (banded end to banded end), right?
Old 10-16-2019, 03:04 PM
static1701's Avatar
Yes, just attached to test clips for now.
Old 10-16-2019, 05:42 PM
Is the old dual diode out of circuit?
Old 10-16-2019, 06:08 PM
static1701's Avatar
Yes, I changed to some different fast diodes and the picture was rock solid. But I don't think they can handle to power, the set has reverted to rolling a bit and the picture is not centered. I will need to get the correct replacement.
The picture is from when I just tried the fast diodes.
Old 10-16-2019, 07:09 PM
static1701's Avatar
Figured it out:
One of the legs of the N5 broke loose. Re-soldered it and everything is fine.
Old 10-17-2019, 06:33 AM
kvflyer kvflyer is offline
Originally Posted by static1701 View Post
Figured it out:
Old 10-17-2019, 05:08 PM
static1701's Avatar
I finished replacing all the resistors on the main
Board. I have a buzzing in the sound when txt is on the screen. Going to work on the IF board next.
File Type: jpg D3A3AA3E-BC47-4961-A790-EF37F3C37C10.jpg (117.1 KB, 22 views)
File Type: jpg 0CFE8F02-9D65-4573-A4DF-7F043A4B4299.jpg (103.6 KB, 20 views)
File Type: jpg CE95B0C2-2372-493D-BAEC-27154D0C052A.jpg (106.7 KB, 23 views)
Old 10-20-2019, 06:23 PM
static1701's Avatar
I replaced the resistors on the IF board, the set works very well. I am happy with it, so I am not going to mess with anything else. I still need to buff out the scratches in the safety glass and get the rust off the stand. Over all, it was by far the hardest set I have repaired. Thank you to everyone that helped me get it working.
File Type: jpg 74239267_10214583465332117_6522083369994420224_n.jpg (93.8 KB, 24 views)
Old 10-23-2019, 03:10 PM
static1701's Avatar
I was going to let it be, but I brought it in the house and the buzz that it does when text is on the screen is a pain. It is minimal but I would like to resolve it. What causes that?
