Old 05-03-2018, 02:09 AM
Josef's Avatar
Josef Josef is offline
Exclamation
Originally Posted by EdKozk2 View Post
Hi Phil,
Just reversing the two horizontal wire connections within the same circuit is what makes sense. The same would go for the vertical connections. One thing to watch for is if the picture is reversed. Lettering or words on the final viewed image will be incorrect. Just like putting a slide in a slide projector backwards.
Ed
That's exactly what I wanted to point out. Sorry for causing misunderstandings- I'm not native speaker.
Old 05-03-2018, 05:12 PM
No problem! It's a clever idea. I may get a chance to try it in a day or two.
Regards,
Phil's Old Radios
https://antiqueradio.org/index.html
Old 05-04-2018, 07:10 PM
Originally Posted by Josef View Post
I'd reverse the vertical and horizontal deflection wires and see what happens. If the pattern is mirrowed the defect comes from the electronics, if it stays the same the optics are faulty
Josef's test shows that the defect is in the electronics.
I reversed only the horizontal wires (pins 5 and 7 in the previous schematic). That should answer the basic question. Here, they are connected normally:
Horizontal wires connected normally:
Horizontal wires reversed:
The distortion flips horizontally, so clearly the big defect lies in the electronics. Thanks for suggesting this simple test, Josef!
That's actually a relief. Although I don't have an immediate solution for the electronics, that sort of problem-solving should be easier than trying to fiddle optical parts inside the Protelgram "black box" without the factory jigs originally used to align them.
Now I will put the three chassis back onto the workbench and resume my homework (testing voltages, etc.).
Regards,
Phil's Old Radios
Old 05-30-2018, 04:26 PM
I finished my voltage-testing homework, checking all the voltages against the chart in the Sams manual (https://antiqueradio.org/art/Sams%2090-6.pdf). This spreadsheet shows the test results (ideal = voltage from the manual, actual = measured voltage):
https://antiqueradio.org/art/Emerson...nVoltages.xlsx
The tests were done with the line voltage held at 117VAC on a variac. I turned down the brightness and audio volume controls; the horizontal & vertical hold controls were set for a normal picture.
Not surprisingly, given that most of the TV works fine, most of the voltages are in about the right ballpark. The filament voltages look somewhat low everywhere, measuring about 5.7 - 5.8VAC rather than 6.3 volts. None of the other results looks like a big red flag, although possibly I'm misinterpreting something.
I'm back to seeking a cause for the bad horizontal linearity. As mentioned earlier, adding a cap across the width coil increased the width and somewhat affected the linearity, but it wasn't a miracle cure. I suppose I could go back and fiddle with different values for that cap.
There isn't much else to tweak in that circuit, although I see two caps on either side of the horizontal linearity adjuster (C-65 and C-64 in the Riders schematic below). Those wouldn't be difficult to change, if there's a reason to try that.
Any other ideas?
Phil's Old Radios
Old 05-30-2018, 05:13 PM
What type of caps and values are C-64 and C-65? If you have no way to test, substitution is surely a good idea - after all, that coil they're attached to does say H lin.
Old 05-30-2018, 09:25 PM
The originals were 600-volt rated paper caps, which I replaced during the first recapping pass. C64 is .035 and C65 is .05, which look like pretty standard values for those caps in my old TV books.
I replaced them with modern film caps (the brown chiclet style) rated for 630V. I paralleled two caps to make up the .035 cap.
I guess it's possible that one of the replacement caps is bad or that I (shudder!) installed a wrong value. I can disconnect and test them.
Phil's Old Radios
Old 05-30-2018, 09:42 PM
I have less confidence that they are the problem, since you replaced them, but it doesn't hurt to double check. There seem to be two things going on: left and right not the same width (usual sort of linearity problem), and sides much wider than the center. I don't understand the circuit well enough to point to a possible cause or causes.
Did you replace C-76 and C-77?
Old 05-30-2018, 10:28 PM
C76/C77 are 1000-mfd/15V electrolytics, which I replaced with new 25V-rated electrolytics. All paper & electrolytic caps have been replaced.
Old 05-30-2018, 11:08 PM
Phil's Old Radios
On other sets of the day that were based on the RCA 630 those caps on the linearity coil were 1000V IIRC. Are you sure the 600v ones you found in it were original?
Old 05-30-2018, 11:44 PM
They are specified as 600V in both the Sams and Riders parts lists, for what that’s worth.
Old 05-31-2018, 12:28 AM
OK, they are just huge filters to bypass all AC. I was guessing that, but wasn't sure if they could be smaller values that could shape the waveform. Never mind.
Old 06-20-2018, 12:33 AM
In the damper circuit, there is a 25-watt wirewound filter resistor (R86), which turned out to be open!
It's one of those guys that stands upright inside the high voltage cage.
Replacing it cured the worst horizontal geometry problems, but then the width was insufficient. Earlier in the project, I had removed a .25 paper cap that someone tacked in parallel with the width coil (L8).
I experimented with a decade box and found that .25 was indeed about the right value to bring the width back into range.
I guess the guy who added that cap was onto something
There's more tweaking to do -- there is still a very slight crushing of width on both far edges -- but I have a watchable picture for the first time in this project.
Yay!
Phil's Old Radios
Old 06-20-2018, 12:48 AM
EdKozk2 EdKozk2 is offline
Tinker
Hi Phil,
Your picture looks really good now.
Ed
Old 06-20-2018, 12:58 AM
irext's Avatar
irext irext is offline
I've been watching this thread with great interest. Very well done. Just goes to show "never give up". Working rear projection sets would have to be as rare as rocking horse poo.
Old 06-20-2018, 04:45 AM
decojoe67's Avatar
Very nice work. Interesting to see how these sets performed. They must've really impressed people back then with their, for the time, huge picture.
