Old 04-22-2022, 10:16 AM
Another thing noticed of the differences between the chassis shown in the combo unit listed in the SAMs, and what I have in reality, the SAMs combo has a 45.75MHZ IF, but this one has 25.5. Even though both seem to be dated 1953.
Went over all resistors in the IF and found only 4 that were really bad, 40% over, not replaced yet, will do tonight.
Cleaned tuner and tried to tune in signal from TV pattern generator with sweep disabled, was able to see SOMETHING trying to come in on video output, but with the IF & tuner tubes in an unknown state, ( NOS ones ordered ) it's hard to tell, also w/o sweep, AGC is not working, leaving the front end a bit deaf, I'll have to see when I get the big CRT back in it, and all sweep up safely if the tuning perks up.
Old 04-22-2022, 01:43 PM
In the mid 50s some brands (Admiral was notorious for this) used BOTH IF frequencies on the same chassis and which one you got depended on whether the set was optioned with UHF (the 45MHz IF models) or not. Sam's typically bought one specimen and usually got all the options so they could document all the optional equipment.
Old 04-22-2022, 03:07 PM
I just seem to have a weird combo unit, or one that was not seen exactly by SAMs, the one they cover has a 199 chassis, but mine has a 192.
And as mentioned, the 192 version is in a separate folder, NONE of which list the RCA 21FP4D as the CRT, leading me to think it has been replaced at one time.
Luck, I guess?
Old 04-22-2022, 11:49 PM
MAJOR LEAP AHEAD!
https://i.imgur.com/Po94lAa.jpg
Old 04-23-2022, 01:33 PM
VIDEO TIME!
https://www.youtube.com/watch?v=2jTC83TOeRY
Old 04-25-2022, 09:19 PM
Now with Sound!
https://www.youtube.com/watch?v=6abTcMTjmxk
I see an IF alignment in Its future!
Old 04-28-2022, 10:02 AM
So, next step with this is I guess is to bring up the severely damaged radio section.
The TV section has run OK for a while with no major problems and seems to be stable, aside from the slight video smearing / ringing that changes with fine tuning, this I hope to improve with IF alignment.
But, as before, having no sweep marker generator and just a digital RF function generator, I can only do the general MIN/MAX adjustments, and not the overall video IF response check where the response curve is plotted.
But I'm hoping to get SOME improvement with the VOM method, I just wish one did not have to remove the CRT to do it, but there is just no way to get to the coils with it in, it's almost, but not quite impossible take the IF tubes in/out with the CRT in, the spacing is so tight!
As for the Radio, as mentioned, I will be using the very old Sansui P-130 power transformer I have, to replace the burned original, of which I can find no info online, but it seems close to use voltage wise.
I have decided NOT TO wire in the damaged 5u4gb area, I will leave it bypassed, but may wire up the heaters only.
In its place I will use a pair of BYV26E-TR diodes, this obviously will raise the bias a bit, and thus have to raise R160 candohm resistor's replacement (500 ohms) till the bias is in the right range.
Old 04-28-2022, 10:54 AM
I know what you mean about tight spacing around tubes in old TVs. I had a few sets like that, years ago, such as a Philco console in which some of the tubes were located almost directly below the CRT bell, with the chassis in the cabinet, not to mention portables with very small cabinets. How these tubes survived, being just a few inches below the CRT, not to mention escaping interference from the charge on the bell, is beyond me, although the TV did seem to work normally. Why my Philco TV was designed as it was, being a console, however, is beyond me as well, since there seemed to be more than enough space inside the cabinet to keep the tubes, every one of them, spaced well apart from one another. I can see tight tube spacing in small portable TVs, but for crying out loud, not in a 21-inch console. As I said, how the tubes which were just under (!) the CRT escaped interference is more than I will ever know at this point.
That Philco TV worked great once I did get it working, but unfortunately the CRT socket eventually came unglued, all but forcing me to remove the socket and hard-wire the signal leads from the TV chassis to the bare wires from the CRT neck. The TV worked for some time after that, though I'm darned if I know why it worked as well as it did; however, one day one of the wires broke off, leaving only a very short stub, impossible to solder to. Even if the stub had been long enough to solder a wire to, I would have been afraid to do it for fear of cracking the glass around the base (actually, the end of the CRT neck, as I had removed the tube base altogether), or worse.
BTW, I'm glad you are making progress with your TV, and have gotten it working fairly well. I hope you can get the radio working as well without too much trouble, although I wonder about the power transformer you will be using with the latter. How old is that transformer? If it is more than a few years old, I would be concerned about the condition of the windings; after all, if the transformer is vely old (say 20 years or more), the insulation on the windings may be crumbling and could cause a serious short inside the transformer. I would test the transformer before installing it, just to be safe. As well as your restoration project seems to be progressing, it would be a crying shame if the transformer would short and burn up some or all of the wiring under the chassis, if the set's line fuse doesn't blow first.
Old 04-28-2022, 10:12 PM
https://i.imgur.com/4Mu1RTy.jpg
mostly cleaned chassis many burned wires still.
Sansui trans installed.
https://i.imgur.com/Oyh9YoN.jpg
https://i.imgur.com/gpt7k44.jpg
Old 04-29-2022, 01:40 PM
Been thinking about how to mod the PWS in the radio, but truth is, until I try, I wont really know for sure how it will behave.
The Sansui p-130 transformer has a bias out of 350ac vs the orig 340ac, and the BYV26E-TR diodes have forward voltage of 2.5v vs the 40ish of the 5u4gb, the SAMs shows the rectified voltage was 390v originally, this will jump up quite a bit, however, rather than having the xformer center tap direct to gnd, I will stick in a 200 ohm 20 watt, and the first candohm resistor has been changed from 500 to 600 ohms.
Will just have to play with it and see what happens.
Old 04-29-2022, 02:07 PM
Why not use the 300 volt taps on the hv (350V) secondary? Might work about right with the reduced ss diode forward drop.
Old 04-29-2022, 02:27 PM
did not think about it that way, it my work with the original resistor setup.
will try.
Old 04-30-2022, 01:37 AM
https://i.imgur.com/qyliiDl.jpg
primary and heater strings hooked up!
we now have glow!
I did find a bad 6V6GT, did not light up but got hot.
not sure if it was the cause of the x-former burn out or symptom of cascade of problems that were in a chain of problems.
Old 05-04-2022, 07:59 PM
the Radio lives!
https://www.youtube.com/watch?v=IGG5g1z25Dk
Mostly!
AM/FM is very weak, I was working to get the amp working mostly.
have not looked for bad resistors yet, there are no doubt bad ones in the IF as always...
Old 05-04-2022, 09:14 PM
If there's an AM loop antenna in the cabinet it may need it to perform good on AM...FM also may benefit from an antenna but it usually doesn't need that much wire to make FM happy.
