Old 06-22-2024, 08:02 AM
fumplet fumplet is offline
admiral 24c15 with 20b1 chassis attempt at restore
Recapped powersupply section separate chassis and thought Id see if it had life by variac. Absolutely nothing. My shaver cheater cord is making contact and power switch working. Thought Id check fuses and discovered holder for both fuses was/is/ in the process of failing. Hunting for screws/nuts to fix this then see if tubes light.
Fixed fuse block with screws and nuts. Now power supply tubes light up but tv chassis filaments seem to be not lighting. dont know yet if this is a series string tube chassis. power supply does have a 6k6 instead of a 6v6 tube in it. Not sure thats good for testing or not.
