Old 09-26-2012, 08:43 AM
IsthmusTV's Avatar
IsthmusTV IsthmusTV is offline
Bravo!! It looks like all your excellent work replacing the "K" networks really paid off. Congrats!
-Clark
Old 09-26-2012, 12:30 PM
Originally Posted by cwmoser View Post
Hey Bob, I'm collecting knowledge on these old Predicta's because they seem to catch my eye. Can you post a
picture of a new tube socket and tell who can supply them?
If I find a Predicta, might as well replace all the tube sockets
with the recapping.
Thanks
Carl
They're identical to the originals.
Check out these two earlier posts in this thread.
http://www.videokarma.org/showpost.p...3&postcount=28
http://www.videokarma.org/showpost.p...1&postcount=32
There are also some white ceramic ones available like these guys that might hold up better: http://www.ebay.com/itm/10-ceramic-9...-/320962006659
The central ground post doesn't go through to the PCB though. Not sure if that matters.
-Clark
Thanks! Now I'll be forever curious if these networks are working as well as the originals would have
Old 09-26-2012, 01:20 PM
marty59's Avatar
marty59 marty59 is offline
I've not done anything with the couplates in my Predicta but I sure like how yours turned out. I could imagine my luck could change at some point....
Once you know everything's fine I do like the heatshrink method to protect/cover 'em with.
Old 09-26-2012, 07:36 PM
mpatoray's Avatar
mpatoray mpatoray is offline
Great work with this set! It has been a great thread to follow. Cant wait to see it all done!
Old 09-26-2012, 07:55 PM
Mars777's Avatar
Mars777 Mars777 is offline
Congratulations Bob!
The replacement couplates that you designed seem to be a valid replacement after all. Nice work! I am suspecting bad couplates in my Eico 369 Sweep Generator which may be bad/out of tolerance as well. Maybe that is why your Eico 369 is a little out of whack also.
Good luck with the final tweaks in the Predicta!
Take Care,
Tom
"Mars777" aka "AntiqueRadioandTV" aka "Tom M."
AntiqueRadioandTV Youtube channel
AntiqueRadioandTV Photo Gallery
Old 09-26-2012, 08:39 PM
Thanks. I do have vertical jitters so my K networks may need a little tweaking. That or something else is not quite right. I'm in the process of checking all the voltages and waveforms.
Old 09-26-2012, 08:58 PM
It's tempting to coat these networks in epoxy or silicone, but I'm afraid I may need to tinker with them to get the set running properly.
They do kind of look like they're built out of Saltine Crackers.
Old 09-26-2012, 10:28 PM
Down Under's Avatar
Down Under Down Under is offline
Hi Bob,
I'm reading your post with interest, as I have a Holiday that I'll start working on as time permits. I'm also working on a Debutante and Princess just to punish myself!
With regards to those tube sockets, where does the break occur exactly? It's a bit hard to see, even on your close ups. The boards are out of my 17in TVs at the moment, so I'd like to know what I'm looking for in terms of broken sockets BEFORE I solder the boards back in.
Of course I'll be testing the boards first, but if any of my sockets look suss, I'll replace them.
I'd LOVE to get a Tandem, but I have to be welll cashed up to get one of these. They go for a lot, and then I have to add around $700.00 freight just to get it to Australia!
But thanks for your continued posts, I always find them interesting!
Four Predictas down, now to score a Continental.
Old 09-26-2012, 11:02 PM
Checkout this post: http://www.antiqueradios.com/forums/...p?f=3&t=176131
I just happen to have two Tandem sets and will likely sell one off. I'd like to get them both working before I make a decision though.
I'll also be restoring a Princess and Siesta model along with the Tandems.
Old 09-28-2012, 12:06 PM
I pulled the main PCB again which actually wasn't bad to do now that I've got the hang of it.
Getting the old sockets out isn't quite so easy though. I ended up cracking the old brittle plastic and removing the pins one at a time.
I had thought the replacements were identical to the originals, but I was wrong. The replacements are made from heavier gauge metal and are twice as wide where the old ones broke. They should hold up very well
Old 09-28-2012, 12:09 PM
Moving on to the cabinet. Structurally it's fine, but the photo finish is badly flaking off around the CRT base.
Perhaps some real veneer is the easiest way to go
Old 09-28-2012, 09:58 PM
50scraze's Avatar
50scraze 50scraze is offline
I really need to get on here more! First time I've logged in for months and I see this great restoration. First time I did one of these sets I absolutely hated it, several more later it's not so bad.
I think the wood veneer (teak?) will look really good. Just be prepared to spend a lot of time cutting around all those lines!
Old 09-28-2012, 10:06 PM
That's real mahogany veneer. I might just veneer that bad center section to avoid having to cut out all the pieces. On the other hand it might stand out if I do that.
Old 09-30-2012, 09:02 PM
Down Under's Avatar
A real glutton for punishment, I love it!
I love the tandems, especially the mahogany ones.
Thanks for that link to ARF, I can see where the sockets fail now. Looks like a job for my magnifier lamp!
Old 10-01-2012, 05:30 PM
Now that I've experienced the heat put out by the 3-section filament dropping resistor, I've been thinking how it could be eliminated.
I crunched the numbers and came up with about 97 volts consumed by the tubes including a 6.3 VAC replacement picture tube. If I assume 125 VAC at the plug, a 20uF AC capacitor would do the trick.
However, those two taps are there for light bulbs that illuminate the VHF and optional UHF channel knobs. I did a little research and found there are 130 VAC white LEDs available in a BA9S base.
They're a bit harsh compared to the yellowy incandescent blub, but work fine.
I figure I'll give it a try and if I don't like the results it's easily reversible.
