Old 08-14-2013, 10:38 AM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
These were too, which is odd why it had a chip at the top. Both of em did.
Old 08-14-2013, 12:46 PM
Chipping around the plate lead can happen fairly easily if the lead is bent without proper support of the lead where it enters the glass. Usually not a problem unless a crack has propagated down past the seal area, the orange/red portion of the wire sealed in the glass.
Old 08-14-2013, 04:52 PM
I have a 51 or 52 17" Sylvania that uses those odd rectifiers, I had no trouble with them but I did buy a couple because I initially suspected they might be bad.
Old 09-12-2013, 01:52 PM
Winky Dink's Avatar
Winky Dink Winky Dink is offline
Hantavirus Revisited
To expand on Eric H's 5-3-2013 post (above): I was cleaning the results of a rodent infestation from my current project, feeling safe that there was no viable virus in these old droppings. I went to the CDC website to find that the virus only remains infectious in the environment for a few days, but they also point out you can't be sure that the critters weren't pooping in the radio moments before you pulled it out of the shed/attic/barn.
There have been less than a thousand reported cases in the U.S. since they started counting in 1993; but it has occurred in 34 states so far, the animal vectors are found in all 48 contiguous states, and about one third of the infections have been fatal.
The CDC recommends some rather extreme measures to deal with rodent droppings, but I think it would be prudent to leave a rodent-infested set outside of your living area for a week, and then clean as much as possible outside before taking it inside.
Winky Dink
Damn the patina,
Full speed ahead!
