Old 05-30-2011, 01:56 PM
VintagePC's Avatar
Tube bug got me 05/2010
Looks to me as though something is clamping the vertical sweep wave... i.e. it's rounded off on the bottom instead of a nice sawtooth.I'd be tempted to say it's a passive component (resistor, capacitor) that's the culprit, but if that's the case, you'd see it at the top of the sweep too.
Does anything happen if you adjust the vertical centering control, and if so, can you bring the top edge of the raster in to view?
Old 05-30-2011, 03:55 PM
vts1134's Avatar
vts1134 vts1134 is offline
Looking For Time
I don't know where the vertical centering control is on my set. I don't see mention of it in the schematics.
Old 05-30-2011, 04:01 PM
Originally Posted by vts1134 View Post
....I also adjusted the vertical controls to see if I could get an aligned picture but the picture above is as good as I could get it. I'm not sure if you can tell by the picture but the bottom of the picture is brighter than the top... Any ideas on where to head next?
Try jumping a known-good electrolytic across C1 (the 100mf one going to the cathode [pin 8] of the 6V6). That's exactly the effect you'd see if that cap were open. oc
Old 05-31-2011, 08:19 AM
jeyurkon's Avatar
jeyurkon jeyurkon is offline
The bottom is brighter than the top because the vertical linearity is way off. It could be an adjustment, or a symptom of another problem.
Old 05-31-2011, 09:03 AM
That's correct.
An open (or absent) electrolytic (C1) on the cathode of the output stage will cause severe non-linearity with insufficient sweep at the bottom. I'm wondering too if the problem isn't related to T2 (the coupling xfmr.) being different from the original.. and also if this difference is gonna cause the vert. frequency to be off. oc
Old 06-02-2011, 07:10 PM
vts1134's Avatar
Looking For Time
I don't have another 100uf cap to replace C1B, nor do I have a capacitor tester. What I did do was fire the set up and take a visual check, then remove the cap that is in place and fire it up again. There was no change at all in the picture. I'll get another 100uf cap and try swapping it in.
Old 06-02-2011, 07:21 PM
VintagePC's Avatar
Seems to confirm what everyone says... Fingers crossed once you get that replacement!
Old 06-04-2011, 09:31 AM
vts1134's Avatar
Looking For Time
New cap same problem . Might R3 be the problem? I've tested it for impedance but could it fail in another way? I'm going to try again to get the real replacement for T2 to eliminate that from the equation also.
Old 06-04-2011, 10:47 AM
Well doggone. Did you connect the + end of the cap directly to pin 8, and the other end to ground? (Some foreign-sourced electrolytics have an arrow pointing to the [-] end of the unit, which can trick you as to which polarity it's signifying.)
Not likely if it measures (approx.) 5K and shows no dead spots or drop-outs throughout its rotation.
Old 06-04-2011, 03:01 PM
vts1134's Avatar
Looking For Time
R3 reads 5k on the high side and just a couple of ohms on the low side. There are no dropouts or dead spots in the rotation. C1B used to connect to pin 8 with a wire. I removed the wire since I was no longer using a multi stage can and now have the electrolytic directly on pin 8 and the negative right to ground. Here's hoping a new T2 will be the answer.
Old 06-05-2011, 09:41 AM
VintagePC's Avatar
If you have the proper resistors to match the new T2's resistance to the original, you can try that too. I doubt it would work, but if it does, it might save a few bucks on trying to locate a matching part elsewhere.
Old 06-08-2011, 05:25 PM
vts1134's Avatar
Looking For Time
New transformer same problem . I will return to the schematic for component by component tracing soon.
Old 06-08-2011, 05:52 PM
VintagePC's Avatar
Sounds like it's time to break out the scope
Tracing waveforms can get you a good idea of where the problem lies. Do you have a reference of what they should look like? (Usually in a Sam's)
Also, if you have substitute tubes, it may be worth trying those too. Some sets drive them to their design limits, and the result is a set that works perfectly with one tube, but not another that is slightly out of spec. Both tubes will still test good, of course, so the easiest way to find this problem is what's called the "tube roll" (swapping tubes in the problem areas with another one).
Old 06-08-2011, 06:18 PM
I have found that to be the case with oscillator tubes, especially. Sometimes I have had to swap in several horizontal oscillator tubes before finding one that the TV "liked."
Speaking of oscillators, are the voltages on V13 still as far off as before?
Looking at waveforms with a scope seems sensible. This schematic doesn't give models, but you could start by looking at the grids of V13 (oscillator) and V14 (output) and posting photos of what the scope traces look like there.
Old 06-08-2011, 06:39 PM
Well tarnation. Just out of curiosity, what voltage are you getting at the low/wiper end of the vert. size control? oc
