Old 12-23-2013, 12:07 PM
if you are getting a clean snow free pic do not clean the tuner. those horz lines are macrovision and not a fault of the TV. Watch my video listed for how to setup the fine tune.
Old 12-23-2013, 12:40 PM
rob Cashin's Avatar
rob Cashin rob Cashin is offline
i just tried switching some of the tube- i switched 3 of them around, now the thing doesnt show any picture at all
Old 12-23-2013, 12:47 PM
rob Cashin's Avatar
no picture no sound... looks like ill need a few 6BL8's
Old 12-23-2013, 01:03 PM
before messing with the tubes did you do any of the stuff I recommened?
check the signal
adj the fine tune
If not I am out.
Old 12-23-2013, 01:08 PM
rob Cashin's Avatar
the signal is good, i use my converter box and vhs/dvd daily on my 80's zenith space command. i got the tv going again, a tube was half out... the tuner is screwy. i get no picture but then if i push on the tuner to the right it comes in nice and clear, but black and white
Old 12-23-2013, 01:09 PM
Did you adj the fine tuning per my video? Try it while doing what ever you are doing to get a BW pic
the idea here is to isolate the color issue to tuner bandpass or color circuits.
Old 12-23-2013, 01:15 PM
rob Cashin's Avatar
i did adjust the fine tuning. i have to push on the tuner though for the picture to come in clear. its working again, black and white but something is up with the tuner.
Old 12-23-2013, 02:46 PM
DavGoodlin's Avatar
Motorola Minion
Rob,
If you're on channel 3 with the VCR, try switching it (or changing it in set-up menu) to channel 4. Then change the TV to 4 . Or vice-versa. its possible your Motorola's tuner may not have the fine tuning range on the channel you are using. If you have to push the tuning knob in for it to come in at all, wiggle the tuner tubes or the tuning knob to verify if you have a connection issue.
DG
-Dave G
Old 12-23-2013, 03:51 PM
holmesuser01's Avatar
You're probably doing the TV a favor by letting it run. It needs to get warm to get the dampness out of the electronics.
You're getting there. It's got a picture!!
Bruce
Old 12-25-2013, 08:58 AM
Old TVs are better!
Well that piece isn't a magnet, it's the degauss thermister, and yea, if it is open or in this case falls apart, set will be dead. Maybe the tubes may light up, but no B+ to operate the set. If you like to try it out, just twist the loose wires together and see if the set powers up. Usually it's a 120 Ohm thermister (cold), and it drops in value as it heats up. Giving the set a slower warm up and also runs the automatic degaussing. Also check for a large black round varister with 2 leads in the degauss circuit, usually near the thermister. If it is fried, it needs to be replaced as well. Set will work with out it, just won't degauss the crt. I have a 120 ohm degauss thermister if you need one. I'll send you it free.
Sorry, only read first page of post, didn't realize you got the set going.
Old 12-25-2013, 12:09 PM
Walter,
Read post# 42 re. The auto-degauss setup.
Old 01-05-2014, 07:00 PM
Robert Grant's Avatar
Originally Posted by egrand View Post
Do you have a way to hook up a signal source like from a VCR?
Here's an ad from Sep. 1964 when Motorola introduced these sets:
http://books.google.com/books?id=-Eg...eranto&f=false
Love that ad link - but check out the Admiral "Copenhagen" ad on page 65!
