#91
LOL yeah I know
Sheesh, I din't payed atention. I thought the engine was included.
True that stuff is rare, but with 8,000 bucks I think you can buy an unrestored car. |
#93
But does any one haves photos with old hand singnals? Like you see here from 7:16 https://www.youtube.com/watch?v=cPLgZqP0Hts
When do automobiles in U.S.A. started to had turn signals and how did they looked? |
#94
Atleast as far back as the 30s turn signals were available on some cars as an option, and on any car as aftermarket modifications. I think they remained an option until the early 50s then became mandatory on new cars...IIRC in some places if you own a car that never had factory turn signals you don't have to add them.
#95
Wow I didn't even know it, but the hand signals have changed a bit from back in the day. We are still taught hand signals in driver's education, but they are only left turn, right turn, and stopping. Presumably if your lights are out, you should use hand signals.
As for the year they became mandatory, I'm not getting a clear reading. It looks like 1955, but I think it might have been different for each state. I can't seem to find any photos of old aftermarket turn signals, though I'm sure many still exist. I recall when I was young, my dad was fixing a 1930's Packard, and it had an aftermarket signal switch on it. It was just a turn signal stalk that you clamped to the steering column, and presumably some lights to mount on the outside of the car. |
| Audiokarma |
#96
In U.S.A. the autombiles didn't had trafficators?
I was wondering if you could install heating on cars that don't. I found that you could. Now here's something intresting: http://www.oldclassiccar.co.uk/forum...c6e48c7f860809 Last edited by Telecolor 3007; 11-08-2019 at 07:47 AM. |
#97
Do you know this chanel?
https://www.youtube.com/user/USAutoIndustry/videosHere is another one: https://www.youtube.com/watch?v=RCEmhR_QTgs Last edited by Telecolor 3007; 11-16-2019 at 08:39 AM. |
#98
I didn't know of it, but I subscribed now - thanks
#99
Fun fact , both cars were 6 volt electrical systems with tube radios . I of course had the radios working perfectly and had taken an FM converter , used a small 6 V motorcycle battery in series with the car's 6 V to supply the converter with the 12 V it needed , and headbanging metal was happily blasted to the general disgust of most of my fellow commuters
#100
Lol. Depending on how I feel I may do that and or rewire the original radio...A year or so back I took a late 40's mono Magnavox home console and upgraded it to stereo. The process involved adding sections to the band/function switch of the AM/SW/preamp chassis, reworking the preamp for stereo, adding an FM MPX chassis (to work with the factory FM tuner), swapping the 60's VM someone cobbled in with a Magnavox badged Colarro Conquest, and a installing a second matching PPP 6V6 amp chassis to it (the results were pretty awesome )...Part of me, if I ended up with a messed up enough car radio, would like to do something akin to the what I did to the Magnavox and custom build an AM/FM stereo tube car radio with powerful tube-based amp unit based on a car radio chassis that is beyond hope for resto...I'd also really like to get one of those RCA 45RPM car changers.
Tom C. Zenith: The quality stays in EVEN after the name falls off! What I want. --> http://www.videokarma.org/showpost.p...62&postcount=4 Last edited by Electronic M; 11-17-2019 at 12:06 PM. |
| Audiokarma |
#101
#102
I wish me for a '30's-'40's car, but I want a British one.
So in the early '50's you still had to do hand signlas when driving?
#103
If your car didn't have signals (and other cars and or police were present) yes....even if you did have signals you had to understand them when other drivers used them... nowadays there is probably a rather large portion of the driving population that wouldn't know hand signals if they saw them...
#104
In Europe I think allsmot all cars had some kind of turning signal by the early '50's.
#105
Steering column mounted turn signal units were still showing up on heavy trucks fairly recently though I'm not sure how compatible they are for use on a car. Signal Stat is a popular brand; a quick search shows they're still available, and pretty cheap.
Bryan |
| Audiokarma |
