Old 03-01-2021, 02:35 PM
recepteur recepteur is offline
I wouldn't want to advise you on using a scope considering the voltages present.
As an alternative, I would do this - take a cap of .1 uf or higher, and jump it from pin 5 to ground and see if it kills the blip. Then from pin 9 to ground and see. Try the cathode too for the heck of it (pin 2).
But as a precaution, first measure voltage on the pins to be sure it doesn't exceed the cap's voltage rating.
old_coot88,
Will do. !
Thanks
Cheers
Old 03-01-2021, 04:12 PM
Caution! I believe the CRT except for cathode and G1 are all floating on the high voltage (thousands? of volts).
If you have a spare replacement .005 cap for C54/C55, that could work to protect your scope, as it has the required voltage rating for whatever is on the CRT.
Old 03-01-2021, 04:16 PM
A similar Admiral schematic
https://www.earlytelevision.org/pdf/..._rider_tv3.pdf
lists C54/c55 as .005 mfd, 6000 volts.
