Old 06-17-2026, 11:28 AM
kf4rca kf4rca is offline
What source are you using when you see bending. Three quarter and half inch machines that don't have a TBC output can cause horizontal bending. What are you using for a signal source?
I use Paint (in W7) to crop and squeeze my pictures down. Generally I have to go down to 640x480 to get them to post.
Do you think if I donate to the site, they'll let me have more space? Hmm.
Old 06-17-2026, 04:19 PM
Retired Batwings Tech
The bending happens regardless of the source be it from digital or TBC analog, all of my analog tape has dedicated TBC's and everything is locked to a master BB source thru a Kramer VM-1045 distro amp.
Sources are a Sony VO2860A U-Matic that's on a NOVA-800 full frame TBC. The DigiBeta doesn't need any TBC and the Type-C Sony BVH2000/3 has the internal TBC option boards. I also source from a one of those DTV converter boxes and get the same results.
I'm seeing two types of bending, one related to the black subjects and the other bend is fixed at roughly 1/4 down from the top that doesn't move except when I push the horiz hold to the edge before lock is lost.
Going to sub in some capacitors on test probes and see how things are affected.
Old 06-17-2026, 04:58 PM
Having bending related to black subjects seems to indicate sync clipping at the wrong level, possibly video signal is too small peak-to-peak or at wrong DC level; or, the sync clipper itself is at fault.
Old 06-17-2026, 08:19 PM
That's what I'm thinking as well, going to run thru the IF alignment again and keep a close eye on the sync & burst using both the sweep/marker and actual video to see how things are interacting. I'm sure it's something I'm not doing right but can't put my finger on it just yet.
Going direct composite gives similar results however I can't get my DA to go much higher than 1.5V P-P from an unloaded output. It does however make for a very nice picture without all of the lumped bumps from the coils along the way.
You should see what my cat did to the set earlier today, it's posted here on Audiokarma... and I'm not too happy about it. https://audiokarma.org/forums/thread...#post-18377210
Old 06-18-2026, 02:35 AM
It's 0200 central and I'm out of ideas. A picture can be worth a thousand words so I did my best to grab a few and crunch them down, if you want larger originals they're available. I named the files to be self explanatory, if something doesn't turn out please let me know.
So what I have is endless frustration with the horizontal and to a lesser degree vertical sync. I've run thru the IF response several times tweaking here and checking for symmetry there, replaced the AGC/Sync sep 6GH8 with several NOS tubes fresh from the cartons and checked resistor values along with probing in capacitors on top of the originals with no changes to the bending.
The signal into the 1st video amp is strong, over 2.5V P-P from the detector and I'm seeing signal levels on the various test points that are very near the spec'd levels in the schematics, horizontal lock is very strong but the vertical is dependent on the size control settings, stretch the vertical to fill the screen and it wants to lock on the black band within the picture itself unless I run a 4:3 image in which case it attempts to lock onto a something near black. Tube is new and I've sub'd in several different NOS tubes with the same results.
Power supply voltages are within 5 to 10 volts of spec and I can't pick out any ripple on the scope. AGC is set conservatively however going for overload doesn't affect the bending as much as it does the overall black and contrast as expected.
Horiz out cathode is shy of 200ma at medium brightness and the 6LQ6 tests at 90% give or take.
In the group of pictures I've included the test pattern I'm using to demonstrate running in as both composite and CH-3 RF. The scope screen shot is direct from the test point TP2 using a 10:1 100 MHz probe and the test pattern itself comes from my Newtek Tricaster TC-550 which is essentially a studio control room in a box. All the output levels conform to NTSC standards and verified using a Leader waveform monitor and vectorscope.
So what this all comes down to really is what am I missing?
Old 06-18-2026, 02:45 AM
Just for those who want to see what the set looks like here are a few gems to safely drool over.
Old 06-18-2026, 10:07 AM
damen's Avatar
damen damen is offline
Sorry if I missed it, but if you haven't yet replaced C511 in the vertical circuit, do try a .03, or .033 there.
Old 06-19-2026, 02:32 PM
Complete success.
Found R728 had carbon tracked from what I suspect was an overvolt being it's a carbon film subjected to some 400-plus volts during the initial power on and that particular tube warming up rather quickly. My theory anyway. What I do know is there's a clear carbon burn going from end to end and being on the bottom I didn't see it right away, a carbon comp has since replaced it and the wiggles along with the nagging vertical issue are gone.
Picture quality? Absolutely stunning for 1970 and I've known this set for the past 56 years. Remaining issues? None. A couple of loose ends with the add-on MTS decoder I use in place of the sound discriminator and a mountain of cat hair that's trapped in the cooling fan is really all that remains. What a ride this has been!
