Old 05-09-2011, 12:33 PM
Originally Posted by Buzzsaaw View Post
That chassis looks so good that it's a shame to put it back into the case!.. Just leave it on the table and plug 'er in!.. Love the mold idea. !
Did you make a vid of that process?
Buzz
Thanks. Last night I received this email Maybe I could have saved myself a lot of time and effort
I've been working on the CAD drawings for manufacturing replacments for the original Philco Model 60 chassis. If any one would like one. Let me know. They will be reasonbly priced sheet metal chassis of the same thickness, punched out using a CNC turret press I own.
Yes, I made a video about casting those dogbones. It's starts at about 8:44. http://youtu.be/iBrJlkMY4XE#t=8m44s
Last edited by bandersen; 05-10-2011 at 11:34 AM. Reason: Modified youtube link to start at 8:44
Old 05-10-2011, 11:16 AM
Buzzsaaw's Avatar
Buzzsaaw Buzzsaaw is offline
Cool Bite the dogbone!
That's cool.. re make the chassis!
but I like what you did to it.
I watched the vid.. great job as usual!
Buzz
______________________
Buzzsaaw
Sunlitedreams.com
Old 05-13-2011, 08:32 PM
There's just one item left to deal with - the dial lamp is very corroded and falling apart.
I drilled out the rivet holding it together, removed the rust and patched with J.B. Weld.
Then, sanded it down, painted silver and reassembled.
And with that it's finally done
I'm still using the donor speaker though. One of these days the backordered cone will show up and I'll post an update.
Also, I never was able to completely flatten out the dial, but it works well enough.
Here's some before and after pics.
Old 05-13-2011, 09:48 PM
Here it is back in the cabinet with the donor speaker. I think it sounds pretty good. I'll try enclosing the bottom as suggested earlier when I get the reconed speaker back.
The cabinet could use a little work and the knobs are a mix of black and brown, but it'll do for now.
Old 05-18-2011, 03:52 PM
The reconed speaker just arrived in the mail. The paper cone was salvaged from another speaker as new ones seemed to be backordered indefinitely at the supplier my reconer uses.
Time to pop it in and give it a try.
Old 05-20-2011, 03:16 AM
I finally installed the rebuilt speaker and gave it a try. It sounds quite good. I certainly can't tell the different between it and the 37-60 speaker I had been testing with.
I blocked up the radio cabinet bottom temporarily and it does make a noticeable difference for the better. I think I'll cut a piece of masonite to size and mount it with some glue blocks.
I guess that's it for now. Perhaps I'll refinish the cabinet someday
Old 05-20-2011, 07:57 AM
Reece's Avatar
Reece Reece is offline
Recommend a piece of plywood 3/8" or better rather than Masonite as the latter is too thin and can vibrate and rattle.
Reece
Old 05-20-2011, 10:23 AM
Ah yes - good point!
