Old 04-29-2012, 02:35 PM
It's a video monitor.
http://antiqueradio.org/art/RCATM-10...ockDiagram.jpg
Phil
Old 06-18-2012, 07:07 PM
miniman82's Avatar
First Light: 1952-2011
Update? Phil must be busy!
Evolution...
Old 04-01-2013, 01:57 PM
Working even more slowly than my usual snail's pace, I have begun replacing electrolytics & whatnot in the TM-10 monitor. In the service manual, someone penciled in a little modification to the power supply:
http://antiqueradio.org/art/RCA_TM-10_P-S_Mod.jpg
The mod would add two 7-ohm, 25-watt resistors in series with the selenium rectifiers, presumably to reduce surge on startup.
I'm debating whether to substitute something like CL-60 thermistors for the resistors. If you have an opinion on that, vote early and vote often.
I have begun an article about the restoration. Obviously, there will be much more to come.
http://antiqueradio.org/RCA_TM-10_15GP22_Monitor.htm
Regards,
Phil's Old Radios
Old 04-01-2013, 04:33 PM
miniman82's Avatar
Any chance you can copy the mounts and ball bearings of those wand magnets? Not sure, but I seem to recall that the prototype needs a couple of those.
Evolution...
Old 04-01-2013, 09:39 PM
Making exact copies would take metalworking equipment that I don't own. Here are some photos that give an idea how they work.
http://antiqueradio.org/art/RCA_TM-10_Convergence01.jpg
http://antiqueradio.org/art/RCA_TM-10_Convergence02.jpg
http://antiqueradio.org/art/RCA_TM-10_Convergence04.jpg
http://antiqueradio.org/art/RCA_TM-10_Convergence03.jpg
http://antiqueradio.org/art/RCA_TM-10_Convergence05.jpg
The wands have a spherical part that allows movement within the mount, which is a simple clamp with beveled holes. At the ends, little swiveling clamps hold the cylindrical magnets.
If somebody held a gun to my head, I might try to fab something out of brass stock (assuming it wouldn't matter if the wands were non-ferrous). The spherical part could be a brass bead with a hole drilled through the center, soldered in place. The magnet clips on the end could be as simple as a piece of wire soldered to the wand and wrapped around the magnet. The magnets are practically weightless.
Eventually, I'll need to figure out how to replace the two missing magnets. Perhaps I'll try cutting bits from a frig magnet.
Phil's Old Radios
Old 04-03-2013, 10:56 AM
ohohyodafarted's Avatar
Bob Galanter
Nice job on the start of your restoration article Phill! Looking forward to seeing more as time goes by. It's giving me a good idea of what I have to look forward to when I get to a point when I can start the restoration of the TM-10 I acquired a while back.
ME http://AntiqueTvGuy.com
Old 04-03-2013, 11:49 AM
Thanks. Balloting is still open on whether to use a thermistor in place of a resistor in that little modification. Since I already have some CL-60s on hand, I'm leaning in that direction. Or, perhaps it doesn't really matter.
I'd normally just put something in and then monitor voltages when I bring the set up for the first time. The rectifiers are not in a convenient place, however. To remove the cage around them, you need to pull the CRT and yoke, which does not invite casual experimentation.
Old 04-05-2013, 12:42 PM
Phil-
Since you are likely to replace the selenium rectifiers with silicon diodes, wouldn't you kill two birds with one stone if you put in dropping resistors along with the diodes?
Your new restoration page for this monitor looks great.
Old 04-05-2013, 03:36 PM
Yes, good point. A dropping resistor should do.
Meanwhile, I'm trying to decipher what was done to this set. The choke L34 is missing. Nothing left but a rubber stamp on the chassis and two empty mounting holes.
The parts list describes it as "reactor: choke coil," giving a stock number of 78961 and no other specs.
The choke is connected between the junction of rectifier CR1 and capacitor C3 and its other lead goes to terminal 1 of R241, the screen purity control.
Perhaps someone intended to replace the choke, which had failed and caused other problems. The wires have been ripped from R241 and from R3, the purity control. Both of the 22-ohm resistors wired in parallel with those controls have broken in half. In this photo of R3, you can see that someone crimped a salvaged resistor around a couple of ripped-out wires, maybe as a reminder to "fix this someday."
I'll sort out the wiring eventually. Not so sure where to go for a replacement choke. I don't have bins of spare parts on hand, and the manual gives no spec for it, other than the stock number (78961).
Old 04-06-2013, 12:33 PM
Tim's Avatar
Tim Tim is offline
Phil:
That same RCA part number is used in the CT-100 as a filter choke. L57 in Sams. .63ADC, 17.3 ohms, .6HY. The only sub Sams lists is Triad C-40X. Thordarson Catalog lists 26C81 as their sub.
Tim
Old 04-06-2013, 01:19 PM
holmesuser01's Avatar
I would love to have a unit like this. I remember the 21" round version of this set from RCA and Conrac and wanting one of them, too, knowing how well-built they were.
I look forward to seeing this set pass an image soon. I'm very glad that you saved it.
Old 04-06-2013, 01:34 PM
Thanks, I should have thought to look that up.
I contacted Moyer and they said that they have the Thordarson part. Yay!
Old 04-07-2013, 10:05 AM
N2IXK's Avatar
N2IXK N2IXK is offline
Technohippie
FWIW, the Triad C-40X is still in production, and available from Newark:
http://www.newark.com/triad-magnetic...0-20/dp/03F765
Old 04-07-2013, 11:41 AM
Well, I'll be darned. It's available from Mouser and Allied, too, and all at about half the Moyer price.
Old 04-07-2013, 12:50 PM
WA3WLJ's Avatar
WA3WLJ WA3WLJ is offline
So what fried the choke ?
Something made it get real HOT
