Old 08-25-2016, 10:38 AM
bigaudioal's Avatar
5 is the only one with weak HV, you won't have any trouble getting a full 24/25 KV out of this set.
When working with my CTC-5 last week I noticed that all the service literature I have says between 19.5 - 22.5kV at the CRT anode. My CTC-5 is putting out exactly 20kV.
Why do I constantly see folks complaining about the CTC-5 not putting out 25kV when all the original service literature says lower than 25kV for this set is normal?
SAMS for early CTC-5 says 22.5kV
RCA Original Service Manual says 19.5kV
RCA Original Setup Manual says 20kV
SAMS for late CTC-5 says 22kV
See attached snip-its from some of that literature.
Just wondering as I have limited experience with vintage color sets.
Thanks.
File Type: jpg Original RCA service Manual - Early CTC-5.JPG (35.7 KB, 24 views)
-Al
Old 08-25-2016, 03:16 PM
miniman82's Avatar
First Light: 1952-2011
The problem is not the literature for the chassis, it's the specification itself. Not only did they choose an anode supply for the 5 chassis which only provides around 20kv to the CRT, they also for some unknown reason decided to not make up for that lack of voltage by having ample current reserves. To understand why this is a detriment, see note 3 of this PDF on the 21AXP22:
https://frank.pocnet.net/sheets/137/2/21AXP22.pdf )
I say lack of voltage because the 5 is the only one that low, all other chassis (especially the earlier ones) made a full 25kv and had more than enough current in the anode supply to make a full and bright picture without trying very hard. Add this to the fact that the data sheet on the CRT even tells the engineers that less anode voltage equals less brightness, and it will always be a mystery to me why RCA chose in this one particular chassis to do what they did. I don't care to speculate why it happened, it's an issue and makes the 5 a real dog in the brightness department compared to other sets.
Evolution...
Old 08-25-2016, 03:47 PM
Add to that the fact that some chassis versions have a bass-ackwards brightness/contrast control circuit that has lots of interaction between controls, and some users were literally sending working sets to the repair shop because they could not manage to set the controls for a good watchable picture.
The 5s are the BOTB RCA color chassis in my book. If I had a nice 5 with a good 21AXP as well as my beat up 4 with a bad AXP I'd consider the 4 more worthy of the rare AXP.
Old 08-25-2016, 03:49 PM
bigaudioal's Avatar
Ah, I see. So it was the design of the set which produces the lower HV, thus being the least adequate to run the AXP. So the set literature is accurate and the 20kV is "normal" for a CTC-5. But that is barely enough to produce a decent picture compared to other sets of the same time period which produced around 25kV.
Very strange they did that considering the specs and notes on the CRT they were using.
-Al
Old 08-25-2016, 03:51 PM
bigaudioal's Avatar
I have noticed blooming and focus issues while adjusting both the brightness and contrast controls.
-Al
Old 08-25-2016, 04:11 PM
SwizzyMan's Avatar
Restoring an admiral c322
Doesn't this set need to be registered in the ETF's database of surviving CTC-4's?
RCA CTC-7 Pensbury (Restored)
RCA CTC-5 Westcott (Restored)
Old 08-25-2016, 08:57 PM
miniman82's Avatar
That's why it's the runt of the litter, so to speak. For the same reason I, like Tom said, would cannibalize a 5 to get a CRT for a more deserving set. Done it many times. About the only ones that don't fall into that category for me are the more rare Deluxe doored models like yours, my Wingate and maybe a few others. But apart from that, they fall into the category of donors.
Evolution...
miniman82's Avatar
Here's a thread talking about the circuit mods, BTW.
http://www.videokarma.org/showthread...=256638&page=2
Evolution...
Old 08-25-2016, 10:49 PM
bigaudioal's Avatar
Thanks very much!!!
-Al
Old 08-27-2016, 08:40 PM
SwizzyMan's Avatar
Pulled the chassis tonight. Multiple repairs have been done. You can tell it was owned by a repairman. I have already started recapping the filter caps. More to come later.
Old 08-28-2016, 08:56 PM
SwizzyMan's Avatar
It's amazing what a bit of tarni-shield and elbow grease can do!
Old 08-29-2016, 07:11 PM
Reading the nth explanation of the 5, got me thinking:
1) Did the DeLuxe, with its better color, video, and sound circuits, have the same low HV as the Super? If so, that's a shame.
2) If you consider the 5 as a donor anyway, how about the possibility of rebuilding the HV section based on a better design. Maybe the main replacement needed would be only the fly, with the same yoke? Or maybe you'd need both? If this makes sense, I'd be tempted to try it on my 5, which makes me cry because it's got a good CRT being shown to such poor advantage.
Old 08-30-2016, 04:17 PM
miniman82's Avatar
Wayne,
This is a problem with all 5 chassis, including the Deluxe ones unfortunately. The problem is the flyback, it's got a lot more primary resistance than other models. This means there's a practical limit to how much current the HOT is able to sink, which in turn limits how much HV can be made in the secondary (lower current primary pulses means lower amplitude flyback rectification in turn). I'm not sure why this was done, but it appears to be in the design and intentional. Perhaps the engineers wanted it to be 'safer' or something, we'll likely never know.
I have a few different flybacks I can try in my Wingate (CTC-4, CTC-28, CTC-15), but the problem is not getting more HV or a yoke inductance match from the swap- there are ways around both those problems. It's getting all the ancillary circuits to play well with the new transformer that's a big question. None of the tertiary windings that provide pulses to circuits like burst gating or AGC appear to be common across chassis to me, which makes the job of adapting them much harder. Some flybacks had positive going pulses, some negative. Some had very high amplitude AGC, some not. What I see is probably a matching/inverting network and possibly some slight phase shifting to make the new fly work. It won't be a plug in deal unfortunately.
BUT- the payoff would be a very nice chassis indeed. The deluxe sets had good circuits in them for color processing, they just had a wimpy horizontal output transformer. I'm going to give it a shot at some point, and I'm also going to try primary side pulse style HV regulation. It'll be like reengineering a complete section of the chassis.
Evolution...
Old 09-01-2016, 04:23 PM
SwizzyMan's Avatar
Still have 2 more filter caps to replace, but I thought I'd do a power up to see where I'm at. Current draw is about 2.5A and only putting out about 3 KV. I don't believe the HV readings since the yoke is not plugged in and all I'm using is a piece of wire to short the yoke connection so the HV will actually come up. Found a 80 uf in place of a 40 uf in one of the filter caps and most of the hacked in filter cap replacements had shot their crystallized goo out the side already. Things are going well!
Old 09-01-2016, 05:30 PM
Personally I'd pull the H output tube, till the recap is done and the osc. has been dialed in with a scope. Don't want to risk your flyback. On my 4 I did it that way, and when I was ready to install the tube I had it set up to dip the cathode current using the linearity/efficiency slug as soon as I had HV....I pretty much confirmed I had decent sweep and HV then immediately dipped the current. If something is wrong and the fly is being fed too much current, you don't want to run it that way long....We refer to flys for early sets like this as unobtainium for a reason!
