Manually degauss, and if that fails move the yoke farther back (even if you temporarily have to slide the convergence yoke back a bit to make it work).
I have an RCA WR-64A color dot bar generator that I hooked up just for the heck of it and the thing worked for a few minutes and then my sync started going whacky. So I put it on my daily watcher and the same thing happened, which to me was good as it told me that it wasn't some issue with my old Zenith. I smacked it on the side (generator) and the sync problem went away. SO, I probably need to clean up some tube pins and sockets and I will have that rather handy unit ready. Never a dull moment in this saga! BTW, I know they make DVDs now for alignment. I'm sort of a fan of vintage test/setup equipment and it was a gift, so I may as well put it to use.
"Face piles of trials with smiles, for it riles them to believe that you perceive the web they weave, and keep on thinking free" |
GREAT! Moving the convergence clover back along with the yoke allowed me better purity adjustment. Not having a true technicians degaussing coil, I just got out my Weller soldering gun and used it like a coil. The trick worked great! I'm a bit embarrassed as to worrying so much about positioning my convergence clover perfectly. I have learned through trial and error that indeed we often need a pointer, but sometimes ya just gotta jump in there and see what things do.
If you are a tech or minded as such, then you know to mark and or document in some way the way things were before you moved or adjusted this or that. Our training or experience taught us not to go 'tweaking' this or that until you have reviewed some technical data and at least have a rudimentary understanding of what a device, circuit or adjustment of either will or does do. And when in doubt, ask a question. I don't know what it is with some of us, but we would rather noodle with a $10K piece of equipment and sometimes ruin it than to simply say I don't know for sure what is going on with this, anyone got some advice. Geez! ![]() I saw that enough in the work place to not want to be 'that guy' and it's why I don't mind asking things that may sound ridiculous to some of the seasoned veterans of the golden era of electronics. I work on high dollar automation every day, but I need help sometimes with REAL electronics that's decades old. Having this place to gather that pool of knowledge is invaluable and a blessing. Thanks again to ALL here who have helped. I thought someone might enjoy tonight's screen shot of Cream's reunion show at the Royal Albert Hall a few years ago. Ironically, it's where they did their "farewell" jaw dropping final performance back in 1968. I tell ya, audiences of today may as well be dead people compared to the crowd in 1968. The band more or less holds it's own to be the age they are now. Great DVD if your into Blues/Jam/Rock. They were their own unique genre.....
If you can find a curbed 27" BPC TV set with a single large degauss coil, then you can salvage the coil from the BPC, loop that large coil into a ~15" smaller coil, and attach a cord to it, and use it as a degaussing coil. This ad-hock degauss coil may only last 1-5 minutes of 120Vac at a time before overheating so keep an eye on the temp and work fast if you use this method. I made a backup coil that way, and it works decently.
Maybe taking a 60 or 100 watt lamp and connecting it in series would produce enough magnetic flux to be effective, without burning up.
| Audiokarma |
Interesting that they use aluminum wire. I've never removed the black plastic wrapping to check.
I still can't believe the job that my Weller model 8200 soldering gun did. Anyone ever tried this? I found it on the web as an alternative. I will say that it didn't hugely distort the raster the way a traditional degaussing coil does. Mine is 100/140 Watts. Not sure why it is listed that way.
Pull trigger to the second click = 140 watts jr |
OK thanks! I think my gun is as dated as most of my equipment. The packaging looks 50s or 60s. Great to know!
Not to derail this thread too far, but here is a nice page about Weller guns... 60s is a good guess for a 8200.
My first Weller was given to me by my parents when I was a kid (late 50s)... a 8100 K set. Later (late 60s) it was lost/stolen and I replaced it with a 8200, which I still use on occasion. My favourite soldering tool for most stuff is a WTCPN station, also shown on the page: http://www.stevenjohnson.com/soldering/weller.htm jr |
| Audiokarma |
I got a near perfect 8200 for $10, tried to keep a poker face as I dug out a note
"When resistors increase in value, they're worthless" -Dave G |
I'm glad to hear the good press on the older Weller soldering guns. I guess I didn't really know what I nice gift my girlfriend bought me. Yep, the same woman who would LOVE to see the Zenith in the kitchen vaporize as well as the 5 other sets that she widdled me down to. Actually, she does see some charm in a 1950 RCA TC-127 in the living room, so it may have hope of a long and healthy life.
But she brought home this Weller in it's factory gray case with a nice piece of period advertisement inside the cover as well as the Styrofoam insert that seems impossible to pack it in. Actually, I think it broke in two on my last attempt, so I keep the gun on the shelf. We have a newer one at work that is the same size, but feels like a toy in your hand compared to the old one. Great stuff!
I was able to find 3 used 6GH8s that test as good as new and a NOS 5GH8 (which should not mind an extra volt on the heater from a transformer powered set).
I'm trying to scare up some 6KT8s too...I found 3 that were less than great, but I've only searched a fraction of my unsorted stock of that era of tube so far.
That term "reform" is probably what goes on really. A decades long dormant set gets playtime and the caps (if they made it that far) may sort of reform or rejuvenate themselves. Some people don't believe it, but I have seen it many many times. I heard these 60s color sets, particularly Zeniths' often come back from the dead like new. That's more or less what happened with mine. I put a new cap across the horizontal efficiency coil as I was installing it anyway and will likely replace the coupling caps in the same circuit. That's about it....
| Audiokarma |
