Old 07-11-2016, 10:15 PM
Hagstar's Avatar
Hagstar Hagstar is offline
UPDATE- I devised a corona free method of measuring high voltage (no there is no rubber cap on the lead to the CRT you can slip it under) and lo and behold I measure 22-24 kV out of her now. I didn't see the leakage robbing my voltage before where the tip of the probe met the (empty) rectifier socket contact. I sleeved it with 2 layers of shrink tubing leaving just the tip and voila- 24 kV which I adjusted per the specs down to 23.
John H.
Old 07-16-2016, 09:06 AM
Hagstar's Avatar
WHERE IS MY DEGAUSSING COIL??? I'm not going to do it with the soldering iron again.....BUT best image so far, mostly converged- https://www.youtube.com/watch?v=NGVm...ature=youtu.be
EDIT- 11 AM Sat.- found it, a Walsco 2592 with Lafayette labeling.
John H.
Old 07-22-2016, 05:34 PM
Hagstar's Avatar
Better video- https://www.youtube.com/watch?v=LfC2...ature=youtu.be
Old 10-03-2016, 09:11 PM
Hagstar's Avatar
Can someone offer clues as to why NONE of my horizontal phase coils seem to do anything? I can't seem to get any decent dynamic convergence and this appears to be the reason. The amplitude and tilt controls all seem to function normally. Stripped slug threads is my only guess.
John H.
Old 10-04-2016, 11:55 AM
Make sure that all the drive signals are there, using a good scope. if you don't have one you should get one. There are are three good books on the down load page at SMC Electronics that will give insight on there use. Eric H. if you would be so kind, post the link and instructions to get the pdf's would be great(thanks Eric). All the best,Tom.J
