Old 02-18-2023, 07:34 PM
pac.attack76's Avatar
Stuck in the past
I can't find a replacement. I'm assuming it's 1-684-698-13.
Genesis does what Nintendon't
Old 03-10-2023, 04:51 PM
Stuck in the past
Got the board out. Had it checked by someone. He went over the bottom and hit a few places that looked questionable. I don't have the proper iron for this. I put it back in and tried it and now it doesn't start up. It just clicks, blinks led 3 times then clicks again.
Old 03-16-2023, 10:23 PM
Stuck in the past
On the very first attempt, it's sounds like it's gonna turn on. Probably the sound of the degauss. Any attempt after that is just one relay, 3 red led blinks, then another relay. Nothing else. Not even static on the screen when you touch it like you'd get if it turned on.
Old 03-17-2023, 09:27 AM
JohnCT's Avatar
JohnCT JohnCT is offline
With the TV unplugged, go the horiz output and measure resistance from collector to emitter. It should be virtually open. A short means the transistor is bad.
If there's no short, measure the voltage on that transistor from collector to emitter - it should be over 100VDC. If that's missing, you work back toward the regulator. If that voltage is there, we work on the horizontal drive.
Is there a schematic on-line?
Old 03-17-2023, 09:28 AM
Stuck in the past
I downloaded the pdf of the service manual. Would u be able to show me on the manual where I need to test? I'm not familiar with emitters and collectors. My 30 years with self learning is limited. I tried sharing it on her but it's like 15 mb.
https://www.manualslib.com/manual/85...v-32hs510.html
Old 04-03-2023, 09:15 AM
Stuck in the past
Do I need to leave the board in to do this or can I take it out?
Old 04-20-2023, 07:16 PM
Stuck in the past
I've given up on this one.
Old 04-21-2023, 08:41 AM
JohnCT's Avatar
Board in if you can get to the test points - out if you need swing room.
Have you measured the voltage at the collector of the horiz out?
Old 04-21-2023, 08:43 AM
Stuck in the past
Naw, even if I did get it to turn on again, I'd be back to replacing all the caps for the vide. Apparently these sets aren't so good for old games because there's some sort of lag.
