Old 12-02-2013, 07:28 PM
Kevin Kuehn's Avatar
Workin' Late Again
It looks to me like the 6AL7 is driven by one plate of the 6T8 discriminator through a low pass filter. So it's an indication of the audio carrier strength ? Since my audio isn't tuning as expected, I guess it follows the indicator would behave oddly.
Sounds right. I wonder if it's possible that the output of your disc. transformer was inadvertently wired in reverse at the factory? I'm not even sure if that would do it, but it seems odd you're getting a signal inversion to your eye tube.
I also noticed a note in Sams saying some models have L23,L24 reversed. Not sure how that would effect the alignment process.
Did you ever figure out why the sound trap(A13) was not working in the tuner? That could account for some dependencies seen during alignment.
Old 12-02-2013, 08:05 PM
No, but I've seen the same issue with traps in other sets and it was always a faulty mica cap. I'm not too keen on opening up that tuner and extracting the trap to find out.
I'll trace out the eye tube wiring as soon as I can. I'm way backed up at work right now from the holidays.
Old 12-03-2013, 02:59 AM
I stayed up late and gave the sound IF and good going over. Right away I noticed a 1K resistor with a crack that measured about 300 ohms. The one to the right of it measured 1,300. Both got replaced.
Next came the mica caps. 3/5 were bad - a 10pF, 27 pF and 47pF. By 'bad' I mean they were showing leakage at less than 200 volts (all are rated for 500) and I couldn't get a capacitance reading. Hopefully, replacing these will have a positive impact on the sound tuning.
Old 12-06-2013, 02:56 AM
I finished replacing the leaky mica caps and out of tolerance resistors including the one in the eye tube base then redid the audio alignment. Bingo!
The eye tube now responds like it should, I only get good sound at one distinct point on the dial per station and it coincides with a sharp picture.
Time to start putting this set back together
Old 12-06-2013, 08:43 AM
IsthmusTV's Avatar
IsthmusTV IsthmusTV is offline
Good show, Bob! Congratulations. After spending more time tuning around with mine, I notice that I also have the double peak issue with the audio. It's not as pronounced as yours was, but clearly I still have some work to do. I'll start by looking at those mica caps.
Are you going to do anything to the cabinet? I haven't done anything to mine except superficial cleaning.
Again, congratulations. Your friend should be very pleased.
-Clark
Old 12-06-2013, 09:03 AM
Workin' Late Again
Congratulations is right. I still don't understand how those bad components would cause the reveres action you were getting on the eye tube. Suppose it was a combination of the leaky caps which caused a false alignment indication at multiple resonances. Was the alignment off a lot when you went back through it? At any rate I think we're about to the point in time that we need to start shotgunning all mica caps. Although sometimes those types of caps make for a excellent learning experience.
Old 12-06-2013, 09:51 AM
bigaudioal's Avatar
Congrats, Bob! I just watched your YouTube video last night on this set. Nice to see that you solved the audio issues and the tuning eye reverse issue. Cannot wait to see the next video of this set functioning!
-Al
Old 12-06-2013, 09:57 AM
Micas can go bad and I have replaced my share of them, but many more in sweep circuits (horizontal, vertical) and HV circuits. Audio circuits tend to be more forgiving, but if you find a bad one -- or two -- there, of course it has to go.
I would not advocate shotgunning micas in IF stages unless you are well equipped and well versed in alignment, since a slight change in lead dress may kick things out of whack. Ditto, even more so, for the tuner section. Service manuals often included warnings to keep your clumsy mitts out of the tuner.
These days I look on mica caps as I do resistors. Generally more reliable than the hopeless paper caps, but not immortal. If a basic (paper + electrolytic) recap doesn't magically fix everything, then the next phase is to look at micas + resistors. One thing that I do during the basic recapping phase is test every component on the same terminal where I am connecting a new cap, the theory being that if I'm disturbing (unsoldering & resoldering) anything on that terminal, I may as well deal with everything at once to avoid trashing the connection with repeated monkey-wrenching. That way, I naturally uncover some other bad parts as I go, although it's not very systematic.
