Old 06-10-2013, 04:15 PM
Charlie's Avatar
Charlie Charlie is offline
On Land
You don't have the Sams? Do you know what number it is? Perhaps one of us has it.
Charlie Trahan
Old 06-10-2013, 08:32 PM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
Is there a fuse between the power supply and the Horiz Output Tube?
You know there is? I assumed that if that fuse was bad, that the set would do absolutely nothing. Checked the fuse. Yep, it's bad!
Put a new fuse in, but it changed nothing. Excellent call, though
Old 06-10-2013, 08:37 PM
Kamakiri's Avatar
This is the one:
https://www.samswebsite.com/en/photo...ndex/id/173981
Might just as well spend the $15, if nobody happens to have it handy....
Old 06-10-2013, 08:39 PM
Kamakiri's Avatar
Originally Posted by holmesuser01 View Post
I'd be checking for drive from the oscillator, B+ on the output tube, the damper circuits. Could easily be something like an open resistor... Is the yoke OK, too? Does the horizontal output actually get HOT, other than filament hot? So many possiblilities!
I think the schematic would be something worth getting at this point, for sure.
It's not hotplating, if that's what you mean.....
And yep, gonna definitely need a schematic now.
Old 06-10-2013, 08:40 PM
Charlie's Avatar
On Land
I will check tomorrow. Just might have it. It's a real bitch trying to chase down a problem without a Sams.
Charlie Trahan
Old 06-10-2013, 08:42 PM
holmesuser01's Avatar
Yes. I assumed you would have told us if it was red plating, anyway.
You'll get it going!
Old 06-10-2013, 08:52 PM
Kamakiri's Avatar
I pretty much have to now!
I knew there'd be a little adversity with it, though. After all, the best laid plans of mice and men......
Old 06-11-2013, 09:28 PM
Charlie's Avatar
On Land
Tim, I found the paperwork on your set. I am going to start scanning the pages. PM me with your email address and I will send these to you when I finish.
Charlie Trahan
Old 06-13-2013, 06:28 AM
Kamakiri's Avatar
You are awesome!
[email protected]
Old 06-13-2013, 09:28 AM
Charlie's Avatar
On Land
You are awesome!
Keep that a secret!
Charlie Trahan
Old 07-03-2013, 01:10 PM
Kamakiri's Avatar
Back on this set for a bit. No HV, so I have a pair of 5642s on order. We'll see what happens next
Old 08-13-2013, 08:04 PM
Kamakiri's Avatar
Had a little time to stick in the 5642s tonight. Powered it up, and got a faint line on the raster
The line faded out after about 10 seconds of play. Shut it down, power it up, same thing. I've got 2.5 kV to the picture tube at this point, and I don't hear the horizontal oscillator running. Hm.
Old 08-13-2013, 08:53 PM
How do the filaments of the two that you removed ohm out? are they *both* open?
Old 08-14-2013, 05:52 AM
Kamakiri's Avatar
Hm, good question. I'll check later today. My only concern is that when I removed the NOS tubes out of the boxes, the glass on the single wire end on each was broken, only about 1mm worth, and not into the vacuum portion of the tube. Still....
Old 08-14-2013, 09:41 AM
I always saw those tubes packed real well. A GT sized carton and the tube wrapped in Kimpack .
