Old 10-28-2022, 04:01 PM
the hot coil problem is most likely due to a faulty C96, But you can't get the exact replacement for it, it may even be what burned r145.
it can be replaced with 2 caps in series,
https://www.mouser.com/ProductDetail...rjw6zMJw%3D%3D
https://www.mouser.com/ProductDetail...EPCXzdjw%3D%3D
this is unrelated to K1
2 3kv caps in series that = 6kv@132pf total
get 2 new 1000v 2amp power diodes at the same time.
Not really square 1, or square 5001. You are making progress......
I was just looking at the schematic & thinking about the hot focus coil too....
But I was wondering about the other part of the circuit....... You know, the
part over by V1 where there has to be a rotten nut.....
I'm wondering about C60, & R87, & R14. At this point any Variable Resistors
should be checked from all 3 pins to ground for a possible internal short, not
just checking to be sure they read their rated resistance.... I still did not see
a post about R23 to be sure there is no short to ground from any of it's pins...
Think about that "tin wiskers" stuff inside these pots.....
Any way poor Timmy being pulled in 30 different directions to check this, and
replace that..... I think he needs a beer....... And if he ain't drinking yet
well then he's a strong determined individual!
The other bad bunch-a nuts can be hiding in that V6 area, where this focus
pulse is going - See that pin 3 with 2.5V on it, and with the scope pic of that
450V P-P wave.... No way you going to be able to figure out what should
really be there..... And that little circuit helps that K1 do it's thing, and it's
attached to V1, or did I say that once already.....
Old 10-28-2022, 04:14 PM
unless there is some other weird error in the way the flyback was wired back up, I'm not sure what is going on here.
Old 10-28-2022, 04:28 PM
The agc pot checked already for anything and r23 didn’t check yet but the 2.2pf+25 cap I actually have one coming. And yes I know the agc network is hooked to v1 so with L42 and focus coil getting hot there’s the 2.2pf cap and the 130pf hopefully one of these is the cause.
Old 10-28-2022, 04:29 PM
Flyback is good I went over that.
Old 10-28-2022, 11:37 PM
I would also think that C59 would be suspect, its getting hammered with pulses from the flyback.
DANG this set is REALLY an oddball one!
Old 10-29-2022, 08:21 AM
I still have the original 130pf 6kv and I have a 470pf 2kv and I have a 2.2Pf +25 pf 1kv coming sams don’t show a voltage for the 2.2pf I hope this cures L42 from getting hot that is very delicate.
Old 10-29-2022, 12:18 PM
Disconnecting the 470pf and 2.2pf made no difference L42 still getting hot and made no difference with video the 22ohm on v1 was 28+ohms so I changed the 22ohm on v2 it was 26+ohms on since doing this I don’t have the good video I had on pin 2 of v2. The batteries are at 8v maybe the subber is not working at full because of that. As for L42 all I got left is the focus coil or the 130pf 6kv cap which is new so I don’t know what’s more likely.
Old 10-29-2022, 01:45 PM
Has that big dropping resistor network been changed? r142-144?
Old 10-29-2022, 02:06 PM
Are you referring to k1 ?
Old 10-29-2022, 02:08 PM
I did not think that those caps in the sync/ AGC area had anything to do with the L42 heating problem, you unhooking them just confirmed that, the way they are doing things in this set is confusing to say the least, BUT, the current path for L42 has to be between pin 1 of the flyback and pin 8, and also the resistor network to ground.
But what is really going on here is odd.
Old 10-29-2022, 02:10 PM
i mean the 3 big 22 meg 2 watt resistors in the focus circuit
Old 10-29-2022, 02:13 PM
Yes they are new along with the 130 cap
Old 10-29-2022, 02:37 PM
So I could have probably used the one single 66 meg focus resistor that’s used in the ctc series clone chassis and rca.
Old 10-29-2022, 05:38 PM
yes, they are sill to be found all over the place.
Old 10-29-2022, 05:56 PM
But can that single 66 meg be used in place of 3 22 meg resistors. Why Motorola used 3 resistors when they could have used one. I have a bunch of those resistors.
