Old 07-18-2012, 05:28 AM
Reece's Avatar
Reece Reece is offline
Yessir, really sharp!
Reece
Old 07-18-2012, 07:23 AM
kvflyer kvflyer is offline
... I bet this pot fried and someone switch this wire to the other side to key it running....
I would bet you are right!
Old 07-18-2012, 12:31 PM
mpatoray's Avatar
mpatoray mpatoray is offline
Bib,
WOW! It is looking great, another set brought back from the dead! And form the video you posted the sound seems to be pretty decent as well!
Matt
Old 07-18-2012, 02:52 PM
Thanks. The sound is pretty good but seems odd projected out from the side of the set rather than the front.
The safety glass has some nasty scratches that I suppose I'll just have to live with.
The CRT is very nice though.
Old 07-18-2012, 03:31 PM
AiboPet's Avatar
AiboPet AiboPet is offline
"micro" and quirky
Location: I'm in San Diego, but lived in Hong Kong for a long time
It's okay.....I call this "Survivor patina". The sort of thing MOST would pass up the set for, but wouldn't keep me from rescuing it and putting it RIGHT next to the pristine ones.
My current "holy grail" is trying to get enough parts together to get a Singer TV6U going. Been kicking my ass for nearly a year now :-P
Old 07-18-2012, 03:35 PM
DavGoodlin's Avatar
Motorola Minion
My 1958 Philco with abrasions on the front. Someday , the right buffing wheel and compound will motivate me to try and fix it.
Old 07-18-2012, 05:31 PM
Someday a clean cabinet will show up for it, until then it's the perfect prop for one of those post apocalyptic movies!
Old 07-18-2012, 05:49 PM
Mal Fuller Mal Fuller is offline
I well remember those sets as pretty good looking. I also remember there being problems with the contrast control. Philcos, while sometimes problematic, always had the engineering it took to produce a good sharp picture when all was well.
Old 07-19-2012, 01:57 AM
mstaton's Avatar
mstaton mstaton is offline
"Book em Dano!"
[QUOTE=bandersen;3042360]Thanks. The sound is pretty good but seems odd projected out from the side of the set rather than the front.
[/QUO
You can fill the scratches with automotive clear coat paint, the small brush on stuff you find at auto parts stores, fill, sand and buff. Maybe test it on other plastic first. It has worked on the plastic panels in front of plasma screens. had pretty good luck with it. hardly noticeable when done.
Old 07-19-2012, 02:18 AM
mstaton's Avatar
"Book em Dano!"
Sorry, I thought it was plastic.
Old 07-19-2012, 11:02 PM
Kevin Kuehn's Avatar
Workin' Late Again
I've often wondered what one those windshield repair guys could do with a scratched safety glass.
Old 07-19-2012, 11:34 PM
Dunno, but it could be worth experimenting with one of the windshield scratch kits available.
I also got a tip about using a felt buffer and Cerium Oxide powder mixed with water to polish them out.
Old 07-20-2012, 06:47 PM
compu_85's Avatar
compu_85 compu_85 is offline
Procrastination Expert
This might be a good use for a dead CRT... Put a scratch in the face then try to remove it.
Sent from my iPhone using Tapatalk
Old 07-22-2012, 08:24 PM
I unmounted the CRT and cleaned off the remaining aquadag.
Then I masked it off and sprayed on a three coats of Slip Plate. The resulting resistance is very close to what I measure on other CRTs. Around 5K with probes 8" apart.
Old 07-22-2012, 09:31 PM
ctc17 ctc17 is offline
You can measure the capacitance with an eye type cap tester. There should be a spec for that crt.
