Old 08-14-2021, 08:26 PM
Originally Posted by vortalexfan View Post
OK, so then the power transformer should be able to swap out for each other, the only other issue I could see being a problem is the mounting screw hole spacing for the power transformer from the Philco radio vs. the the GE's original Power Transformer.
You might have to drill different holes to match the footprint of the replacement transformer. The original transformer is mounted a little different, with long through bolts, so it sits above the chassis.
Old 08-24-2021, 08:17 PM
Well a little update, apparently the power transformer wasn't the problem, it was the power switch on the volume control I subbed in, apparently the power switch was bad...? because I put the original volume control and power switch back into the radio last night and the radio popped right on as soon as I powered it on... Weird, I didn't know those power switches could go bad like that.
Unfortunately that persistant and untraceable hum is still there and I still cannot figure out where its coming from.
Old 08-27-2021, 06:44 AM
Well for sure something's not right with this radio because the back of the radio says it's rated for 65 watts at 120 and the radio as it sits with its incessant 60 Hz hum is only 43 Watts so something's not right, either one of my filter caps failed or there's a bad tube or something else odd is going on with this radio.
I've tested all of the tubes in this radio and the 6K7 tube and the 6F6 tube both tested as having a H-K Short in it so I subbed them out with known good tubes and the hum is still there and the radio pulled the same amount of wattage, So I'm not sure what's going on with this mystery of a radio.
I'm about tempted to just salvage the bulb and tubes and capacitors out of the radio and scrap it out.
Old 08-27-2021, 12:02 PM
It depends what condition the cabinet is in! If the cabinet is in good condition, it's worth trouble-shooting a little further!
Remove all the tubes but the 6F6 and the rectifier and see if it still hums, proving it's a power supply issue. If so, bridge the electrolytics and see if it clears the hum. The power supply is a rather simple supply using a grounded B minus.
Old 08-27-2021, 03:39 PM
The Cabinet is actually in pretty decent shape yet, but I did try what you suggested last night before I even saw that you suggested it, and it still has a hum, actually the hum got worse when all but the 6F6 and the 5Z4 were removed from the chassis.
I didn't try bridging the electrolytics yet, but I'm not sure what you mean by that, do you want me to bridge all of the ground connections from the electrolytics?
If so I'm not sure how I would go about doing that seeing as all of them are grounded to the chassis in some way, shape, or form so they should technically already be bridged, seeing as the chassis is the common ground in this case.
Old 08-27-2021, 04:29 PM
Bridging simply means "connect in parallel with", using a pair of clip leads. So bridge (jumper) each individual electrolytic (one at a time) with a single unit of equivalent or higher ratings. Note correct polarity.
The caps in question would be C19 and C20 (main power supply filters). You could jumper each with something like a 20mf 450V unit and see if it affects the hum.
EDIT. Those two caps should be replaced as a matter of course anyway. If they're the original cans they could be left in place for aesthetics, but out of circuit. There's also C26, a low voltage electrolytic across the cathode resistor of the 6F6. It won't cause a hum problem, but will cause reduced volume if it's gone open. It should be replaced anyway.
Old 08-28-2021, 10:57 AM
Its already been done, none of the electrolytics in the radio are original to the set, that was the first thing I did when I got this set, was replace the old electrolytics, which I left the old cans in place for aesthetics and wired in some new electrolytics which I installed onto some isolated terminal strips that I soldered ontop of the old electrolytic can's positive terminal (the terminal strip's attachment lug was isolated from the terminals so the original cans are still out of the circuit but are being used as an attachment point for the terminal strip for the new electrolytics without affecting the circuit, its a trick I learned from Mr. Carlson's Lab.)
I checked the capacitors that I installed in the radio and they still test good yet on my ESR Meter, (they mesured about 4-6 ohms ESR and they both are 2 4.7 MFD 450V axial lead electrolytics paralleled together to make 10 MFD at 450V).
And then the low voltage electrolytic is a 10/10 @ 160V Firecracker type electrolytic cap like the original was, and that one tests fine as well.
So unless one of these caps failed in a manner I'm not aware of, or that the ESR meter wasn't able to detect (dead shorted) then I don't think the electrolytics are to blame here.
Old 08-28-2021, 11:41 AM
Remove the rectifier tube and check the HV windings on pins 4&6. Should be around 600 volts AC or 300 volts from either 4 or 6 to ground. If it seems to be in order, replace the 5Z4 with a 5Y3. Maybe the 5Z4 got damaged!
I would leave the 5Y3 in there! I don't trust the old-time metal rectifiers!
Old 08-28-2021, 12:48 PM
If the negative of the can is grounded you could alternately solder the terminal strip to the chassis so the mount lug of the strip can be used for a negative terminal...you need a powerful iron to do it that way but it can clean things up a bit in some cases.
Old 08-28-2021, 01:49 PM
With an ohmmeter set to RX1, be sure the negative ends of C19 and C20 are securely grounded (zero ohms) to chassis. Any resistance here would definitely produce ripple in the B+.
Old 08-31-2021, 12:07 PM
OK, so a little update with this radio:
I changed out the 5Z4 for a 5Y3G tube and installed a 6V6G tube into the radio and the hum has gone away, but a new issue as arisen, whenever I touch the chassis anywhere including the knobs or ground my signal generator to the chassis, the radio goes completely silent.
But then when I remove my hand or the signal generator ground clip from the chassis or from any of the knobs, the radio comes to life.
Is it because with this radio being made to utilize the metal tubes they had one of the heater pins grounded to the shield pin of those tubes and thus to the chassis?
If so should I go and unground those heater pins to make this radio work with more modern glass tubes?
Old 08-31-2021, 01:49 PM
Well I got it working, unfortunately it has to be turned up full blast in order to hear anything on it, which is what you guys warned me about with this unit because of its lack of AVC circuitry, the hum is still there but its not nearly as bad as it was, in fact when I turn the volume up all the way the hum goes away.
Unfortunately I couldn't tell how good the reception was on it because my housemate (who caught covid from his dad) had his desktop computer running (which is a high end gaming desktop) which has a super noisy power supply which basically renders AM Radio useless in my house, it just sounds like a a bunch of hash noise, across the whole dial with one local station that manages to break through the noise, the weird thing is that the noise seems to be not only on the AC line but also radiated through the air because even my battery radios are affected by the noise...
Old 08-31-2021, 02:05 PM
PCs with plexiglass view windows tend to radiate RF noise as as do many cheap power supplies. When I built my PC I went with a full metal case and a Bequiet brand power supply which doesn't seem to emit any noise to hamper radio or TV reception in the slightest.
Old 08-31-2021, 05:26 PM
That's weird because I have a completely metal case on my computer I have now and it has a fairly expensive looking power supply in it and mine is pretty noisy, compared to my old computer which was a see through case and had a medium priced power supply and it hardly radiated any RF Noise, and then my housemate's computer is also an all metal case and I'm pretty sure he had a higher end power supply installed in it, but his computer is noisy RF wise, so I'm not sure what to say about that.
Old 08-31-2021, 06:24 PM
Just because you paid a lot for a power supply doesn't mean you're not buying a cheap crappy one with a highway robbery markup... Overpriced crap exists in every market.
