Old 10-24-2010, 04:30 PM
Strange - I've never had shellac go bad. I've been using the Zinsser brand. I prefer it to lacquer for grain and minor ding filling as it seems to shrink less over time. Then I use Deft Sanding Sealer over that.
Speaking of which, I made some good progress on the cabinet this weekend. The weather has been very cooperative - 70F today.
After the sanding sealer, I used a couple light coats of Mohawk Van Dyke Walnut on the old veneer and three coats on the new veneer which was a little lighter.
Then 3 coats of Deft Gloss. Once that cures, I'll sand it lightly and put on another 3 coats.
I also polished up the rest of the lower portion of the control panel.
I'm not sure about the burnished top section though. I tried some Simichrome on it and it does look better, but it's a little splotchy
Old 10-24-2010, 07:31 PM
Reece's Avatar
Reece Reece is offline
Wow, that's turning out beautiful, Bob.
Reece
Old 10-25-2010, 08:09 AM
M3-SRT8's Avatar
M3-SRT8 M3-SRT8 is offline
Hey, Bob.
Don't worry about the red paint in the brass bezel lifting or crazing when you clear coat it. It's so dried out it doesn't matter if it was lacquer or enamel. The clear coat shouldn't react to it.
...and even if it does (highly unlikely) you could squeegee in water based red paint AFTER a lacquer clear coat. I did this with my GE 805 brass escutcheon, and the fresh red paint really made it pop. Wait until the clear lacquer hard dries.
To tell you the truth, I would buff the hell out of the shiny portion, mask it off with a rubberized tape, then lightly glass bead the matte section for a uniform finish. Use fine bead and light pressure. Clear coat the entire brass, let hard dry for a week, and fill in lettering with red paint.
Tamiya Color Flat Red XF-7 is a perfect match for that shade of red, BTW. It's water based, and won't react with the lacquer. Available at good hobby shops...
Old 10-26-2010, 09:15 PM
kvflyer kvflyer is offline
Hi Bob,
Well, I picked a GE 810 and a Philco 49-1040 tonight. So I will continue to follow this thread and the Philco 49-1040 thread with great interest! Nice work so far. I hope I can do as well.
Old 10-26-2010, 09:22 PM
Now that's a bizarre coincidence! Did you have your choice of sets or were those the only two ?
Thanks! I just have the front frame left to do.
Originally Posted by M3-SRT8 View Post
... lightly glass bead the matte section...
Thanks for the great suggestions Lee. I don't have access to a bead blaster right now, but someday...
I did manage to make more progress using brass polish. Not too bad I think.
After a bit more polishing, I'll take a chance with some Mohawk lacquer specially formulated for brass.
Old 10-27-2010, 05:47 AM
cwmoser's Avatar
cwmoser cwmoser is offline
Beautiful restoration. I was admiring the front panel before photo you earlier posted and the after photo above -- its striking improvement in appearance. BTW, where did you get the speaker cloth?
Carl
PS: I enjoy the detailed explanations. Keep them coming.
CW
Old 10-27-2010, 08:41 AM
Now that's a bizarre coincidence! Did you have your choice of sets or were those the only two ?...
Actually, the gentleman went to our local club meeting and purchased them and other sets. No one wanted TV sets. I didn't make it home from Louisiana in time for the meeting.
So I bought those two and a Motorola VT-71 with Channel 1. Now, I have 5 VT-71 sets and I have restored one of them.
Unfortunately, I won't have time to work on any of the sets for several weeks, maybe months. Lots going on with the family and friends.
Old 11-01-2010, 08:43 PM
I'm just about done recapping
This one has me a little puzzled though. The parts list calls for a 0.0022 (2200pF) paper cap. What I found is this sangamo cap. It does appear to be 2200, but I'm not sure about the composition.
Micamold or real mica and what do the two green dots mean ?
Old 11-01-2010, 09:34 PM
Big Dave's Avatar
Big Dave Big Dave is offline
Dead from the neck up
2200pf... it's a micamold. Get it out of there.
The world's worst TV restoration site on the entire intranoot and damn proud of it.
http://evilfurnaceman.tripod.com/tvsite
Old 11-01-2010, 09:46 PM
miniman82's Avatar
First Light: 1952-2011
And the 2 below it as well.
edit: all 4.
Evolution...
Old 11-01-2010, 09:56 PM
OK, thanks. I'll use a 0.0022 poly cap.
This is an old reference photo from before I started working on it. All the other caps have been replaced
Old 11-01-2010, 10:18 PM
I wouldn't change that one at all, pretty sure it's Mica, it may have some stability issues if you replace it with Poly.
If I read this chart correctly the first Red dot indicates it a JAN Mica Capacitor,
Red, Black, are the first two digits and Brown is the Multiplier. Teh left side green dot is the voltage, 500v.
Here are a couple charts explaining the dot codes.
http://www.tpub.com/neets/book2/3g.htm
I've run into problems before replacing the square molded caps with regular Polys, even if they are paper there is probably something special about them, temperature, tolerance or whatever.
Old 11-01-2010, 10:43 PM
jeyurkon's Avatar
jeyurkon jeyurkon is offline
I'm guessing it really is molded paper. I had a few of these I've replaced. I think the middle green dot means +-5%. The left dot might mean 500V, or it might be a temperature characteristic.
What do they list fo the voltage rating in the parts list? Time passes... Well I just looked it up in the Riders and I think I bet wrong. The one I see listed there is a Mica like Eric said.
Old 11-01-2010, 11:45 PM
Hmm. Eric's linked chart results in a 200 pF cap doesn't it ?
It's C47 in Riders. It's listed as a 0.002 mfd 600v paper cap.
It appears to be a coupling cap between the Clipper and AFC circuits.
They also list C30 and C78 as the same type. Those were tubular paper & paper caps and I replaced them with poly. Heck C78 was even connected to the same tube right next to it. I can't find any evidence that C47 was ever replaced. So why would they use different type caps unless it was important ?
I'll just leave it alone for now.
Old 11-02-2010, 12:57 PM
jeyurkon's Avatar
Guess it doesn't quite fit the standard paper mold. I would interpret it as paper 2200pF, 600Volt and 5% using the colors, but guessing on the order of the dots.
It's strage that none of us have found a catalog or the like that explain these oddballs.
