Old 12-16-2015, 01:26 PM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
The bottom of the horizontal oscillator's just a mess. Here's a shot of that, and another shot of the section. The orange drop was done by the last person that worked on it, I should probably change it out just because......
Old 12-16-2015, 01:45 PM
If the osc. coil is out of range I'd check the resistors and try replacing that orange drop...If that fails see if adjusting the other slug of the osc. can gets you anywhere.
Old 12-16-2015, 04:11 PM
Have you tried adjusting the horiz. range trimmer, designated B2 in Sams? It's located on the rear chassis apron, next to the horiz. drive trimmer (just to the left of it).
Also there's two resistors, R75 and R76 (68K and 120K respectively), coming off either end of the horiz. hold control. Either of those being off value will affect the range.
What value is printed on the Orangedrop cap? Is it .002 mf?
Old 12-16-2015, 08:18 PM
Kamakiri's Avatar
I didn't try the range because I was assuming that it was a frequency issue.....can't hurt though
The orange drop was a .002. I changed them both, no change in performance. I'll check the resistors tomorrow. I'll get back on the 8TS30 as well
Old 12-16-2015, 10:47 PM
It means `frequency range`, like a coarse adjustment, with the H.hold being the 'fine adjustment'.
It looks as though sumbody was working on this problem at length, then gave up on it when that Lin coil blew.
Old 01-10-2016, 06:00 AM
Kamakiri's Avatar
Well, I've spent time over the last couple weeks on this set and got basically nowhere. This morning I got up at about 3:30 AM after falling asleep at about 8:30 PM last night, I had a full head of steam and decided to tackle this set, do or die.
I disasembled and tested everything in the entire horizontal circuit, found one missing cap on the width coil (this set was pretty botched up before I got it), and no change. After testing about a dozen resistors and replacing a couple that were way out of tolerance, still no change.
Then I noticed a couple green spots of corrosion on the back side of the width coil, where I couldn't have seen them before. Looks like a couple turns are shorted....which would explain why the turning the width coil does absolutely nothing. That, and the fact that the horizontal lin coil, which sits right below it, was corroded and open, leads me to believe I need a width coil. Spec on the Sams is .1 ohms, this one reads about 1.3 ohms.
I'll pick this up after I get one......
Old 01-10-2016, 06:43 AM
decojoe67's Avatar
Good luck with it. Sometimes you get those sets that just play flawless with a re-cap and others have all sorts of issues. I guess it's the conditions they were stored in that determines that.
Old 01-10-2016, 12:00 PM
Kevin Kuehn's Avatar
Workin' Late Again
When you're talking 1.2 ohms error, make sure your meter was able to zero first, and that the terminals on the coil are clean(maybe re-solder them) It doesn't take much contact resistance and you end up with a false reading.
Old 01-10-2016, 12:53 PM
Even when working correctly, the width coil has very little effect. From one extreme to the other it will change the width maybe an inch or even less. The with coil is in parallel with the flyback coil and used to tweak it's characteristics.
BTW that photo you posted earlier of the bottom of the hor. osc. circuit is stock. Admiral made really wired it that way with three resistors connecting together in mid-air.
Old 01-10-2016, 02:12 PM
Kamakiri's Avatar
Yep, I figured that out by the schematic. As I said, I tested every resistor in that entire string. Since the width control does nothing and I have inadequate width, along with the resistance of the coil, I figured that would be the next step. Terminals were definitely clean, as I de-soldered and cleaned the ends of the wires to the coil.
These sets are never this difficult!
Old 02-21-2016, 02:15 PM
Kamakiri's Avatar
Welp, she's working great now!
The problem turned out to be a simple one. Whoever was futzing around under the 6BG6 (probably before I was born), cut a cap out of it that I couldn't even see. Looks like someone back then was testing things and just gave up. That, and the width coil out of a parts set (thanks bgadow!) brought the set back to life!
Horizontal lin's a little off, but I'll play with that after a little usage.
And finally, another tough dog is done. Whew.
Old 02-21-2016, 02:30 PM
baursam's Avatar
baursam baursam is offline
Well done Tim!!! Perseverance! !!
Old 02-21-2016, 04:18 PM
Kudos to you Sir. Good job! Of course I'm curious which cap it wuz.
Old 02-21-2016, 04:50 PM
Kamakiri's Avatar
It was a .2 uF 200V cap anchored to a dead pin on the 6BG6 going to the ground on the filter can closest to the tube......
