Where in the world did you find the peaking coil (L24)?
Talon had it.
https://talonelectronics.com/shop/item.aspx?itemid=7720 they have a lot of hard to get parts.
=^-^= Yasashii yoru ni hitori utau uta. Asu wa kimi to utaou. Yume no tsubasa ni notte. いとおしい人のために |
It's blatantly obvious the the original yolk had a … problem and needed to be replaced, it seems to have failed rater violently, it's no wonder it did not take the CRT with it.
https://i.imgur.com/zzpbKHC.jpg it says in the Sams to use the back of the original yolk with the centering magnets on the new yolk, which seems to be what was done, but it was so damaged, I do not think I can ever get it back on again. The damn thing is melted to death! I may be able to bodge some of the rings from my projector tubes on to it, don't know how well it will work , or somehow use the plastic from the projector assy with these old rusty rings, somehow... who knows.
Your problem with the centering rings is very common. The plastic used could not withstand the repeated heat-cool cycles. There have been many posts about making a new yoke back end to accommodate the centering rings.
*yoke
All the plastic on the yokes do that over time, nothing violent about it. Bob Andersen has a couple videos showing how to rebuild them. One he did out of some PVC and as I recall the other from a yogurt container. |
| Audiokarma |
Photos here: https://www.flickr.com/photos/700398...57663009940550 Last edited by bandersen; 09-10-2020 at 04:12 PM. |
https://i.imgur.com/5c1EP28.jpg
I DO know that something very drastic happened to it sometime before I got it, because, i can tell that T4, T5 ,C94, C6, C7, ,C78, R58,R59 R106 had all been replaced before
It might be a case of a technician "shotgunning" a repair when they couldn't determine the exact cause of the problem.
HA!
i knew that those old dead projector tubes would be useful for something someday! https://imgur.com/Io3iUj0 https://imgur.com/wMz82D9
| Audiokarma |
https://imgur.com/tLCYEop
before https://imgur.com/LdbQKDD after https://imgur.com/iHz7AMA waiting for filler to dry si it can be sanded it will never be perfect again, there was too much rot. but after paint, it will be decent, i hope. why they left it in such a damp place for so long, i will never understand..
https://imgur.com/mznzZpn
https://imgur.com/VD4NM7L just ripped out what was LEFT of the base for the chassis bottom in the case, it was too far gone, gonna have to replace it with something.
holy cow!
I may have found another RCA color roundy! https://i.imgur.com/WvpxRTp.jpg no info on it yet not even sure WHAT it is yet,,, waiting to find out...
https://imgur.com/BTljJ8t
new bottom is made, mostly of spare pieces of wood I had. I still need to cut air holes in it. https://imgur.com/H8TanEw outside painted, covered up the major water damage. BTW,, I'm told the mystery color roundy is a GE, but no MO# yet.
| Audiokarma |