Old 12-06-2013, 11:18 AM
Originally Posted by IsthmusTV View Post
... Are you going to do anything to the cabinet? I haven't done anything to mine except superficial cleaning.
-Clark
Pleased and relieved as I really want to get back to my other projects
I'm not going to touch the cabinet but the owner asked for suggestions on preserving the finish. I'm no expert on blonde finishes but I figure a quality, non-silicone furniture polish found be fine.
Congratulations is right. I still don't understand how those bad components would cause the reveres action you were getting on the eye tube. Suppose it was a combination of the leaky caps which caused a false alignment indication at multiple resonances. Was the alignment off a lot when you went back through it? At any rate I think we're about to the point in time that we need to start shotgunning all mica caps. Although sometimes those types of caps make for a excellent leaning experience.
Yes, the IF between the 1st & 2nd audio stages was off as was the discriminator. Those are the areas where I replaced three micas and several resistors.
I would call it a reverse action - more like the bias point was shifted over so that the left bar would never dip below the reference bar. Now, it swings to either side. I'll show that in detail in the next video up later today.
That video was my first attempt at alignment. I'll post another video later today showing the replaced micas and second alignment with the correct tuning eye action and sound.
I would not advocate shotgunning micas in IF stages...
I agree and didn't touch the tuner. Also the micas in the video IF tested OK so I left them alone. It was tempting to replace them all, but that would require yet another alignment plus those micas get expensive! Also, there's always that risk of slipping with the soldering iron and damaging a coil or other fragile component.
I think the big culprits were the bad 10pF coupling mica cap between the 1st and 2nd audio IF stages and the two bad 1K resistors which threw the bias off the 2nd tube.
Old 12-06-2013, 11:39 AM
egrand
Guest
Posts: n/a
Yipee! Great going! Look forward to seeing the video.
I've wondered on some of these sets if the reason a bunch of components are bad is because of some kind of power surge or jolt to the system in the past? Something like lighting coming in the ac line or antenna lead. Maybe even running long time on low voltage or other abuses?
Perhaps that doesn't explain it as much as plain old age and normal wear and tear. And, maybe that couldn't affect these mica caps. But, I see some people's restorations with a bunch of normally good components that have gone bad and think they all got zapped by something instead of just coincidence.
Just wondering out loud here (or through a keyboard).
Old 12-06-2013, 12:16 PM
I was thinking more along the lines of an issue with the materials or construction technique used. All the failed caps are "Micamold" - not exactly know for being high quality.
Old 12-06-2013, 12:57 PM
Workin' Late Again
I have to agree that shotgunning the mica caps could be a bad idea. I keep forgetting that not everyone wants to get involved with alignment. Although in a few more years it may come down to that. Even so it would be best to replace them one at a time, testing as you go.
Old 12-09-2013, 12:19 PM
I reinstalled the yoke, speaker and chassis and fired it up. Well that's a little disappointing. Moving the ion trap magnet all around the neck has barely any effect. I brought it near a screwdriver and it seems plenty strong. I'll dig up some spares and give it another try.
Old 12-09-2013, 02:01 PM
I consulted the Rider service info and they mention this specific issue. It seems that he original 17AP4 required a stronger magnet than the 17BP4. They suggest sliding the original all the way back over the base.
That did the trick I'll try to find an RCA to F connector at Radio Shack tonight so I can feed a cleaner signal into it.
While working on this issue, I would occasionally hear a loud squeal from the HV area. Eventually, I tracked it down the the HOT plate lead. Moving that wire just slightly on the end going into the cage can eliminate or bring back that squeal. I suspect that's why there's tape wrapped around it - to keep it from moving. I guess I'll pull the chassis again and take a closer look. Probably a bad connection at the flyback or a break inside the wire.
Old 12-09-2013, 03:53 PM
holmesuser01's Avatar
Congratulations on getting a picture on your set CRT! It is looking great, to me.
Bruce
