Old 04-06-2021, 09:34 PM
As I suspected, 80% of the resistors in the thing are VERY out of tol, and are needing to be replaced, looking forward to what kind of pic I can see once I get vert working.
Old 04-08-2021, 10:57 AM
The 1M resistor in series not to mention the 2.5M pot should limit plate winding current to safe levels with the plate grounded.
I think I have only seen 1-2 Vert Osc transformers failed and one of them was mouse chew fail...
A while ago on the antiqueradios.com TV forum an australian posted an RF circuit one could use in place of a vert Osc transformer to help out someone with that issue in IIRC a Dumont set.
I'm not good at all soldering surface mount stuff but years of collecting and restoring have made me learn how to solder 2 paper thin wires together well.
I will soon have a new ( well NOS) X-fomer from ETF, that hopefully won't get lost in the mail, in the meantime, I think I have found what you mentioned, but I have no clue how it can be put into THIS circuit.
https://www.radios-tv.co.uk/communit...r-transformer/
https://imgur.com/CejiNie
Old 04-13-2021, 10:14 PM
While I'm waiting for the vert Osc x-former from ETF, I have noticed that some of the power resistors are running a bit warm, they are not smoking or anything, so I guess its OK.
https://i.imgur.com/p8TwMpx.jpg
R122, which was the candohm resistor, rated at 20w, now a 25w, still very hot, and R123, was a 5w sand resistor, was getting very hot, disintegrating, green leads, new ohmite 5w in there, still getting very hot. Gonna put in a 10w
electrolytic capacitors are new.
The 145v goes mainly to the video IF , no shorts found, and when I pull the IF tubes, the heating stops, so I guess this is normal...
Old 04-15-2021, 11:40 AM
dtvmcdonald's Avatar
Modern "leaded" resistors of all wattages seem to be designed to get extremely hot
at rated power. I've taken to using resistors the same physical size as the
old ones, unless they are running 1/8 watt or less. This usually means twice the wattage
or even more.
Old 04-15-2021, 03:44 PM
Measure the voltage across the resistor. Wattage = (V*V) / R Use a resistor rated for at least twice that.
Old 04-15-2021, 08:57 PM
OK....
found out a few things...
the 8yp4 does NOT work with thing
I had to go grab the 21aup4a from the Stromberg.
using a signal generator, I was SORT of able to recreate Vert osc, but It is not perfect.
https://i.imgur.com/Fqk4hXC.jpg
It will have to do till I get the transformer from ETF.
HORZ looks fine, IF is obviously messed up, but working mostly.
and it DOES look like this thing will work!
Old 04-16-2021, 10:20 AM
This IS getting rather interesting, since the 8YP4 would not work for some reason, checked 2 times, it was hooked up right, and still waiting for the 21FP4 from dieseljeep to be shipped, which I hope to be the final CRT for the completed project.
But as mentioned, since the 8YP4 was not compatible, I'm using my 21AUP4A/B for now, but the method I used last night of laying it down on foam pads and cardboard boxes is NOT the safest way to do this, not to mention, I really need to extend the CRT and yoke wires a bit to give more room to place things safely.
After thinking for a bit about how to do this, with a bit of searching I found a giant hose clamp. :O
Big enough to fit around the screen, so when I get it, I will attempt to build a base to strap it safely down to for testing, it will look very strange when done I think!
Old 04-16-2021, 10:53 AM
I'm still working on a quote for shipping. Then I'll PM you.
Old 04-16-2021, 12:06 PM
Is there a focus coil or magnet around the neck of the 8YP4 ? If so, you need to remove it. The 8YP4 is self focusing and an external magnetic field is not needed. Also no ion trap magnet.
Old 04-16-2021, 01:02 PM
I have used this 8yp4 before, when I brought up my FADA 895, so it was hooked up as you say.
One of which can be seen here, https://www.youtube.com/watch?v=Id3OWPlHtVo
But I have no clue as to why it did not work this time, it just gave a blank raster, brightness cont had no effect, SOMETIMES there was a dim negative image, but it just did not like it.
But hooked up the other tube, BAM! Image. so who knows
Old 04-16-2021, 01:56 PM
I'm gonna try something I did not think of last night...
With the FADA 895 & the 8YP4, video was being fed in on G1 with the cathode @ 0v, and adjusted G1 bias to set brightness, the Arvin has video going in on the cathode and adjusts IT'S bias to set brightness, and has G1 @ 0v... and the 8YP4 seems to hate it, what if I were to switch them?
Feed in the video in G1 like it was when it worked on the fada and hooked the cathode line up to where the 0V G1 was? :O
EDIT---
No, that won't work, cause even if it fixes the problem, it will cause a negative image... RATS...
Old 04-16-2021, 04:15 PM
21AUP4 and 8YP4 have different # of pins so I assume you are using an adapter ? Could be that G1, G2 and K are not going to the correct pins.
Do you have an 8XP4 ? That would be directly compatible.
Old 04-16-2021, 04:29 PM
I checked them 2 times
not sure why they why it does not wanna work
https://i.imgur.com/lsyrjzp.jpg you can see the adapter here, Got it from EM last year.
all the pins DO go the right place. it just does not like it
and Sadly I only have the one test tube.
but I have thought of an unusual way of mounting the 21aup4a for testing, which I will try tonight, which i am PRETTY sure has never been done before!
Old 04-17-2021, 09:02 AM
I DID say that my idea was unusual, and most likely never been done before!
https://i.imgur.com/UvGcHkg.jpg
https://i.imgur.com/Yu7bCLu.jpg
https://i.imgur.com/9ZKXqly.jpg
Took the chassis from the stromberg carlson x-21, and mounted the 21AUP4A in it backwards to be used by the Arvin chassis.
Old 04-19-2021, 08:43 PM
I managed to beat it into submission, a little bit
https://www.youtube.com/watch?v=_XjsK3P1DvU
