Hi Timmy,
Don't get discouraged! i discussed with a fellow VK member & friend about your TR-1010 ailments and we both think that you probably have a cut trace on the printed circuit board. Get the chassis under a really strong light, use a magnifying glass and very carefully inspect the PCB around the vertical processor IC. When i do this, i use a paper printout of the board's trace layout + an Ohm meter with a "beep" function - it beeps if you put the 2 test leads in contact to indicate zero Ohms = perfect continuity. I put one end of the test lead at the start of a PCB track and the other one at its end. If the trace is not cut, the meter beeps. Good luck, jhalphen Paris/France |
well i am trying but i am just about out of options i cannot find whats wrong with this set. and you see these little sets with the same problem and i just cant believe i cannot find any repair info on this horizontal line problem with these tvs on the web , not one thing comes up in regard to the tr101p. there must be someone out there that has mastered this nasty little problem. its strange when i got it it had no hv nothing on screen but found a bad rectifier for the focus voltage and replaced it and got full hv and focus voltage but was left with the line across the screen. checked the schematic and the loss of this voltage would not have affected any other part of the circuit. so its still a mystery.
Did any of the old caps have signs of leakage? I restored my JVC P100 and it was littered with bad caps, and a number of them leaked, taking traces with them. I've seen Panasonic capacitors leak, especially in audio gear such as their micro series components.
Take your time, go through each trace on the schematic and if you have a board layout as well, using a highlighter and you'll likely find the issue sooner than later. Good luck |
| Audiokarma |
well it looks like this tv is for parts because i done everything possible to find whats wrong. i think the fly may be bad or a part of it inside because i checked every resistor both chip and threw hole and whats amazing to me is every resistor was right on even the chip resistors. the damper diode only has b+ voltage on it, 4.8 volts and that dont seem right. so for now is going on the side because im out of things to check.
Hi Timmy,
1) reflow solder pads on these corrosion-suspect SMDs 2) check trace continuity with Ohm Meter afterwards. Show us some closeup photos of the suspected corrosion contacts. If you choose to remove these SMD caps, do you have a capacitance meter? Check the vertical winding on the deflection yoke. You have the service manual, locate the pins going to the V coils & check for continuity with an Ohm Meter. On the vertical deflection IC: use your digital VOM to measure voltages on each of the IC's pins vs ground. Compare with the pin-per-pin voltages on the Panasonic service manual. If really fed-up: send the TV to Andy in TX, he will fix it for you. Best Regards jhalphen Paris/France |
OK:
1) reflow solder pads on these corrosion-suspect SMDs 2) check trace continuity with Ohm Meter afterwards.hi, ok heres where im at i did check the ohms on the yoke even though the schematic dont say what it should be it looks ok the ohms are lower then the other coil which i know they vary between vert and horiz coils. and the corroded look to one of the chip caps i did reflow and did check continuity everywhere. i actually checked every resistor and all check very good and i did remove a few key chip caps and subbed one at a time to see if anything changes on the screen, but nothing i do is making and progress. i notice using my dvom on diode check that one lead on ground and i touch the other to pin 4 on the vert ic the screen jumps like it wants to fill the screen. so it seems to me there is a problem in the sawtooth gen that creates the oscilliations to make the vert work but i dont know where else to go from here. it does seem like a timing cap of sorts that may be bad but i just dont know. it is very difficult to really take these chip caps off and sub another really unless i have the exact one to put back in, and leave in and call that cap changed being the right one. all voltages on both ics are where they should be with the exception of pin 6 on the vert ic which is 4.8 volts and should be 2 volts maybe because the vert is not under load, working... also what puzzles me is the line across the screen is not completly across, it starts on one side and stops about an 1/8 befor the other side. i dont know if using ceramic disc caps as subs would be the same as the chip caps that are in there, but i tried. but if it must be the chip type well then maybe ill have to try and get all these chip caps that are in question. Check the vertical winding on the deflection yoke. You have the service manual, locate the pins going to the V coils & check for continuity with an Ohm Meter.... On the vertical deflection IC: use your digital VOM to measure voltages on each of the IC's pins vs ground. Compare with the pin-per-pin voltages on the Panasonic service manual. If really fed-up: send the TV to Andy in TX, he will fix it for you. Best Regards jhalphen Paris/France[/QUOTE] Last edited by timmy; 12-03-2012 at 09:16 AM. |
I would like to just give Timmy a lot of credit for putting all this time and energy in trying to get this TV working again - most of us would have given up with less than 1/4 the effort that he put in - I myself gave up after the ribbon cable tore. Even though these TV's look simple, they are actually very complex and they are very poorly built from a servicing and component quality level standpoint.
We have all had pieces of equipment that were so challenging that the basic "IT or ME" instinct kicks in and forces us to NOT want to let it beat us. At this point, I suggest that you purchase another cheap TR-1010p with similar problems and apply all that you have learned to make a fresh start. Good luck. PS: Andy is excellent, and I am sure that he could fix it, but these TVs are a dime a dozen, and the main purpose is for Timmy to have the satisfaction and pride of repairing it himself. Last edited by crtfool; 12-03-2012 at 05:54 PM. |
| Audiokarma |
I wanted one of those Panasonics for a long time but hearing about all the problems maybe I will pass. I do have the Sony Watchman sets and they seem to be holding up well. Even the ribon cables seem to be strong. I can definitely recommend the FD-20. It is a great performing nicely built set.
Just look at those channels whiz on by. - Fred Sanford |
Hi Timmy,
To help: closeups of the block diagram + application note schematic of the AN5760. Last document is a high-zoom of the TR-1010P's schematic showing the AN5760. Quote:
Hope this helps... Hi Sandy: My experience on many of the Panasonic TR-series 1.5" micro-TVs: TR-1030/1031 always work - built in the second half of the 80s TR-1010/TR-1020 - before 1984 - a lot of failures, mainly V Scan, no sound, dead or very unsensitive tuners. Exceptions: TR-1000 nearly always work - better caps! TR-001, same thing - 1972! CT-101 shoddy plastics: look at them, they break! Not really Panny's fault but the people who made the plastics. When new in 1984-1987 they weren't brittle. Just my 2 Cents.... Best Regards jhalphen Paris/France Last edited by jhalphen; 12-04-2012 at 07:24 AM. |
Why is the circuitry on these handheld sets so complex? One would think that given the small size, simpler designs would be easier to build and service plus be more reliable.
| Audiokarma |
