Old 07-22-2012, 10:12 PM
Originally Posted by ctc17 View Post
You can measure the capacitance with an eye type cap tester. There should be a spec for that crt.
I don't think it would be all that critical would it?
Old 07-22-2012, 10:33 PM
It doesn't seem so since the datasheet says 850-1400pF. I'm measuring around 900pF with my vintage Solar CB-1-60 cap tester.
I would think it's also possible to stick a 1000pF HV cap on the flyback to filter the HV and not use the coating at all.
Old 07-22-2012, 10:34 PM
ctc17 ctc17 is offline
well the dag + glass = filter capacitor. IIRC the small crts are something like 800-1200pf, its enough to smooth out the hv.
Old 08-05-2012, 02:40 PM
I sprayed a little more slip plate in the corners and got it up to 1,000pF.
Then I did some final tweaking and put the set back together.
I sprayed some semi-gloss black on the metal portion of the cabinet and silver paint on the trim. I'd still love to find a better cabinet someday but at least it's somewhat presentable now.
Old 08-05-2012, 02:46 PM
holmesuser01's Avatar
First, I see the resolution of the video. Yes!
This little set has probably never seen such a clean signal... Are you going thru the tuner?
Old 08-05-2012, 02:49 PM
Boobtubeman's Avatar
<---WANTED: Motorola 17P6
Holy smokes thats Sweeeeeeeeet!!! Exelently done!!!
Old 08-05-2012, 02:51 PM
Thanks!
Sure. I'm using an over the air ATSC to NTSC converter box. The RF output on channel 3 is going through a 75-300 balun into the antenna terminals on the back of the set.
Old 08-05-2012, 02:54 PM
Thanks!
Sho' looks purdy.
Kevin Kuehn's Avatar
Workin' Late Again
Loving the way this set has come back to life. Excellent work, as usual.
So what is the test pattern showing the video response at?
Old 08-05-2012, 02:59 PM
I think around 3.5 MHZ. I'd have to dig out the Sencore VA62 manual to know for sure. Also, I haven't done an alignment on this set yet.
Old 08-05-2012, 03:14 PM
that's a nice sharp picture ,good work .
Old 08-05-2012, 09:48 PM
Looks great!
Old 08-05-2012, 09:56 PM
WOW! That thing really came back to life! It looks a lot better all cleaned up. I hope you can find a bezel for it. That picture looks perfect!
Old 08-05-2012, 10:48 PM
Boy, great picture on that one.
Old 08-05-2012, 11:31 PM
Thanks. I'll wait a while and if a bezel doesn't turn up I'll break out some Bondo and try to repair this one.
