I recall Phil posted a photo of Barkhausen oscillation recently and it appears as a narrow squiggly vertical line. I did try different tubes and it had no effect.
I've also noticed fine tuning does have quite an effect on it as Eric mentioned earlier. I'm going to hold off on fooling with that issue and the buzzy audio until I do an alignment. Between replacing so many caps, resistors and tubes I figure it's got to be off. Here's about when the arcing sound is worse as power up ![]() and at power down ![]() I get a sense there's built up energy looking for somewhere to go. I'm also starting to wonder if the sound is actually coming from the speakers and not arcing at all.
Looks like a borderline weak H oscillator tube. The pic should come on fully locked in.
Not sure how out-of-sync horz sweep would cause the arcing sound, though. |
Great job man! That cabinet turned out beautiful. I can't even tell the top was redone, the color matches perfect. Nice picture too, I wish there were some LP stations closer to me. I can pick them up, but not clearly.
My TV page and YouTube channel Kyocera R-661, Yamaha RX-V2200 National Panasonic SA-5800 Sansui 1000a, 1000, SAX-200, 5050, 9090DB, 881, SR-636, SC-3000, AT-20 Pioneer SX-939, ER-420, SM-B201 Motorola SK77W-2Z tube console McIntosh MC2205, C26 |
Does this tv have a piece of metal from the chassis that lays on the dag of the CRT to bleed off a charge? Is it workin okay???
SR |
| Audiokarma |
There is a metal tab at the top and bottom of the CRT tension band than press against the dag. I'll double check. I'm also going to check the tubes on the sweep board again. It does take a while for the set to lock when turned on.
I'm a little distracted by a free set that was just dropped off Details to follow.
In instances like this, the set itself can be the best tube tester.
I'm wondering if the Horizontal osc coil needs touching up? The one on the board I mean, not the Consumer used control.
You may just be hearing the screech of a tortured oscillator trying to start up. |
Perhaps. I'll pull the chassis out once the cabinet refinishing is done and go trough all the factory adjustments.
I spent a lot of time and used a lot of tape to get the set masked off so I could spray the top. Lacquer dries after a couple feet in the air so I'm not concerned about any getting on the feet on my floor. They will just be some brown dust I'll clean up with a swiffer. ![]() Here it is after three passes with the toner and a couple coats of semi-gloss lacquer.
The weather is finally warm again and I should have the top done soon. Meanwhile, I snapped the neck off the original, dead CRT so I could dispose of it. I wish I could just reach in there and fix the filament ![]()
| Audiokarma |
You could fix it now
...Though it probably would not do you any good without CRT rebuilding equipment. I tend to keep electron guns whenever I have to snap one off. I like the way they look...Especially the delta-guns off of rectangular color tubes; those sort of look like Lightsabers
I finally decided I was happy with the top and removed the masking tape. It's not exact but a pretty decent color match I think. I'd have to do a custom blend to get any closer. After it cures a while longer, I'll knock it down with some steel wool and pumice.
Now I can get back at the electronics inside ![]()
Man, I think it came out really cool! It certainly looks like it was well worth your time and effort!
Charlie Trahan He who dies with the most toys still dies. |
Hi All;
Bob, I am Glad to see that it was you who snapped off the neck, instead of something Your picture tube checker did to it.. THANK YOU Marty |
![]() CRT testers are electrical devices that attach to the CRT base via a wire and socket and apply fairly low voltages. The only way someone could snap a neck off a CRT during testing is by having an unsafe procedure or an accident. The only way a tester could neck a tube when used properly is if the tester got hit by lightning during the test(CRTs have been known to have neck failures and implosions if subjected to voltages more than 50% over their specked HV anode voltage).
| Audiokarma |
