Old 10-03-2006, 03:52 AM
oldeurope oldeurope is offline
Smile
Originally Posted by wa2ise
The above Mexican schemes only have 2 signals, roughly a red signal, and the 2nd is a cyan signal. No luma only. Thus you can never get true RGB from just that.
Don't agree , if you are able to delay a frame, it is possible .
The mexican system uses two colours because the picture is double
interlaced. If you have a tripple interlace it can make RGB . The problem
here is colour flicker . Today this could be solved with frame stroe devices,
this causes of course artefacts in quick moving colours... and this makes
it all complicated .
The advantage of the described mexican colour is that it is very easy.
For example it can be recorded on a B&W vcr without any modificationes .
If you watch some old colour recordings, with its bad noisy colour, I think
the mexican system gives the better results here.
Kind regards,
Darius
Old 09-13-2008, 03:14 PM
I discovered a film on youtube about Gonzales Camarena. Unfortunately, I do not understand Spanish, so I mainly picked up references to things I already know. If comeone can summarize in English, it would be very much appreciated!
http://www.youtube.com/watch?v=FLfUE...eature=related
It starts with discussion of Baird and Farnsworth. It does show use of color filters and a wheel. It also has some reference to Chicago, which was very unexpected! Could someone at least summarize that part in English?