So at this stage I'm going to run it for a while and construct the Phil Nelson CT-100 triode based video input adapter that uses the 12AT7 and go from there. It's not a need so much as I have the IF working quite well but now that all the variables have been worked out I can move to the next chapter.
Give me a day or two and I will post more pictures of actual operation and some of what I feed the set with.
Again want to thank everyone for all their help and support. A special thank you to damen and Danny S. for help with the IF board and tuner. Without you I would still be at square one.
Old 06-20-2026, 01:04 AM
Okay so as I promised here's a short clip of the Magnavox in action with playback from my U-Matic of a tape from 1985. Contrast is a little crummy from the ambient lighting but I wanted to do all of this as in the moment at the moment. Anyone know how to repair or restore the woodgrain on that left side slider?
see for yourself.
https://youtu.be/5nUg7hVFQmo
Last edited by ARC Tech-109; 06-20-2026 at 01:09 AM. Reason: because I forget more than I remember.
Old 06-20-2026, 01:11 AM
ronl ronl is offline
Source of free vintage Canadian tv service info.Caretaker of various 1920 to 70s radios,a Farnsworth 651p tv,a RCA Ctc5 and a few 50s tvs.
Old 06-20-2026, 11:41 AM
Looks pretty good! Is that a 25 or a 23 inch CRT?
Old 06-20-2026, 02:56 PM
It's a 23 inch (25BHP22) and the third tube so far. First was a frosty with bad cataracts and low on emissions, second one I swapped in the summer of 83 that came from a C-II and it went another 20+ years before the emissions died off, this was around 2006 and was replaced with an RCA Hi-Lite from an unknown CTC before the set was parked in a big refrigerator box and stored in my parents barn.
It's been quite the journey but now it's back to its former glory and working like it did, most of the resistors and a number of capacitors were replaced along with the tuner after the accidental shorting of the IF cable to the 120V primary fuse. The picture is still vertically challenged but I'm going to let that go for now while I focus on the composite video input interface. One idea right now is to use a DPDT relay in conjunction with the rear audio selector switch that will cut the B+ feeding the IF amp itself and at the same time switch in the composite to that test terminal strip I soldered to the cover tin. Years ago when I added the Recoton MTS decoder I also wired in a 3P3T rotary which selects between the internal MTS and external R/L "simulcast" TV audio input so that way I could have the stereo audio from my U-Matic deck or the satellite we still had going, the 3rd contact set or position was never used so this could handle the switching of a relay as I need to keep the lead length to the 1st video amp very short to avoid smear.
I also received the SAMS 1144 folder this morning and will scan in the Magnavox as a complete set including the TV chassis, stereo receiver & amp chassis and the remote if you want to add these to your collection. Everything will be in a high-res pdf format and will overlap the large pages so things don't get cut off. Give me a few days and I will email it, if anyone else wants a copy drop me a private message and I will get it out to ya.
Here are a few of the audio details. The 45_Coil is exactly how I did it back in 1986 and it feeds a "probe" input on the Recoton FRED MTS decoder, originally they included this adhesive loop to grab some stray 4.5 MHz but that didn't work so I made the pickup instead and have it set to grab some from the 4.5 MHz trap.
Input switch selects between the MTS decoder and external R/L feeding the TV position of the receiver selector.
The hairy fan needs no explanation, the set doubles as a vacuum cleaner of cat hair.
Old 06-23-2026, 03:25 AM
jhalphen's Avatar
jhalphen jhalphen is offline
Hi to all,
Hi ARC Tech-109,
The Phil Nelson composite video adapter for the CT-100 is here :
Original RCA design + Pete Deksnis improved version.
https://antiqueradio.org/VideoAdapte...Television.htm
I purchased the Pete Deksnis modified version of the original RCA design, it works well and is easy to install (on the CT-100) on other TVs, i don't know.
Best Regards
jhalphen
Paris/France
Old 06-23-2026, 09:54 AM
Originally Posted by jhalphen View Post
Hi to all,
Hi ARC Tech-109,
Best Regards
jhalphen
Paris/France
A few years ago I built an improved version for a restoration customer. We wanted to still be able to use the tuner in a switchable capacity. Running the detector video through coax to a switch degraded it so I put a mini double throw relay on the socket extender so the tuner signal path lead dress would be virtually unaltered when not in composite video input mode, I added an audio injection circuit too and copied the preamp circuit from an RCA 45RPM record player for the audio line input... It worked great and I need to build a couple more for me.
Old 06-23-2026, 10:40 PM
That's what I had in mind, DPDT relay to feed the 1st video amp while cutting the DC to the IF amp, composite goes in after the 4.5 sound trap so I still maintain the DC integrity of the grid, did some tests just poking a 1V Hi-Z video signal in and got excellent results.
